Question about Canon BJC 8500 InkJet Printer
Printer does not print the photo that is on the screen
I am having trouble optimizing my printer to get the same picture that is on the monitor. The colors are off.
Is there a book I can read or other material that will help me.
4 Suggested Answers
SOURCE: canon pixma mp145
try to make regular photo copies from the printer, if u still get lines then u need to replace the printer because its a hardware issue
Posted on Jun 12, 2008
SOURCE: incorrect color of photos
I found out that Windows Vista (this is what came with my HP laptop) is not compatible with my printer. So, I went to the Canon website and downloaded a driver, and my photos are very clear and of normal color:)
Thanks for checking and your response time was pretty quick.
Karen
Posted on Aug 24, 2008
SOURCE: Printer will not use the magenta color
I had the same problem. It is most likely that your print head nozzles are clogged. Your choices are to attempt to manually clean them, or order a new print head from Canon.
Attempt the manual cleaning at your own risk, this doesn't always work. When it does not work, it means your print head is damaged.
To maually clean the print head. Printer cover up (so you can get to the cartridges and print head). Turn the Printer Off. Remove all the cartridges (I put each cartridge in a separate zip lock bag). Then flip up the lever and remove the print head.
Now heat (don't boil) distilled water (Iused a good sized cook pan and a plastic measuring cup to pour the water). Find a container you can soak the print head in (I used a deep alluminum baking pan). Pour the hot (not boiling) distilled water over the print head molding where the cartridges seat down (hold the printhead over your diposable alluminum pan). Then dunk the molded print head part into the pan numerous times. When the water gets dark change it (be carefuill not to stain the sink). Then slowly pour the hot distilled over the print head (opposite side from where the cartidges seat in). Eventually no ink will be in the water. Set the print head on a dry paper towel, and let it dry for 24 hours or longer. Reinstall the print head, then the catridges. If it worked, your true colors will return. It make take up to 15-20 photos to get all the ink catridges flowing-be patient. You can also just wait 24 hours after re-installing the cartridges, and hopefully it will take less photos to see the correct color match.
Never keep printing when a cartridge is low or out.
Print a few prints every week. Not printing for weeks causes the printheead and the ink flow to clog!
Good luck. I just recovered my S820 and my i900D using the above cleaning method. Like everything else, your mileage may vary! It cost me $1.29 for distilled water and about an hours worth of time!
Posted on Oct 20, 2008
I cannot get an E-size plot to print properly. I have no trouble with plotting D-size drawings. What are the correct settings to use to print E-size sheets?
Printing high quality photos using an inkjet printer is not only possible, but affordable too. Top notch quality relies on a few factors: the right paper, the right ink and the right settings. Read on to find out how to print photos with an inkjet printer.
1.Use a good digital camera. For 4x6 and 8x10 prints, you will want a camera with at least two or three megapixels.
2.Buy photo paper. Spend the extra few dollars to get high-gloss photo paper that is designed for your printer.
3.Use photo ink. High quality photos take high quality ink. Do not use the same ink that you use for documents.
4.Optimize your settings. Select "File > Print" then click "Properties" and find the preferences or quality tab. Set the quality to the highest or choose a photo preset.
5.Edit photos on your computer. Import your photos from a CD or your digital camera. See your camera's manual to find out how.
6.Crop and resize. Cut out anything extra in the background that you do not want and resize the picture so it will fit on the page.
Sep 19, 2011 | Canon iPF700 InkJet Printer
My Canon MP210 never prints photos correctly! The colors come out like the right color but very incorrectly. Basically, the photos all have very severe color management problems. APparently the printer has...
Have you heard of Wysywig? What you see is what you get?
Well on color pictures on you monitor you get wysinwyg what you see is not what you get. Monitors are backlit, so colors are much more vibrant than what a printer can generally deliver. Explore the printing properties of your priinter as there are adjustments that can be made to enable better quality and true to color prints. The paper you use to print out your pics is also important in producing color that is close to original.
When you view your pics on screen try adjusting the color hue to the point it becomes overcolored and try a few experimental prints to see what level of the slide is needed to be used to achieve a brighter more vibrant picture. I would also like to say that the Canon 210 , whilst it is a very good printer, is at the cheaper end of the photo printer scale.
Talk to your ink and paper supplier, they can often show you or recommmend printers that are much higher and more accurate in delivering brighter and true to color photos.
Please rate my help++++Thanks for using FIXYA
Aug 04, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Muddy prints
I have the R2400 and the photo prints look muddy. I have tried the same picture on another printer and the colors are vibrant. Why the muddy pictures on such a nice printer?
Mar 23, 2010 | Epson Stylus Photo R2400 InkJet Printer
There is no Gray, it is Green gray. Photos are not what is seen on screen, Need calibration or something.
The colors on your computer monitor might differ from the device output. Select Screen Match in the Color tab of the printer driver.
For most users, the best method for matching colors on your screen to your printer is to print sRGB colors. The printer uses sRGB and automatically optimizes color output.
Dec 05, 2009 | HP Color LaserJet 2600n Printer
My c65 prints photo all dimmer
Set up a picture with basic squares of colour using a graphics program such as Powerpoint. Print this picture. Does the printed picture look like the picture on the screen. If not, uninstall the printer, reboot, and re-install it. Try again - still no good? You need to get a technician to look at your printer.
If this basic colour check works OK, take a photograph of the printed picture and load it into the computer. Compare it with the original on the screen. The same? No - it's a camera problem - Yes? - OK now print the camera version. Any sign of this dimming? Yes - it's a printer problem - get a technician, as before. No? - I'm baffled why you think you have a problem?
Dec 11, 2008 | Epson Stylus C60 InkJet Printer
R1800 printing way too green/yellow
I had a similar problem with my R800 . I got a colour profiler to fix it and he used a spyder. Made an amazing difference. Well worth the trouble especially if you are printing a lot of photos
jenni U.K.
Nov 22, 2008 | Epson Stylus Photo R300 InkJet Printer
Calibration of monitor
Here's the tip I used years ago on CRT's suffering this same fate.
Take one of your printed photo's and hold it next to the screen (with the same photo on it running in whatever software you want to print from)
Now using the monitors controls, make the monitor look like your photo that you have printed.
Nice and dark now like the photo, good =)
Now adjust the software to what you want it to look like when printed.
Looking good so far..ok
Save those settings in the program. then re adjust the monitor back to how you want it to look normally (as it was before basically)
Not the ideal soloution, but it works and it's free.
Apr 15, 2008 | HP f1905 19" Flat Panel LCD Monitor
Photo paper
1. Never put XtraLife paper from a printer dock in any inkjet printer. This paper is not made for inkjets. The ink will simply spill all over the place.
2. You can use any paper you wish that is inkjet paper but you must set the appropriate settings through the print manager if the paper is anything but Kodak inkjet photo paper. The 5100, 5300, and 5500 all recognize the backprint on the Kodak paper and automatically optimize the settings. Other brands of paper are not optimized in this fashion and therefore must be done manually through the print manager or software.
Mar 30, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Darken print
Read your instruction book its all in there.
We all need to learn how to do these things but sometimes its best just to sit down a read the book for 1 hour or so.
Anyway to make a document or photo print darker;
Go into Printer preferences
Effects
Check the box; Simulate illustration
Then move the contract bar to you setting you require
You have other option in the as well such as;
Vivid photo
Image optimizer
Photo Optimizer pro
Photo Noise Reduction
Jan 26, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon BJC 8500 InkJet Printer Logo
16 people viewed this question
old marine
old marine
