Question about Kenmore 53082 / 53084 Side by Side Refrigerator
My Kenmore side by side cuts out when plugged in, trips the GFI.
We moved a few months ago, we used it full time before the move, now in the new house when we plug it in it blows the GFI, will not work at all.
  • petersen99 Jan 31, 2009
    Checked all the above and also unplugged/disconnected power to compressor, lights, fans among others. Still trips any plug we use.
  • Mark Egan May 11, 2010
    I am surprised the refrigerator is on a GFI. But -
    GFI's work on the theory that the current in the neutral wire has to be the same as the current in the line wire, or there must be a current path through something else, and that something else could be a human body. So, it trips.
    How old is the refrigerator? Many components like defrost timers and fan motors will continue to operate with internal short circuits, and not cause a problem, until connected to a GFI, and then it detects a circuit imbalance, and trips.
    Has it ever been worked on, and if so, what condition is the wiring? Correct any suspect wiring errors.
    Any exposed strands of wire sticking out anywhere? If so, correct.
    Is the power cord in good condition, and is the grounding conductor securely fastened? If not, correct
    Has the third prong been removed from the power cord? If so, have the power cord replaced.
    Please reply your findings, and I'll provide you with more instruction.
    President:
  • 1,214 Answers
Do you know how to use a volt-ohm meter, and do you have one avaiable to you? Preferably a digital one.
Posted on Jan 31, 2009
After moving to a new home, the freezer keeps tripping the breaker every few days
My first instinct is to ask you, are you plugging this freezer into a GFI outlet, one which has a breaker switch as part of the outlet? If so, that is the culprit and not the freezer, as refrigerators and freezers will often trip this ground fault indicator because water can on occasion reach ground, which causes the breaker to trip on the outlet.
Test this by plugging the freezer into a non GFI outlet for longer than a few days. Nothing is broken and you dont need refrigerator repair service.
Sep 29, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
I cleaned my Kenmore 59658692890 and moved it to the garage. When I plug the fridge in the GFI trips. Any suggestions?
Refrigerators has starting amps that do not done well with GFI circuits.
GFI is designed to trip with a power surge.
Refrigerators have power surges.
Find a non-GFI circuit to plug into.
Jun 27, 2010 | Kenmore Refrigerators
Moved Kenmore dishwasher to new house. Installed it. It will not start. Is there a reset switch? Model 587-1541590. Electrical installation checked OK. Water connection checked OK. Is there something I...
You say "electrical installation checked OK"...is the machine hard wired into a junction box or does it plug into an outlet?
If in a wall socket the new house circut may be on a wall switch which is currently off. If it is plugged into a GFI outlet it may have tripped, Find another power source to wire to, GFI plugs and dishmachines just don't get along, Learned that some time ago!
There may be an issue with your door safety switch on the unit.
Check for voltage where the house wires are wire capped in the machine if hard wired, sometimes twisting those can cause issues.
I doubt your machine has a reset switch but many hobart units have on on the motors.
It really sounds like you have a voltage issue.
Dec 22, 2009 | Kenmore Dishwashers
GFI switch outlet may have damaged Kenmore 55771 side-by-side?
Could be the GFI switch.
The washer has a 3-prong (grounded) plug, what about the other appliances that you tested?
The GFI may not have a good ground and the 3-prong appliance provided a "difference" that the GFI detected as a "fault".
Sep 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
10 year old air compressor cuts off at 10psi
hello, if you plug the compressor into a none gfi outlet does the compressor still cut off ? it could be one a short in your compressor causing the gfi to trip our your gfi has a ground try the compressor in a diffrent outlet, when you use any other electronic equipment on the gfi does it still trip ? if you use the compressor in a diffrent outlet that's none gfi this should sholve your problem most likely a bad gfi outlet or the compressor is drawing to much amp's.
Mar 28, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
Kenmore side by side shorts out when plugged in
you have a short may be refrigerator or wall check panel
Jan 31, 2009 | Kenmore 53082 / 53084 Side by Side...
Try a different circuit to plug the fridge. Possible you GFI is weak and can not take the start surge of the compressor. Refrigerators need to be on 20 amp circuits and not on same circuits with lights ,televisions,etc.
Also if the refrigerator has be laid down on its side during moving give it 24 hour for the oil to return to the compressor. This also is a symptom of overload on the compressor.
Let me know what you find..Sea Breeze
Jan 31, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Fridge keeps tripping electricity
I assume by "earth leakage" you mean it is on a GFI circuit? Some older GFI outlets are sensitive to and do not work well with motors or other inductive loads like your refridgerator compressor. As for the compressor feeling hot, this is usually normal.
If this is a GFI outlet, try replacing it with new unit. If it is a GFI breaker, try replacing that.
Dec 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Gfi outlet keeps tripping
try running an extension cord to the old outlet and see if the fridge works then you'll know if it's the fridge or outlet. good luck
Dec 03, 2008 | Whirlpool ED2FHEXN Side by Side...
Ge 50amp gfci trips, worked great before I bought it
Hi hondo,
When an electric motor kicks on there is an in rush current called FLA(full load amps), it is usually about 125% of rated circuit amperage. Try a 2 pole 60 amp gfci circuit breaker and see if that solves your issue. Going up to this amp breaker will not be a fire hazard or cause any anomalies.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it!
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - anaanymous
Oct 19, 2008 | Spa Parts Plus GFCI, Circuit Breaker, 40...
Kenmore 53082 / 53084 Side by Side Refrigerator Logo
96 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
