Question about Zanussi IZ12 Front Load Washer
Zanussi IZ 12 pump access
I have a Zanussi IZ 12 that appears to have a pump problem. I can hear the pump working but with a grinding sound, and water isn’t being pumped from the machine. I believe the pump to be at the front of the machine close to the filter. That being the case, can anyone assist with the front cover removal to gain access? Thanks Paul C for the info on the sneaky ones, I wondered about those.
Ken M
  • Zanussi Master
  • 3,463 Answers
You should not need to remove anything to check and clean pump filter.
Open the filter door at the bottom right front of washer, there you will see the pump filter cover, unscrew the filter anti-clockwise, and remove the filter, and clean same.
With the filter out, you will see the filter housing, which is fastened directly on to the pump, have a good look inside the housing, and see if anything is stuck in there.
Refit filter, and test.
Please rate my fixya solution.
Thanks.
Posted on Jan 31, 2009
How do you remove the lower front cabinet plinth on a Zanussi IZ 16 S washing machine?
Why? If I remember correctly behind the plinth do not have access to anything. If you need to replace the drain pump or filter housing you can access from the bottom or open housing of washing machine. This washing machine has a housing split into two halves and afterwards you will have access to almost all components of the washing machine.
If you need to replace just plinth, may help this spare part list.
Dado
Feb 19, 2017 | Zanussi Washing Machines
Is the alan screw that holds the pully for drum on zanussi iz 12 right hand or left hand tread?
Have a look at the beginning of the tread, and it will become obvious that it is left or right hand.
Jan 24, 2015 | Zanussi Washing Machines
Zanussi washer iz 12 error e10
Switch off.
Press and hold the two buttons again and switch on.
The appliance will beep or flash, let go of the buttons, the leds will scroll.
Press and release the temperature button until the bottom led of the 2nd column is lit.
Let me have the error code.
Switch off, on and off again
Nov 28, 2010 | Zanussi IZ12 Front Load Washer
Grinding sound - drum turns then nothing - just grinding sound until E20 warning.
Can you turn the drum by hand.E20 relates to a fault with either the pump or the filter or drain may be blocked,check the filter is clean and the pump can be turned by hand,its up at the end of filter housing and can be seen depending on the model.If the drum cant be turned freely then you have something stuck inside the drum.
Hope this was helpful.
May 02, 2010 | Zanussi WJS1265W Front Load Washer/Dryer
Grinding noise from passenger side engine
The water pump bearings could be going out and they will make a grinding noise.The water pump doesn't always leak when the bearings are going out.
Sep 01, 2009 | 2002 Dodge Neon
Whirlpool Duet Washer Making Loud Grinding Noise
not nesseccarrily your pump, possible you have a rear bearing going bad, which will sound as if a helicopter is coming through your laundry room. ( noisy pump can be the issue , honestly a better and cheapre problem to have) in order to determine if its apump problem you can remove the lower access panel and unplug the pump then start the spinn cycle, if it still loud the pumpms not hte issue.
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Zanussi WJS 1397W
possibly a foreign object in pump.
tilt backwards at a good angle and remove pump. i find the easiest way to do this is to undo the 3 screws round the periphery of the pump
Jul 11, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi IZ 12
I've just spent an hour taking mine to bits. On the back there are 2 x 9mm silver nuts at the bottom, below the star head screws you removed to get the top off. Then there are two more sneaky ones at the bottom of each side panel, just next to the gap about half way along on both sides., with a plastic cover hiding them from view. Make sure you release the mains cable holder from the top of the back by pressing the plastic clips down, then the whole shebang should slide off easily.
Regards. Paul C
Dec 31, 2007 | Zanussi IZ12 Front Load Washer
Zanussi IZ12 Front Load Washer Logo
510 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
