Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
Have aair plus extre,e g router. 2nd computer is 30 feet away with nothing but, open air between, a few stairs and a minor corner. Signal is poor. How can this be improved
  • 31 Answers
Please call dlink tech support at 877-453-5465. just an advise on how to handle the call when you reach dlink tech support (agent); do not agree to call back after you troubleshoot with them (they'll be giving you a case id reference# and be advising you to check your pc or call "who" and call them back to continue the troubleshooting). insist to the agent that he need to resolve the problem asap (by the way, agents are not allowed to drop the call or they'll be dead-history!). and if the agent still insisted you to call back, ask for a "senior level technician" to finish the job (escalate the problem).
fyi: dlink tech support handling time to resolve a call is 15 to 18 minutes only. if you reach that 15-18 minutes (max) time the agent will think of a way for you to call back (advising you to check with your pc manufacturer, check with your ISP, call microsoft to update your software, etc... non-sense!) they need to do this in order to reach their handling time (agents need to reach 21 to 25 billable calls, and billable calls are "solution provided", "resolved", and "dropped call"). ---- believe me, i was one of them and repented.
Posted on Mar 14, 2009
Tablet can not connect to wi-fi
Try "forget network" and reconnecting.
Dec 06, 2013 | Samsung Galaxy Note 10.1"
Connect to network wirelessly with in 20 feet when go down to second floor network indicates no internet , but it can find router , run network trouble shooter but not much , dell has not helped ...
Signal is either too weak or something is causing it to drop out.You can try a reboot of the router.
If this doesnt work then you may need to get a wireless switch to pick up the signal from the first floor to the second.Which will need to be located in an open area like stairs.Metal decking and flouresent lights can cause the signal to drop.
Or you can buy a cable and hardwire it.Or a stronger router with a better signal.
Nov 02, 2010 | Dell Vostro 1014 Laptop Computer
It seems that the signal is strong next to the router, but drops to 1 bar within 30 feet away? What is the most likely solution.
Routers generally have a strong signal for up to 10 meters. However no obstacles should be in the way. 30 feets is about 10 meters so the router is loosing its signal strength. If you would like to extend the strength of your router you can buy a range expander. This device acts as a repeater of the signal so from 10 meters you can go to 15 or 20 meters.
Mar 08, 2010 | Hawking Hi-Gain 802.11g MIMO Wireless...
I lose the signal from my 2300 if I move past 30 feet away from it. What can I do to increase the signal distance?
Things that will affect the range on a Wireless router signal are signal strength, and a big factor to this is the antenna you use. The small antenna that comes with the router normally offers around "Up to 100m" indoors and "Up to 450m" outdoors (open range) range, router to computer, and replacing this antenna with a higher gain directional antenna pointed towards your laptop would normally be a way to improve this signal. Router login involves using web browser and going to and login is admin as well as the password of admin ... unless you have changed it! At any rate, if all antennas are correctly attached the router to computer distance would not be a problem. Check antenna connection, replace if all secure and still have low signal strength. Please let me know the outcome of the repair efforts? Thank you.
Dec 14, 2009 | Dell TrueMobile 2300 Wireless Broadband...
Belkin wirless router lose signal after approx. 30
Check the wireless channel on the router.
Is it properly set ?
you can try changing the wireless channel on the router.
Or if that doesn't work then you can try to upgrade the firmware of the router.
for this you will need to open the set up interface of the router.
Click Here to know more about routers
Oct 26, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
It does not seem to have much range. 30 feet
typically 30 ft is the longest a wifi router can reach in the line of sight, you can inprove the range with a larger antenna on each end. I hope this helps-
Oct 04, 2009 | Computers & Internet
I have a DI-524 Air Plus G Router and would like to send signal to a location 350 feet away in another building. Is this possible? Currently I can receive a very weak signal, but not strong enough to...
not without a repeater or maybe outside antenna. then the signal would probally be too low. you are working too far for wirless and thru building walls.
Jul 07, 2009 | D-Link AirPlus DI-524 Wireless Router
My adapter isn't getting a signal from like 5 feet
you should search for wireless in the console or its the problem with your wireless router
Mar 04, 2009 | Microsoft Xbox 360 Console
Check the signal using a different computer, cell phone or game console. If the signal is OK, it is not a problem with the router.
Dropping these units can break the antennas, check for obvious damage, check the orientation (angle). If it looks bent, it may be broken. Sometimes cracks will occur where he connector is soldered to the circuit board. Open the case, retouch the solder connections, with a properly sized soldering iron. Some antennas are removeable, some are not, they all should read continuity if checked with a ohmmeter.
Oct 17, 2008 | Dynex DX-E401 Router
I too am a gamer, it is not only important to have your connection be reliable and consistant speeds, but to have the game set up properly, full upload and download speeds set as default for in game. I would recommend getting a cat5 cable from the store and getting rid of wireless for the gaming computer. Try visiting some of the speedtest sites, depending on where you live you should try just click on the location closest to you, try it a few times, see if the speeds are what your paying for. check your bill or call your internet service provider and ask them what your paying for, if your not getting what you paid for most of the time you can negotiate the amount you pay for the next few months. most of the time free. As well as set up a tech to visit your house to make the signal frequency for the desired speeds.
Nov 12, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
51 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
