Question about Prosonic PDS-758LP Car Video Player
No power to car DVD player or monitor, lights work
Okay, I have a question for you. It's actually a Provision flip-down car monitor, I have no idea what model number. I couldn't find that brand on this site, so I just picked one that sounded similar. Anyway, we have had this DVD player in the car since we bought it (used), but never tried using it until our daughter hit 17 months and became interested in videos. It is a flip-down style monitor that supposedly connects to a PS2 over the glove compartment. I cannot get the screen or the PS2 to power-up. I would like to avoid taking this to a repair shop, if possible, since we really can't afford to do that. I did some reading online and think that maybe the systems are wired into the car battery or electrical components somehow. When I raised the hood, on the positive side of the battery there is a large red plastic thing that covers some other wires, that I haven't noticed on car batteries before... Not sure if that's significant. I tried shaking the wires by the glove compartment to see if I could see what they hooked up to, but nothing seemed affected. It looks like they go into the area behind the radio. Tomorrow I was thinking about taking the glove compartment off completely for a better look, if possible, but am desperate for some insight--even if it's just to tell me that this is a lost cause. One other thing that I thought was odd is that the car interior lights attach directly to the monitor, but they have no problem powering on. Not sure if that is significant. Thanks!! Thanks in advance, Kristen
  • 156 Answers
I'm not surprised the interior lights continue to work. On most monitors, they use a separate power source from the main system power. Since an overhead monitor replaces a vehicle dome light, installers typically use the existing wires for the lighting circuit, and run the monitor's power somewhere else. Usually these systems are designed to use two power inputs: a constant power input and a key-switched power input. There are two places in the vehicle where both these connections can be made easily, and installers usually run their power wiring there: either behind the radio, or under the steering column at the key switch wiring. The add-on wiring typically has its own fuses and fuse holders, which should be located near the connection point. So the first thing to check would be those fuses. If you can drop the driver's side knee panel to inspect the key switch harness, and remove the radio to inspect the wiring at the rear, you will probably find two wires tapped into the stock wiring. There's a good chance the new wires will be red and yellow, and each should have its own fuse holder with a fuse. If either of the fuses is blown, it's the likely cause of your problem.
Posted on Jul 31, 2007
Will not accept dvd
you've got a bad player. the motor inside that plls in the disk and spits it back out is toast. replace the dvd player
Feb 16, 2010 | Nesa Vision NESA NSCM-1040 Overhead Flip...
Directed 10.2
remove all the wires connected externally and then try as some of the wire has got loosed and not supporting the device to work properly.remove the wires and then reconnect it properly.
Oct 25, 2008 | Myron & Davis ADM169GY 7 Inch Flip Down...
ALPINE TMX-R1000 ISSUES
You don't have S-Video coming out of it, although it looks like it. It's actually a bundled cable that carries power, video, audio, and control signal for an Alpine DVD player. It plugs into an interface box that has the actual power connections and inputs/output, and the control cable for an Alpine DVD player. I know this is an old post, but if you still have the unit and would like to sell it, or if you want to get the interface box, I can help you...
Apr 28, 2009 | Car Audio & Video
Cannot find audio on my dvd player
put in a movie and start scanning radio stations it should be 89.7 or sumthing
Dec 18, 2008 | MT&V (MTV-5931) 7-inch TFT Flip-down...
Flip down monitor
Well, It all kinda depends on how ur trying to hear it. Depening on the age and the model of the dvd player some models have a built in FM Modulator. This transmits the audio signal via your FM radio. Most Fm Modulators are preset out of the box with lower frequencies. Simply pop a disc in ur dvd player, Make sure the volume is  up on the dvd system and tune ur radio to the matched setting of the Fm Modulator.
Nov 15, 2008 | Car Audio & Video
CLARION VRX935VD PARTS LIST
Well,it seems you have couple problems there.
About the ribbon cable the part number is 039-2144-00
And about the monitor flips up and down easily,you will need to replace the complete slide mech assy;part number 948-0646-00
you can order it from pacparts.com
Apr 19, 2008 | Clarion VRX935VD Car DVD Player
9" FLIP DOWN TFT LCD CAR MONITOR DVD OVERHEAD TV
No problem.
The size will not be the same.
Ask for the size, you wants the same or a larger size.
atdlee@netzero.com
Mar 05, 2008 | XO Vision GX733 7.3 in. Car Monitor
VIZUALOGIC Headrest monitor
press menu, under the sub menu turn the parking off
Jan 07, 2008 | TMI Products Vizualogic Headrest Pair...
Car Audio & Video Logo
623 people viewed this question
Top Prosonic Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Prosonic Car Audio and Video Expert? Answer questions, earn points and help others
