my dvd player is jammed and it does not allow me to eject the dvd. the dvd is inside and after I hit eject it keeps the dvd inside and starts loading again after a few second. I have tried shuting off and on. I also pluged it out and let a few days pass but it did not work. it is also impossible to force it out by hand.
-   My DVD has been stuck inside for 2 years. There is no pinhole. There is no way to remove it that anyone has suggested. I've tried unplugging, hitting multiple remote button combinations. It's dead and it won't come out.-   Guest
Using a small needle their should be a hole in the front. This is the safety eject hole that will open the drive 99% of the time. Replacing the drive is just as easy. remove the few screws on the bottom of the laptop nearest the drive and grasp ahold of the bay and slide it away from the computer....hope this helped some.... Kevin
Comments:
Feb 01, 2009
- OOPPSSS this was for a laptop...sorry....but you may have to take the dvd player apart to manually open the drive....a few screws on the bottom that have arrows pointing toward them and please be careful, their is a ribbon cable attached to the front that is very delicate. Hopefully you will be able to manually slide the railopenonce it is exposed and as always do this with the unit un plugged.
Now if this is stated to be a combo tv/dvd ignore the screw removal and they should be on the back of the set , about 4, one in each corner. Hope this helped a little. i had to to the same thing on one that did not have a eject safety hole in the front....
take care
kevin
When we turn on our tv it will turn off about 5 sec later. We have to repeat this step about 10...
(More)
When we turn on our tv it will turn off about 5 sec later. We have to repeat this step about 10 times and than it will stay on. What can we do to fix this problem
our tv has sound but will not light up. the power switch went out and we have used the one in the...
(More)
our tv has sound but will not light up. the power switch went out and we have used the one in the back to activate power. Help
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
