Question about Duravit 001422.00.00 Vario Connector Set for Toilet
My duravit toilet keeps running
My top button duravit toilet keeps running, i cant work out the settings to get the mains to stop flowing into it,
  • 1 more comment
  • peter_ratcli Feb 08, 2009
    DV092010..05
    starck 3 cistern d/flush bot supply bottom LH supply WH.
    This was plumbed in and works correctly apart from the fact that it overflows constantly. It has a few settings inside that i have moved up and down etc. but it seems that the float, does not stop the water rising. Although it rises with the water, once it reaches its setting the water continues to rise and flows out through the overflow, down thru the ,main flush system????
    Hope this helps
  • Anonymous Apr 29, 2009
    My Duravit toilet continues to run, too. It's not a leaky flapper, the shut off float does not seem to stop the water flow even when it has reached it's maximum height.
  • Anonymous Mar 31, 2014
    cant stop toilet flow
I too have had this problem. No matter how i change the settings ..sooner or later the toilet starts to flow continually getting worse and worse. I have had plummers and friends etc see if they can make it stop and it is no better. I am very disapointed with it and will never ever buy Duravit again. I tried contacting them for help and got nowhere. Bad design. Waste of money.. I should have stuck with the old ball-**** system at B&Q.
Posted on Nov 03, 2009
  • 34 Answers
Sounds like the flapper valve on it. Let me know the model number and I can hok you up with more info on it
Posted on Feb 07, 2009
How do I change flapper in cistern
pull the control section from the cistern. Normally they are only press plastic tabs and the whole unit lifts out.
Sep 23, 2014 | Duravit Home
My geberit in-wall toilet won't stop running, and there is no way to access any type of plumbing fixtures to fix. Please help me!
Shut off main water supply
shut off water value going to your wall mounted toilet.
look under your apartment or the room ajoining the wall unit.
look for hidden wall space above unit
Nov 29, 2010 | Duravit 111335001 Geberit In Wall Carrier...
OUr 5 yr old duravit toilet is constantly running. Seems that tank water is seeping into bowl causing the mechanism to demand more water. Onl way to stop is to turn of water valve until we need. Before I...
if you can see the water running in the bowl it's a good chance that the flappers warn http://www.aplumbers.com/residential/toilet
1. tank the tank lid off.2. flush the rubber thing that comes up and allows the water to go to the bowl is the flapper 3. remove 4. replace that should fix it.
problem 2
1. tank tank lid off.2. if the waters flowing over the long tube in the center and down then the water level is too high3. adjust the level either it will have a ball **** or a float in either case   a ball **** adjusts by a screw on the fill valve. the float has a either a metal rod w/ a pinch clamp or a plastic long screw type thing.4. adjust water level .5. barely lift handle to allow a little water out til fill valve kicks on then release handle til valve stops .6. just keep re adjusting til you get the water level right there should be a molded in line for the level on the back of the tank.
Nov 16, 2010 | Duravit Tribeca US-Type Elongated Toilet...
Flush button won't work. 12 yr old Duravit Toilet
The push button siphon assembly is worn out. Just replace it entirely.
May 26, 2010 | Home
After cistern refill outflow into toilet bowl continues to dribble in - and you can see a slight flow into the bowl and every so often we hear the cistern refilling a small amount to compensate.
hi i would suggest your ball valve in the cistern needs ajusting remove the top of the cistern you will see the ajustment screw at the end fo the ball **** arm hope this helps
Nov 15, 2009 | Duravit 0910100005 Happy D Toilet Cistern ...
Cannot remove top of cistern
There are some dual flush cisterns where you have to depress one button to reveal a cavity in the second button. Put a screwdriver in that cavity to lever out the second button, then release the first button and prise that out.
Underneath the buttons is a screw which must be unscrewed to release the cistern lid.
Not sure if this will apply to you... but if not, good luck anyway.
Oct 29, 2009 | Duravit 0910100005 Happy D Toilet Cistern ...
Running water in Geberit Starck Toilet
I hate to say it but you may need a pro on this one, if you want I can try to walk you threw it but let me know. bigslimaba@yahoo.com
Jan 11, 2009 | Duravit Starck 3 Wall Mounted Toilet with...
Duravit 001422.00.00 Vario Connector Set for Toilet Logo
2,353 people viewed this question
Top Duravit Home Experts
Craig Butler
Craig Butler
Paul Carew
Lawrence Oravetz
Are you a Duravit Home Expert? Answer questions, earn points and help others
