Goodman CPB 42 Heat/air packaged unit
The outside unit was staying on all the time and the problem seemed to be the contactor not releasing. I replaced the exact contactor and now the contactor will not connectwhen heat or air is called for - so now the unit will not come on? Is it something Iam missing?
  • david_mitche Jan 31, 2009
    I turned off the power before replacing,it does have a coil and I do have 24v on the contactor. The unit will come on when the contactor is pushed in but will not pull in and stay in when thermostat calls for it.
  • Anonymous Feb 01, 2009
    The contactor will not stay in when pushed in, the coil seems to be OK ie: 26v @ contactor and the wiring looks OK - 16ga and not shorted. The old contactor would pull in when the thermostat called for heat but would not release when cycle was complete. The new contactor is just the opposite. I am currently forcing the contactor in making the unit stay on and controlling the cycle with the unit disconnect.
  • 146 Answers
Did you turn off the air handler when you changed the contactor could have shorted and blown a fuse on the control board. did you get a 24v coil on your contactor. do you have 24v at the contactor when unit is calling. check your wire connections
Posted on Jan 31, 2009
  • mopar440man Feb 01, 2009
    you said that you have 24v at the contactor coil. my question is does the contactor stay in when you have pushed it in. if so sounds like low voltage wires may be to small or to long of a run, wire should be no smaller then 18ga. does your unit have any high or low pressure controls on it. if not and you have power at coil recommend to ohm coil on contactor. may have bad contactor out of the box.
I have a Goodman CPE30-1AB (Outside heat exchanger), with a Goodman (air blower) as well. Air blows inside, but not cold. Outside unit is not turning on at all. Can you please assist?
check your breaker or fuses at outside unit. verify you have 24 volts feeding outside unit replace outside unit contactor if you have the 24 volts and not starting.
Aug 08, 2015 | Goodman Heating & Cooling
Will not come on but emergence heat works
Check contactor that operates compressor and condenser fan. Does it try to come on when you first turn it on, or just sits there? If it tries to come on, it could be the capacitor.
Jan 25, 2014 | Goodman Manufacturing Goodman GPH1348H41...
How to wire high voltage goodman straight a/c package gpc1324 unit with 8kw heat kit
do any one have a old package unit is a goodman i want to see were heater on that package uint or take picture of that unit so i can see where the wire go at the heat
Aug 17, 2012 | Goodman Heating & Cooling
I have a Goodman a/c unit,comes on and runs but no colld air. fins spin and blower doesnt blow cold air. model # ckl 42 - 1.
The first thing I would do is a visual on the capacitor. This time of year with more use the capacitor will swell up and fail. themobilian_2410.jpgthemobilian_2411.jpg
If that is good I would see if the contactor was in tact
Sometimes the smaller wires get broken going outside to the contactor.
May 31, 2011 | Heating & Cooling
My goodman central air unit quit working after a storm. The circuit breaker is not blown. The furnace fan kicks on when ac is turned on at the thermostat but unit outside does not operate. Is there an...
1 posible cause.the thermostat supplies 24 volts to the outside unit to control the contactor if you hear a ligth huming on the outside unit this is the being activated. if this is the case then
check to see if any ants are in or around the unit see video, they will usually climb to dry areas before during or after a storm and for some reason they like the contactor if this is the case cut all power to the unit and clean contactor spray the area around the unit with an insecticide ( not the contactor) replace cover and test unit. Best of Luck. raypena_4.jpg
May 30, 2011 | Goodman Heating & Cooling
I have a goodman furnace and ac unit the fan and heat work but every time i turn the ac on it blows the low voltage fuse ive replaced all low voltage wires to outside unit and thermostat i also replaced...
Look at the contactor on the condensing unit, remove the low voltage wires to the contactor and turn on the system. If the low voltage fuse doesn't blow, replace the contactor.
Jun 24, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman PHJK048 Heat Pump Package
ok...where to start.lol ....the thermostat is just a switch.It will tell the unit to run or not run.if you measure the temp with the heatpump running,the air is warmer than 68 but it feels cool to you because your body is 98.6.The unit will run more often and for longer periods when the temperature drops outside for a few reasons.First,your house has more of a load to heat,meaning you have more heat loss because of the difference in temperatures outside and inside.Second,your heat pump pulls heat from the outside air.The colder the air outside,the less btu's for it to pull.If you have anymore questions hillbuck29@aol.com Hope this helps,Dave
Nov 10, 2008 | Goodman PHKJ048-1 Air Conditioner
Heating & Cooling Logo
91 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
