Question about Singer 3116 Simple
The thread bunches at the bottom. It worked fine then one day in the middle of my sewing it bunched. I rethreaded. I adjusted bobbin tensions with the little screw and on top. Help
  • mysimonjelly Mar 22, 2009
    I rethreaded my machine, adjusted the tension and the problem was not fixed.  The machine has done this before and I rethreaded it and sometimes it helps, sometimes not.  I know it is threaded properly and when I have finally gotten it temporarily "fixed" it will work for awhile and then the thread just gobs up under the fabric.  I have a singer sewing machine.  can you offer any other things to try?
  • 124 Answers
Welcome to FixYa! I am the sewing machine expert that chose to help you with your issue.
There are really only two things that can cause bottom (note: remember that problems with the bottom thread, almost always comes from the top and not the bobbin. Bobbins rarely need tension adjustments). These two things are:
  1. An area was missed when the machine was threaded (most machines have an arrow at each area on the thread path where the thread MUST run or the stitch on the bottom will be sloppy. Threading can be tricky and even the most experienced miss once in a while.
  2. The tension adjustment mechanism in the thread path. If the thread is not properly through this area, the thread on the bottom will be sloppy or if, threaded properly, and the tension is set too loose, the stitch will be sloppy. If the tension is set too tight, the bottom thread will be tight and pucker the fabric.
It is counter-intuitive that problems with the top tension cause problems with the bottom stitch but it sure will.
So try it and see if that helps.
Thanks for using FixYa.com
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further.
Posted on Jan 31, 2009
My thread keeps looping on bottom Have changed tension, needle rethreaded and changed bobbin nothing helps what am I doing wrong?
not sure if this will help you...Check Your Tension Settings. Looping underneath the fabric usually occurs when there is not enough tension in the needle thread to pull the bobbin thread. Sometimesthread buching can be caused by something as simple as the tension dial being inadvertently turned.
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC ? ' eBay
www.ebay.co.uk/gds/WHY-IS-THREAD-BUNCHING-UNDERNEATH-MY.../g.html..
or you could go to this link and see if it helps you out.. thread keeps looping Google Search
Oct 22, 2017 | Sewing Machines
Why is sewing machine thread gathering under fabric?
adjust the tension to a appropriate setting,
See the video here.
Sewing Help Sewing Machine Problem Thread Bunching Under Fabric
The knob and its location can differ based on the model of your sewing machine.
Oct 29, 2016 | Sewing Machines
Why is my Brother SQ9185 Sewing Machine thread bunching up on the back side of the fabric?
That is called thread nesting or bird nesting. Usually it is because it is threaded incorrectly (sometimes the thread jumps out of a thread guide or the take-up lever), the upper thread is not seated in the tension disk, or the upper tension is incorrect.
First thing, install a brand new needle.
Second, remove the upper thread, RAISE the presser foot and rethread from the beginning--make sure the correct thread path is followed.
Third, check that the upper tension is set at the midway point between high & low number.
Test. Adjust the upper tension as needed. Re-test. Tension is correct when the upper and bobbin threads meet in the middle of the fabric.
need elp with tension on singer cg550
Apr 07, 2016 | Brother Sewing Machines
When i run a straight stitch, the top of the fabric looks well sewn; the thread on the bottom of the fabric, however, bunches up-it looks nothing like the top stitch.
Is it really the bobbin thread that is bunching under the fabric, or is it really the top thread that is creating loops and "bird nests" under the fabric???
Rethread your upper thread. BEFORE you thread the upper thread, be sure to RAISE the presser foot. This releases the upper thread tension disks so the thread is firmly seated in the tension disk.
If it continues to be a problem, then the upper tension needs to be tightened. Adjust slightly, then test. Repeat until the upper and lower threads meet in the middle of the fabric.
Sep 24, 2015 | Sewing Machines
I have a Bernina 1008. The thread is bunching up underneath when sewing. I've cleaned and oiled the bobbin area, rethreaded and adujusted the upper tensnion- the topstitch looks fine, it's lumpy on the...
Hello. Make sure the bobbin is not backward. It seems the upper tension is still not adjusted right. If the bobbin pulls smooth focus on the top tension. Good Luck
Feb 13, 2014 | Bernina 1008
My bernette 65 is bunching underneath. How do I resolve that?
Grasp the threads and hold them down when you start your seam. If it still happens make sure your thread is seated into your upper tension mechanisms. If that still isn't solving your problem... CLEAN between the tension discs with some sturdy fabric folded in half. (wax build up from threads can cause issues)
Good luck
Aug 04, 2012 | Bernina BERNETTE 65 Mechanical Sewing...
The stitching is not right. It looks fine on the top of the fabric, but bunches up on the bottom
Looping or bunching on on the bottom is a result of problems with the TOP TENSION.
Rethread the upper thread and adjust tension. Try again.
Jul 05, 2012 | Brother CS6000i Computerized Sewing...
Top thread is bunching on the bottom. Ive tried rethreading both threads, changing the needle, adjusting the tension (both up and down) of the top thread. Dont know how to adjust the bobbin tension. Its a...
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Sep 25, 2010 | Sewing Machines
Sewing a bunch of thread from the bottom, this stops the machine from actually sewing
Yes, it does. There are a couple of reasons the bobbin thread could be bunching up on the underside of the fabric. It could simply be that the machine needs cleaning. Take the bobbin assembly out, brush all the old lint out as best you can, reoil the machine once it's all clean, and make sure there aren't any little bits of thread caught in the bobbin assembly. Rethread the machine (carefully) and change the needle. This solves the problem usually--especially if the machine was sewing along fine and the problem develops suddenly. '
The other thing to check is your tension. It could be that the top tension is too loose. But different color thread in the top and in the bobbin, stitch a few inches (be sure to held the top and bobbin thread ends behind your needle as you start to stitch) and check. WIth the pressure foot down, adjust the tension, and stitch again. Keep stitching, checking, and adjusting until you see little if any bobbin thread on the top or top thread on the bobbin.
Another thing to reminder: use the appropriate thread and needle for the fabric you're sewing.
Let me know if this works, ok?
Robbie
Jan 31, 2010 | Elna Sewing Machines
Singer 3116 Simple Logo
288 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
