Question about Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine
Cant move the stich ckanger
I just bought Kenmore®/MD Limited Edition 17-stitch Sewing Machine and I can move the stich changer, Im new at this , and I dont have a manual Can you please help!
    New Friend:
  • 186 Answers
Try setting the stitch width to zero and then change stitches. The cam feeler may be in the way.
good luck
Posted on Jan 31, 2009
Haven't used my Kenmore sewing machine #385.19153 for a long time. The display shows "bobbin winding" I don't remember how to change for simple straight line stich
Try pushing the bobbin winder spindle to the left. It's on the top of the machine to the right of the spool. When this spindle is pushed to the right, the sewing machine is ready to wind a bobbin. Once the spindle is to the left, you should be able to select a straight stitch (stitches 10-12), set the stitch length and check the thread tension.
See https://www.manualslib.com/manual/505279/Kenmore-385-19153.html?page=44#manual for a picture.
I hope this helps.
Jul 04, 2017 | Kenmore Sewing Machines
Tension wrong on sewing genie , bottom stich just makes a huge mess
Begin with tension setting in the middle of it's range. If the stitching improves tighten until it's perfect. Ps "Sewing Genie" isn't a real sewing machine... apologies.
Jul 19, 2014 | As Seen On TV Sewing Genie Mechanical...
Tension setting for small straight stitch on a Kenmore 10 Stich model 385 1249380 sewing machine.
Please go to Kenmore model 385 1249380 sewing machine sell shop and ask the machanic or shopkeeper.
Jan 01, 2014 | Sewing Machines
Thread tension will not adjust.
Check your setting, you have your stitches set too far apart. Wherever on your machine you see the zigzag stich you will see other stich settings, look at it until you see the right amount of stiches you want.
Mar 06, 2017 | Brother CE8080PRW Limited Edition Project...
I just bought a Singer Stylist 457.
if you bought the machine used, then it's possible that a
cam or gear is either worn or damaged. & needs to be check at a sewing machine shop.
if the machine is new,,then take the machine back to where you
bought it & tell them about the zigzag, even let them try it & see
what happens, I been sewing for over 30 years & I wouldn't keep
it,, if you bought it new,, I'd get another one
Aug 10, 2012 | Singer Sewing Machines
I have an old sewing machine in my attic, i just recently put it to use. but i cant seem to find the reverse stitch button. im only 14, it was my moms sewing machine. but shes no longer with us, so im...
I've got a Kenmore sewing machine and the back stitch is a button/lever on the front of the machine. It has to be held down when you want to back stitch, because when you let it go it stitches forward again. Hopefully that helps, I'm not sure what yours looks like. ( I couldn't find pictures of your model online anywhere.) :)
Aug 08, 2010 | Kenmore 15358
I have the same problem
Check the timing of the needle to the hook.
Here is a guide to generic principles of Timing
Aug 27, 2009 | Kenmore 15208 Mechanical Sewing Machine
Stitching is too loose
hi! this particular problem is common when tension and stiches adjustment does not match and complied to fabrics your trying to sew,there a is hard way to find manual specialy to old ones. but if you want it may help you some i got here on manual sears 1803.if your control look similar to this in figure5180e2c.jpg there are stitch control one for straight stitching and one
on special stitching.the small dial near needle is tension dial.You can set tension on # 3 to 5
stitch dial as in figure7a4913a.jpgif you are
sewing a straight stiches set to # 8 to 12 trial are needed somtimes to acquired smooth sewing,Be sure no mechanical problem regarding in machine operation.try to sew a cotton fabric for trial then if sewing another fabrics sudden adjustment should be done.If your machine is equipted by auto tension just select on the fabrics.well small information can sometime helpfull ...nice sewing
Mar 18, 2009 | Kenmore Sewing Machines
Yamata FY7568 only stiches ----------
Have you changed your needle? If you have a dull or bent needle it can cause the machine to not lock the stitches together and the result is a straight stitch on every pattern. Also, check your stitch width selector and make sure that it did not get accidently moved.
Feb 11, 2009 | Brother Sewing Machines
Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine Logo
128 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
