Question about Samsung NV24 HD Digital Camera
IS it possible to make the samsung nv24hd into a webcam?
If so how can i do this?
How do you connect your samsung galaxy 7 inch tab 3 to the tv
Hi! Yes it is possible if your TV is HDMI capable and you have the galaxy 7 HDMI adapter. You can refer the supplier you have bought from to check availability. Goodluck!
Mar 08, 2014 | Samsung Galaxy Tab 7.0 Plus 7 inch Tablet...
I am unable to start my Webcam. It is showing Skype cannot connect to your webcam. Also while using cyberlink it is showing error. My laptop is Samsung R480. Win7
I am glad to HELP YOU!
Is it possible to get such errors because the webcam driver is outdated. A list of ALL YOUR DRIVERS on that Samsung R480 can be found HERE. Just get the driver for your webcam and it can be found under the SECOND LINK to right, marked DRIVERS [click on it].
As to START YOUR WEBCAM all you have to do is:
# START > ALL PROGRAMS and there you have to see a program called CYBERLINK YOUCAM
# click on it
# register by following the instructions [you will need a NAME and an E-MAIL ADDRESS]
# follow the rest of the instructions after the registration and from now on your webcam should be UP and RUNNING!
GOOD LUCK!
... and don't forget to RATE...
Apr 18, 2011 | Computers & Internet
What do you do if you've got a Samsung NV24hd camera and your new Windows 7 computer is not compatible? Samsung tech support says there's no Windows 7 driver...
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Nov 01, 2010 | Samsung NV24 HD Digital Camera
Simple instructions for Samsung NV24HD
You can download an "easy manual" or a full manual from this page.
Oct 31, 2010 | Cameras
I have no driver for pleomax pc camera
http://xpdrivers.com/camera/_1_4.cfm
The link below is for samsung cameras but it is a general driver fr all camera under samsung and i believe that pleomax is a product of samsung.
Download the files and install it and if it doesn't work notify me as soon as possible and we will post another link from the same site. We'll just have to include the specific driver you're looking for.
Thank you and have a great day.
Mar 19, 2010 | PC Concepts 300K Webcam
I have samsung nv24hd and when i turn it on he beeps three times and turns off but i can watch pictures on it and he shows that battery is full.Thanks
Your problem may be due to a weak/worn out battery or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your battery may need to be replaced, or the camera may have a problem that requires professional repair.
If this response helps, please post a rating for me. A rating of "Very Helpful" would be appreciated . .
Dec 02, 2009 | Samsung NV24 HD Digital Camera
Does the rechargable batter go bad? I have a
Yes, rechargeable batteries can go bad. You should try using a separate card reader to download your pictures...solves a lot of problems. Try cleaning the battery contacts in the camera with a cotton swab lightly dampened with rubbing alcohol.
Sep 04, 2009 | Samsung NV24 HD Digital Camera
NV24HD - recording videos. I´m using a 16 gb SDHC Adata Turbo Memory Card. I´m having problems recordings videos (1280 x 720, 30 fps). After recording, watching the video, the images goes on ok, but the...
hi all i know is that with samsungs if u try to zoom whilst using video mode the sound will cut out it is not a fault its just the way samsung made it 2 be. Hope it helps
Apr 05, 2009 | Samsung NV24 HD Digital Camera
NV24HD settings problem
go to menu-setup/settings-date time
then change it
Jan 05, 2009 | Samsung NV24 HD Digital Camera
Samsung pleomax pwc2100 webcam driver
Try driverguide.com search by make and model.
Jul 02, 2008 | Toshiba Satellite 2450-401 Notebook
Samsung NV24 HD Digital Camera Logo
418 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
