Question about Singer CE-100 Futura Computerized Sewing Machine
Singer Futura CE 150 machine -carriage won't move to standby pos.
My machine is less than a month old and i think it is broken.
The carriage does not automatically move to the standby position when the machine is turned on nor will the futura software 'transmit design to the machine'..... The connection in the machine part (where ebroidery unit connects to machine) wiggles- it a little loose. Is this normal? The unit is not an easy fit into the machine- a very poor design.
  • janbwilliams Feb 12, 2009
    There was a problem w/ the connection of the embroidery unit and machine. It has been fixed under the warranty and is now working well. It is much easier to attach the unit to the machine- it was NOT a good fit previously.
SOURCE: Singer futura ce-200 problem, pattern mis-alignment
I have had similar problems in the past.
Do you hear a noise from the embroidery unit when the misalignment occurs ? If so, I suspect that your issue may be that you have some resistance under the hoop. Is there extra material that may be rubbing on the machine or catching somewhere. I have found that if I use some masking tape to keep all of the extra material from hitting any other parts of the machine or dragging under the edge of the hoop this error does not occur. FYI: I also stopped using the "optimize stitch speed" option at the same time. I believe that material dragging was causing the problem, but I still wonder about the stitch speed optimization feature.
Posted on Jul 20, 2008
  • 64 Answers
SOURCE: My Singer Futura CE-250 keeps giving me an error
"PC" symbols on the machine panel if it is not connected to PC and switched on is a normal behaviour.
As for communication failure try to remember whether something on your pc has been changed: windows upgrade, machine got connected to another usb port etc. If any of such changes have been made try to reinstall Futura software. Otherwise launch troubleshooting utility and send its report to futura-support.
Posted on Nov 14, 2009
  • 64 Answers
SOURCE: Singer futura CE-350 software/ drivers will not load up.
There is a troubleshooting utility in your Futura folder. Launch it and send its report to futura-support.
Posted on Nov 15, 2009
SOURCE: Singer Futura 250 under XP - embroidery unit won't move
Could one of you send me a copy of the Futura installation software? I can't find mine and can't use my machine to embroider! Help!
Posted on Dec 10, 2009
  • 64 Answers
SOURCE: Singer CE-150 Futura can not locate driver
Most probably you have a pc with Windows 7 or Windows Vista/XP 64 bit that are supported since latest Futura software versions. For 64bit support you will need a version 3.0.0.7 and higher, for WIndows 7 support a latest update 3.0.0.9
http://www.futura-support.com/downloads/ce150.html
Posted on Feb 20, 2010
My xl400 singer embroidery carriage has stopped working. Will not move at all when machine is turned on. Also keep getting msg error about hoop size but no hoop attached.
The switch for "sew" or "embroidery" must first be in the "embroidery" position.
Make sure the connections are very firmly pushed in.
If it still isn't functional it may require some small motors to be replaced. The motors are what makes the hoop move.
Sep 28, 2016 | Singer Futura Xl-400 All-In-One Sewing And...
Why cant i install futura ce 150 softwRE with windows 10?
Singer Futura CE-150, I NEED HELP!!! - FreeEmbroideryStuff ...
freeembroiderystuff.embroiderydesigns.com/forums/threadView.aspx?id...
Jul 11, 2014 - 15 posts - ‎10 authors
I just got the Singer Futura CE-150 and every time I start a design it ... Posts: 2/10/2014 11:18:44 PM, RE: Singer Futura CE-150, I NEED ... Futura CE-100but didn't realize it didn't have its original install cd with ... I can't afford Singers price. ... -Software-Download-and-Installation_A287.aspx?id=287&siteid= ...
Singer futura ce-350 software download - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesJavaScript isn't enabled in your browser, so this file can't be opened. Enable and reload. ... Singer futura ce 150 embroidery machine 3900 designs dvd. Top 3 singer ... Singerfutura software for windows 10 memphis soft portal. Using my singer ... Singer futura software installation for windows 2000 xp youtube. Service ...
Singer Futura CE-250 Sewing and Embroidery Machine w
SINGER® FUTURA™ Software Installation for Windows ...? 7:20https://www.youtube.com/watch?v=RDkHyrh0ejkNov 30, 2009 - Uploaded by SingerSewingCompanySINGER® FUTURA™ Software Installation for Windows 2000 & XP ... yes i already have a singer ...Singer Futura will not work with Windows 7 - Microsoft Communityanswers.microsoft.com/.../singer-futura.../da1ea4db-8594-4a12-91d1-d8...I bought a Singer Futura sewing machine and a Win 7 laptop for Christmas. ... can find the right person at Singer to talk to they might let you have a pre-release version of thesoftware. ... What if you download the patch and it still doesn't work? ... if you are using ce-150 go to http://futura-support.com/downloads/ce150.html.
Dec 30, 2015 | Sewing Machines
Carriage frozen, just had it completely serviced. Started to make my second swatch, the carriage stopped and seems frozen in place, checked alternate yard, it was caught on underside of plastic wheel of...
Where it just got fixed and I know that it costs to ship even just the carriage out but have you contacted the person that fixed it and told them it is still faulting?
But first there should be a switch on the carriage that lifts the cover up so that you can move it to unjam the carriage, then put the sinker plate back on and try it again.
Seeing that you have a singer type machine, here is a video
that shows how to take those covers off. But you should also be able to see part of the sub drum from the underside as well and may not need to take the cover off.
You may also take a hair dryer to the drum and underside of the carriage to heat up any congealed grease but if you just had it refurbished (was it just the carriage or the whole machine sent out?) to see if that helps.
I am sure the service person lubricated the machine but you should ask to make sure and if not, you need to lubricate it as well. Same goes with the sponge bar, that tends to be the one thing that causes most problems with any machine.
Hope these help and if not, maybe I will see that it hasn't and be back.
Roberta Kelley
May 23, 2014 | Sewing Machines
Board
Close your futura file & exit, switch off your futura machine. Disconnect the embroidery unit from the machine,move the hoop carriage a bit to the left then to the right & it should be able to move. Connect back embroidery unit to your futura machine,ensuring the connecting point click properly. Re thread the machine & ensure needle is fully up position. Now you switch on the machine, you will see hoop carriage moving and stop at its zero point. If that is OK and the earlier led blinking gone, you should be able to operate the futura embroidery program again.
Jul 18, 2013 | Singer CE-200 Quantum Futura Computerized...
My Bernina deco 340 embroidery carriage is out of line
sounds like something isn't installed correctly or is broken.
Sep 07, 2012 | Bernina Sewing Machines
Embroidery machine is making grinding noise and carriage doesn't move. Then, screen says malfuntion, turn machine off.
Just because the hoop holder has been moved during transportation. Shut down the machine, manually bring hoop holder in central position in both X and Y, it will restart.
Apr 20, 2012 | Brother PE770 Computerized Sewing Machine
My futura ce-100 keeps beebing and it lights up. it stops working and will not move on. how do i fix this.
Check the threading, especially in the clear plastic tension race at the top back of the machine. This is the part where the machine checks the thread is moving. If the thread breaks, or is not running correctly through that area, the machine thinks the thread is broken/run out and stops.
Nov 16, 2010 | Singer CE-100 Futura Computerized Sewing...
Will Mac run Singer® Futura
The software doesn't run on MAC. And you can't get a download directly off the internet, at least not anywhere that I've found. When I couldn't find my disk a few months ago all of my research told me that I had to purchase a replacement CD from Singer.
Nov 07, 2010 | Singer CE-100 Futura Computerized Sewing...
I have a Futura Ce-150. Do I need special
List of supported by Futura software design formats could be found in the software manual or on futura-support site:
http://www.futura-support.com/futuraSw/embformats.htm
Feb 06, 2010 | Singer CE-100 Futura Computerized Sewing...
My futura ce200 is driving me insane because i have the small hoop selected on the computer but the machine thinks that the large hoop is selected. How do i fix it??
Before attaching small hoop, turn on power switch to
move the carriage to embroidering standby position, and
turn off power switch.
check troubleshooting in manual
user manual link
http://www.futura-support.com/files/CE200-Eng_Fre_Spa040607.pdf
hope this helps and you get it working soon =)
Feb 05, 2010 | Singer CE-200 Quantum Futura Computerized...
Singer CE-100 Futura Computerized Sewing Machine Logo
215 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
