You will need: A clip. Open out the clip. find the tiny reset hole (see photo). Note that this is often not the tagged 'reset' button on the rear of the tablet. tablet must be be off (and a minimum of five hundredth charged) at this time.
http://screencast.com/t/bm5WvA0cWIP The clip is used to activate the button in this little hole; you may hear and feel a click of the within button, in but 15mm of insertion. don`t force unduly! 1. Insert clip, till you hear the clicking of the button. Keep clip inserted, and press and hold the black power button.
2. In . ten seconds the blue PROSCAN screen will be displayed. still keep black power button on hold, and unleash clip.
3. some seconds later you may see an android 'guy' lying on his back with belly open, and a red triangle (with !) image hovering higher than his belly. unleash power button. this means we are on the point of having the ability to interrupt things. Note that once a second more or less, if no more action is taken, the tablet can shut off, then be restarted normally.
4. Press and hold power button. Insert and take away clip. you may see a screen titled android system recovery. (Note that recurrent insertion of the clip can alternate the show of the Recovery menu). unleash power button.
http://screencast.com/t/TSnhaLpk2kE
5. Use clip to scroll down the list of choices. To reset the tablet, choose wipe data/factory reset. Press power button to confirm the choice. (If you go past the specified choice, carry on clicking, because the choice can scroll back to the highest once at the bottom).
6. Once reset has been designated, you`re currently at the final chance to back out or commit. All the menu things, aside from one are tagged No. To verify the reset, choose yes - delete all user data then press power button.
http://screencast.com/t/0fuyMFYR
7. The wiping method starts, and after a couple of seconds will complete.
8. Menu choice bring up system currently should be highlighted. Press power button to choose.
I beleive i have the same problem, when using my pen randomly it clicks and holds and takes several minutes to stop. Also the eraser works fine, its just the pen tip.. its really annoying, and i hope there's a solution.
same here dude :((
Same here. Eraser will work, but not the nib.
Any solutions?
Yep its the same thing for me. The tapping didn't work either. I've only had my tablet for a year. I wonder if the warranty still covers it..
neither my pen nib or eraser part is working on my bamboo fun.. its rubbish, it used to work fine, well the eraser never used to work in the first place.heeellp
