Question about WYSE S10 (90210501) Network Terminal
Wyse S10 thin client when I connect popup "CETSC"
This is a thin client that was connected to my network and working.
I replaced it with a Wyse V30L and was going to use this in a different app. I "G" the unit and set it up just as I have in the past. When I went to connect RDP a pop up screen comes up.
Remote Desktop Conntection
CETSC and will not connect.
The thin client can ping the server.
Any help would be appriecated. Thanks
  • 9 Answers
SOURCE: network printer through thin print in wyse s10 model
not sure look in the manner
Posted on May 20, 2008
SOURCE: Wyse S30 thin Client with Ubuntu
I played with those a lot with the LTSP and finally made it work...
All in all, the problem is that the X.org cannot autoconfigure the graphic chip of this client. On ubuntu 7.10 you need to force it to use the amd driver and cannot do it from the LTSP.conf file.
In your LTSP.conf file, you have to point to a xorg.conf file specific for your s30 thin client (I called it s30xorg.conf). Then you need to build this xorg.conf file (lots of help on the net on how to do this) and place it in the right folder. (The folder is probably not the same than on my system but it should be pretty obvious or at least written in the manuals or help files where to pu it). In this xorg.conf file, you will need to specify the amd driver and some standard vesa resolutions and refresh rates (also widely availavble on the net). Then dont forget to rebuild your LTSP image with those new files in the tree.
If I remember correctly you will also need to disable the ubuntu splash screen from another config file somewhere... I am sure you will find which one.
Then voila.
Let me know if you can make it work... if what I said is total gebrish, go on reading everythin you can find on the net until you understand what is here.
Thanks
Posted on Dec 04, 2008
SOURCE: How do I enable print screen botton
Depending on what keyboard you use, you may have to press the "F" toggle key to enable print screen.
Posted on Mar 03, 2009
  • 25 Answers
SOURCE: wyse 1200LE - error - out of frequency
This is caused by the terminals default display resolution (or the resolution that it was set to in its previous environment). The easiest way to get a display, would be to use a different monitor with a higher range of supported resolutions.
Fingers crossed the previous wnos.ini file would allow a G-key reset. If so, just hold down the G key when the terminal is booting, and it will reset to factory defaults. This might allow your monitor to work. (I think the default resolution is 800x600)
The problem you have is that the terminal might be locked down via the .ini file. So changing the configuration might be difficult. You could use a program like Wireshark to perform a network trace, this would tell you where the terminal is looking for it its wnos.ini file.
Then you will be able to setup a new wnos.ini on an FTP server set to the IP address(and path) the terminal is looking for, and this will allow you to set your own configuration.
Posted on Jul 07, 2009
SOURCE: Wyse S10 and Windows 2008 Terminal Services
The Wyse S10s require a firmware update to connect to Windows Server 2008. This is due to lack of support for RDP 6.1.
The update I've found to work best is 6.4.0.18.
The only way to get this update is to contact Wyse. However, I have deployed it on numerous clients (our entire base is S10s) and had great success.
Posted on Oct 07, 2009
I have a wyse winterm v30 thin client. what steps will it take in order to reload the firmware?
you can download this pdf guide from
https://support.wyse.com/OA_HTML/cskmbasicsrch.jsp?jttst0=6_23871%2C23871%2C-1%2C0%2C&jtfm0=&etfm1=&jfn=ZG455B66622DEA31A7AE70467E3EBEC537FE9176B1484EFD6E483B952B0ED1CF6F10611204C7B33B20AA233809D7249C41FE&oas=etuN3Cl3pQgYaOxTZDlD7w..&categoryId=10820
this will show you the steps to do a USB firmware upgrade.
Mar 20, 2011 | WYSE Winterm V30 Thin Client - Thin Client...
NIC cards in WYSE R90L machines going bad over time.
Please connect the WYSE R90L machines to a different network switchport and check.
Dec 03, 2010 | WYSE R90LE Thin Client 90952571L Network...
Print Screen on a Thin Client
PrintScreen dont work!
Use the free program, ex. Gadwin PrintScreen
Jun 30, 2009 | WYSE S10 (90210501) Network Terminal
Thin Clients Have a Problem Connecting After Activating Licensing
Try using the command "fixlicense=clean" (think thats how its spelt, check with Wyse) in the wnos.ini.
See if this allows the terminals to relinquish any old TS cal and pickup a new one from your licensing server.
Jun 16, 2009 | WYSE S10 (90210501) Network Terminal
WYSE S10 thin clients; we are hearing from users that when they hit the power button, the unit restarts instead. This behavior is also present using the gui interface. Not all units are doing this, but we...
Check in the BIOS, "Fireport" is the password. I cant remember if the power button behavior is set there or in the wnos.ini file.
You can check the config generator on technicalhelp.de to see if the command is in there for the wnos.ini
Apr 07, 2009 | WYSE S10 (90210501) Network Terminal
Feb 19, 2009 | WYSE S10 (90210501) Network Terminal
Nov 12, 2008 | WYSE S10 (90210501) Network Terminal
WYSE S10 (90210501) Network Terminal Logo
423 people viewed this question
Top WYSE Computers & Internet Experts
Nicholas Bannister
Sunday Ojelabi
Sunday Ojelabi
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
