Question about Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator
Looking for the manual for a kenmore elite 73503
Just purchased a used kenmore elite 73503, but I don't have a manual and all the doors are off.  It also looks like a door hinge is missing and I will need to know where to purchase one.
Thank you very much.
  • 15,935 Answers
Head over to the manufacture's website. www.searspartsdirect.com
You enter your full model number in, and you can see parts and expanded diagrams of your unit.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
I have a Kenmore elite model #32623 790.3262 . Nothing was done ,no cleaning not even used. came home to DOOR OPN on indicator screen.
Hello. If the door hinges are weak due to wear, they might not be holding the door tightly enough prevent the switch from activating and signaling the door is open. If you pushed the door closed and the indication went away, the springs are probably too worn. The part number for the hinges is 139014301 and you will need to purchase two of them. If the door switch itself is defective, then the part number needed is 316445501. I hope I helped you!
Sep 25, 2015 | Kenmore Kitchen Ranges
Kenmore elite 106.44423603 ice/water dispenser housing - plastic broken off for ice door pin hinge. Any ideas for a fix?
Hi and thanks for using fixya!
There is actually a "kit" that replaces the hinge, housing for the hinge, dispenser door and bracket. Just be sure when you're taking everything apart you pay special attention to how it goes back together. Kit comes with metal bracket that will replace old housing. Now that I think about it the kit comes with instructions! Kit pt# 8201756 and you can purchase it here. Appliance Parts
Feb 04, 2015 | Kenmore Refrigerators
How do you remove the door from a 2009 kenmore elite refrigerator
Look for the hinges and remove any bolts you see depress the hinges to release the hinges because they will have a hinge tab to hold them in place
Feb 03, 2015 | Kenmore Refrigerators
I have a sears kenmore elite refrigerator. It is a side by side. The doors don't line up when closed. The freezer side is about 1/4" higher. It looks funny when closed.
there are plastic spacers located at the hinge on the bottom of these units, and they break after wear and tear , they are also beveled so they help the door close,, check to see if yours are in good order, if not you'll have to replace them,, to do this you remove the top hinge,, its just a couple of screws that hold the hinge on under the plastic deco cap ,, once you've done that Lift the door off the lower hinge,, install the spacers, and place the top hinge back once the door is reset
Aug 25, 2011 | Kenmore Side by Side Refrigerator
I have a Kenmore Elite Model 106.57863801 side by side stainless steel fridge. The doors squeak when opening and closing. How can I remedy this?
Good day,
Spraying a good lubricant on the hinge pins should solve your problem. Sprays like WD-40 shouldn't be used because they may come in contact with your food.
I suggest you call around to your local appliance parts houses to see which one's carry a "food compatable" spray.
It's safe to use around food and can be saved for future use. Most service techs I know carry it with them in the service truck to use when needed.
Oct 05, 2010 | Kenmore 73503 Stainless Steel Bottom...
1 year old Kenmore Elite Trio Refridgerator not cooling
There are a lot of things that could be the source of the problem... is there no cooling at all going on in the freezer? Is the back wall of the freezer cold? It could be anything from a fan, to the compressor, to the control board... you need a technician.
I would get on the phone with Sears, and explain the continuing problems you have been having, and they may agree to cover service.
Jul 26, 2009 | Kenmore 73503 Stainless Steel Bottom...
Range door will not seal properly.
Place a hammer handle between the door and the frame at the hinges..
Push on the door, carefully.
This usually works to re-seat the door hinges.
Mar 08, 2009 | Kenmore Kitchen Ranges
Kenmore oven model# 790.79383401 door not closing
Do the hinges come out with the door or does the door slip off the hinges? If the hinges are on the door then there is no adjustment if not there should be an adjustment but you may have to pull the range out to properly adjust if it is a built in range. Also check the door lock.
Jan 15, 2008 | Ovens
Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator Logo
217 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
