Question about Cobra 19 DX III 40-Channels Base CB Radio
President mckinly ssb/am model with mb8719 pll chip.
Fault finding need help..transmitt carier on am normal 4 watts no modulation on am and no modulation on ssb usb/lsb.receive is alright.checked mic insert -inside mic etc and other end mic plug all ok their.
  • ric adam Aug 03, 2007
    fuyt back .found predriver 2sc1906 was blown replaced with 2sc1966.final ok.noticed now that the final and driver had 13 volts readings on the base .when switching mode switch am should read 5.50 volts when switch mode switch usb/lsb should read 13.75 volts.checking tr41 dc reg transister also tr42dc reg transister end of press i will be back ......
    fuyt back tonight 11.20pm been in the garage working on the cb radio put back ic6 found that i could hear my modulation my voice on all modes lsb/usb/am connected another cb radio besides the president radio .mod was low not even moving the needle but i could hear myself looked inside cb again from the mic gain control 2 wires going into the amp stage tr 29 was a bc 458 this did not look right and while touching the legs with my fingers my modulation increased and the watt meter started too peek up.took out tr29 and replaced with a bc945 and wow modulation now on all mode lsb/usb/am.same probem with another cb cobra 148 my friend wanted fixed.my other email is [email protected] cobra cb radios .
    Genius:
  • 1,139 Answers
It looks like you had some loose connections in that CB. you may want to also check for other cold solder joints throughout the units and touch them up with some solder. Might I suggest you use a desoldering tool and then just add new solder to the connection.
Posted on Sep 05, 2007
SOURCE:
My hr2600 shows error 3 when it is keyed up and does not transmit
0 = Transmitter Timeout timer has timed-out
1 = Transmit Frequency is lower than TX Lockout Lower Limit
2 = Transmit Frequency is greater than TX Lockout Higher Limit
3 = Phase-locked-loop (PLL) won't lock at this transmit frequency
4 = PLL is intermittently coming out of lock during transmit
*If your radio displays error 3 or 4, don't keep trying to transmit on this frequency. The cause of the problem could be low power supply voltage to the radio or the radio's VCO loop needs adjustment. Refer to a qualified technician for service. Contact the installer of the chip first. If, however, you installed the chip yourself, contact a qualified technician for service.
Sep 24, 2013 | Magnum DeltaForce CB Radio
Adjust modulation pot cb
4 watts on am and 12 on ssb the modulation pot isn't going to help you . go to www.cbtricks.com and get the service manual.
Jul 27, 2013 | Galaxy Radios DX-979 40-Channels Base CB...
How do i adjust the sideband
Instructions
Connect one end of your coaxial cable to the output port on your SSB Transmitter. Connect the other end of the cable to the coaxial input port on your RF demodulator.
Connect one end of your 1/4 inch audio cable to the audio output port on your RF modulator. Connect the other end of the audio cable to the audio input jack on your amplifier.
Turn on your SSB transmitter, RF modulator and amplifier. Adjust your SSB transmitter modulation by adjusting the knob on your RF
Jul 22, 2012 | Ranger RCI-6900F-25 CB Radio
Uniden president ssb base no transmit and no receive how to fix
Have the mic checked first to make sure wired correctly and or wires not broken where connect to plug----also check to see if same on SSB and Am.
President what? Madison, Lincoln etc.
Apr 23, 2012 | Radio Communications
Just want to know if i should use my ll203 amp in am or ssb mode when running with a cobra CB radio?
What radio?? Does it have single side band(SSB)? If not, then don't use SSB.
AM - amplitude modulation
SSB - single side band.
If you have SSB, there would be a switch on it to transmit in SSB. If not, it is AM only.
Second, Has this radio been worked on to be able to run on an amp? If not, you will blow the amp.
A CB radio transmits dead keys with 4 watts of power, and transmits with 4 watts of audio.
a 4 watt dead key is too much for a linear amp. You will smoke the transistors. Also, 4 watts of audio is not enough to drive it properly. You won't get full power.
The dead key needs to be around 2 to 2 -1/2 watts,or what ever makes the linear dead key half its peak wattage., and the modulation (audio) turned up all the way.
It doesn't sound like you know too much about CB radio's. Not a big deal, you can learn. For right now you may want to take it to a cb shop and tell them you want a peak and tune, and set up to run a linear.
You can find CB shops usually at truck stops. Some area's they are other places. Check the internet for local shops.
Oct 31, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
No modulation in AAM only mode. Needing a schematic.
if the transmitter produces power output with modulation on SSB but NOT ON AM then the AM Pass Regulator is defective, more times than not.
May 24, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
148gtl, Taiwan when you modulate the meter swings backwards
In the back is where power mods have been added...It sounds like a swing kit 1/2 watt deadkey to 25 watts which is a powerful modulation exceeding 100%. Its a 220uf capacitor in place of a jumper J1 or J(x) J something in some radios. if you replace the jumper and remove the capacitor 220uf or 470uf one.(near finals it will return to around 4 watt dead key) The result of 4 watts is modulation is flat;where if you adjust it to 2 1/4 watt to say 20 watts it will be very loud and modulation is at 100%.
Dec 07, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Cobrba 148 gtl TX
Thanks sharcnet i just going through the steps in my head trying to figure out what I would do if it was on my bench ..Between the two of us we'll figure it out!!!..... Dean
Feb 01, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 19 DX III 40-Channels Base CB Radio Logo
503 people viewed this question
Top Cobra Radio Communications Experts
Steve Allison
Steve Allison
Chris
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
