Question about Maytag SAV5710 Top Load Washer
Belt Tension How do you thighten the belt on a Maytag MAH5500BWW?
If you are sure the belt is slipping, you need to replace the belt. Mine was making a growling noise that sounded like it might have been a slipping belt but it turned out to be a motor drive problem. I fixed mine with a motor/control board kit (ebay) for $155.00. However, there was a note with the kit that indicated that the symptom on that particular model might have been simply a bad cable connection at the motor end of the cable. The wire lugs are crimped-on in the motor connector and could work loose - the motor jumps around quite a lot during spin start-up...
Posted on Feb 16, 2009
Belt drive for mah5500bww year 2000 style 47909216
You can try obtaining the part either from Maytag or an appliance parts supplier
Oct 20, 2013 | Maytag Neptune MAH5500B Front Load Washer
Belt tension too loose
the typical tensioner should be able to be bent a little to tighten up the tension
Sep 27, 2012 | Maytag Parts Maytag 801429 Dryer MAYTAG 30...
So this is the first time I'm trying to do work on my car so I figured the belts are the best place to start, but one problem where are they located? I am trying to change the two belts known as my...
When you pop the hood the belts are to the leftside.you will need to remove the pass/side fender cover to see lower part of belts, heres a diagram to help you remove and install belts correctly, loosen bolts A-B to remove the ac/ alt belt loosen A a few turn and B is what releases tension as you turn it, after you tighten the belt then you will tighten A bolt, same with the other belt you loosen C-D bolts a few turns then loosen E to release the tension on the belt then install new belt and thighten bolt E after the belt is tight then tighten C-D bolts, hope this helps. good luck.dis regaurd the wiring diagram,1561ac9.gif0a0a47b.gif
Oct 09, 2010 | 2006 Nissan Murano
How to replace the belt on the Maytag Neptune FAV6800AAW?
See if my Clutch Fix post will help. I also have links to Service Manual which will be big help. The drive belt can be walked on the Clutch Pulley but it is a very snug fit even with the drive belt tension bolt loosened. Watch you fingers as you walk the drive belt onto the clutch pulley….Rich
Apr 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH5500BWW burn smell (doesn't appear to be hose)
if you have a maytag neptune washer that ran up until now you got your money's worth,that's the machine that put maytag out of business,if it's smoking and ripping the boot it sounds like the tub bearing is gone and you'll have to replace the washer,if it's load in the spin like marbles are rolling around in it that's the problem,but i wouldn't put a cent into that machine.
Oct 06, 2017 | Maytag Washing Machines
Very loud spin cycle
The link below, courtesy of www.repairclinic.com, shows that the rear bearing comes with the outer tub only and is very pricey! I have been unable to find a service agency that offers just the bearing. Very aggravating. www.maytag.com would be a good place to define your issue.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MAH5500BWW-%3d%3di1119942&PartID=1119942
Jul 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Belt installation for a maytag dryer model# sde305day
Usally put dryer belt around the drum first
then around motor the tensioner pulley has to to be pulled up when you do this to get the belt around tensioner then you release the tensioner pulley to put tension on belt
Jun 18, 2009 | Maytag PYE2300AY Electric Dryer
Drum belt tension
I found a dryer manual on the web that showed how the drum belt wrapped around the pulleys.
Problem solved.
May 11, 2009 | Maytag Dryers
Belt slipping off of pully on maytag neptune mah5500bww
I loosed the moter and the belt is staying on. However, my belt is cutting the tub when the belt is moving off the pully.
Apr 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Replacing maytag dryer belt
looking at the back of the motor where the belt pulley is you would grasp belt coming down from the left side of drum then come across the top of belt pulley that is on motor shaft going clockwise around that pulley then continue back to your left and over the top of belt tension pulley going counterclockwise around that pulley this is when you will have to raise pulley against spring pressure to get belt on then release belt tension pulley make sure that belt is still in belt groove on the drum hope this helps ed
Feb 28, 2008 | Dryers
Maytag SAV5710 Top Load Washer Logo
83 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
