Question about Dell Dimension 2400 PC Desktop
D drive onj dell dimension 2400 will not open...
Problem was intermittent but now will not open. if needed do you sell drives? thx
    Scholar:
  • 66 Answers
Using a small needle their should be a hole in the front. This is the safety eject hole that will open the drive 99% of the time. Replacing the drive is just as easy. remove the few screws on the bottom of the laptop nearest the drive and grasp ahold of the bay and slide it away from the computer....hope this helped some....
Kevin
Posted on Jan 31, 2009
Is wd1200jb-00gvc0 hard drive compatible with dell dimension 2400
That is a western Digital Hard drive compatible with most computers even Dell Computers
May 15, 2014 | Dell Dimension 2400 PC Desktop
My disk drive will not open dell Dimension 2400
It may have become disconnected from motherboard or power supply, but that is unlikely if the case has not been opened. It probably is either jammed, or the motor in it has gone out. If this is the case, you can find a fairly cheap replacement online. If you have a disc in the drive that you need to get out, you can use an unfolded paper clip, push it into the tiny hole on the front of the drive until the drive pops open. Manually pull the disc tray out and remove your disc. If it feels like it is off track, and you are up to the task, you can remove the drive, unscrew four screws and take the drive case off, and re-align the drive tray and this may fix your problem.
Jul 21, 2010 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 won't recognize DVD-ROM drive as Boot Device.
Enter the Bios and under System Components find the Boot priority in the Bios and move the drive to the top of the list, also you can press F12 at Start up to select it as well. :)
Apr 14, 2010 | Dell Dimension 2400 PC Desktop
What to do after installing a new hard drive?
Download and install the drivers from support.dell.com
Install them in this order
http://www.fixya.com/support/r4432358-proper_order_install_drivers_dell
Apr 04, 2010 | Dell Dimension 2400 PC Desktop
Dell Dimensions 2400 Primary Drive 0 Not Found
For this problem it only means that the Hard Disk of the computer is not being detected
Try doing the ff:
  • reseat the IDE or SATA cable of the Hard Disk
  • Clean the port where the cable is connected (make sure that the computer is unplug)
  • reboot the computer
  • if problem persist contact computer manufacturer
Hope this will help
Thanks
BYron
Sep 24, 2009 | Dell Dimension 2400 PC Desktop
Does the dell dimension 2400 burn dvds?
Hi budliteman36
Dell Dimension 2400 series will not bur DVD, see the link blow for specifications.
http://reviews.cnet.com/desktops/dell-dimension-2400-pentium/4507-3118_7-30824846.html?tag=mncol;rnav
You can replace the CD-RW drive with a DVD writer. Here is a list od DVD-R-RW writers.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=89&name=DVD-Burners&
Cheers!
Mike
Mar 31, 2009 | Dell Dimension 2400 PC Desktop
Dell dimension 2400 does not recognize cd/dvd drive
Dear Minita,
please follow these steps.
1. Click on START button, the click on RUN
2. Enter REGEDIT and press enter
3. When REGEDIT starts, open up the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325 -11CE-BFC1-08002BE10318}
4. After clicking on {4D36E965-E325 -11CE-BFC1-08002BE10318} you should see two settings on the right-hand side:
"Upperfilters"
"Lowerfilters"
Click on each of them, press DELETE and click YES.
Then close REGEDIT, shutdown & restart your PC
if you still having problem or any other questions, please do not hesitate to contact me.
Many Thanks.
Regards,
AJoshi
Mar 18, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400
Open your dell, remove the cd drive backwards, the cd driver has two green rails where it glides on. Those rails you ned to put back if you replace it with onother driver.
Good luck to you
Dec 18, 2008 | Dell Dimension 2400 PC Desktop
DVD drive bay
yes you should be able to play CD on the DVD reader.
Dimension 2400 have drive slide mounted on the side of the hard drive, cd drive and floppy. they are different for each device. you need the 2 side mount for the dvd. in order to mount them in the Dell.
the drive is inserted from the inside of the box toward the front. The front panel will prevent the device from pop out.
yes, 3 party DVD, CD drive will be shorter and fater that what Dell porvide, but it will work, al long as the opening is accessable.
get the HP DVD driver.
Nov 04, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
Alun Cox
