Question about Protron PLTV-32 Television
PLTV-32cm gets a BLACK box on screen on various channels
My PLTV-32cm get a black box on various stations an sometimes funny letters and such show in the box. This dosen't occur on all channels and not all the time. Sometime the box goes away on it's own sometimes it will only goaway by switching channels.
IS THE A FIX?
    Sniper:
  • 96 Answers
Hello. Well it really sounds funny. Maybe the best solution is to get rid of this TV, but before that try to disconnect every equipment linked to TV set: DVD, VHS players, anything, even cable TV, satellite and antenna. Check that there are no cable connected in to INs and OUTs. Now try to see if any problem occurs. Maybe your TV set mismatches inputs with the main view
Posted on Jan 31, 2009
  • 177 Answers
Hello and Welcome to FixYa!,
No it is not a fix if it Continues,
Protron is a Cheap version Television and has Mnay problems - Get a refund or sell up and possibly buy a new TV like a Sony, Pioneer or Panasonic.
Hope this helps, --P3NGYJ03
  • 296 Answers
That sounds like its linked to your closed caption. Is it turned off? You may have it on and dont know it and it may be selected on a differ language besides english.
  • James Bradburn
    James Bradburn Feb 09, 2009
    Check to make sure that your closed caption is off
I get a black box that takes up half the screen and it puts random letters and symbols all over the box. it only happens on certain channels also. only on channel 17 and 7 and sometimes on 65
Look for the CC/Text button on the remote. The TV is in the TEXT mode and is showing garbage that is being sent by the broadcaster, You need to turn the CC/TEXT mode off.
Nov 03, 2009 | Emerson EWF2004 20" TV
Screen has black box with greek letters on channel
If you put the TV on CH 3 and use a VCR (if available) to change channels you'll know if it's the TV or cable channel (sound like the channel)
Oct 05, 2009 | Televison & Video
I have a black box appearing on the bottom half of a 13" Magnavox television on only one channel. Can you tell me how to remove it?
Do you have the closed captioning on? Sometimes if it is in text mode, it will show up as a back box on the bottom on some stations, but not on others.
If you haven't already, view the station that has the black box on another tv to see if it was the station or just the tv. It may just be a station thing. It happens sometimes when they edit for a newscast and it accidentally comes up on screen.
Aug 20, 2009 | Philips Magnavox 27MS343S 27" TV
Black boxes on a few TV channels - connected to DIRECTV
Turn off closed-captioning. You'll find it's set for "text" right now, probably from hitting a button on the remote without realizing it. The set is blanking the screen for the text which doesn't show up. (In your case sometimes it does. You're the first person who's ever seen anything that I've responded to!) On channels and programs where captioning isn't being sent the box doesn't show up, so you don't know you have the trouble.
Apr 25, 2009 | Televison & Video
Digital or not????
You can get the owner's manual at;
http://www.bottomlinelcds.com/manuals/PLTV-32CM-owners-manual.pdf
You need a converter box.
Specifications
General
Dimensions
33.07"W × 25.83"H × 9.09"D
Weight 45.54lbs
Panel Type Active Matrix TFT LCD
Screen Size 32" widescreen (16:9)
Color Range 24 bits (16.7 million colors)
Max. Resolution 1366 × 768
Pixel Pitch 0.51075mm (H) × 0.51075mm (V)
Sync Range Horizontal: 30–80kHz
Vertical: 50–85Hz
Contrast Ratio 800:1
Brightness 500 cd/m2
Viewing Angle Vertical: +/–85°
Horizontal: +/–85°
Response Time 16ms typical
Inputs 2 × progressive scan component video (RCA)
3 × composite video (RCA)
1 × S-Video
6 × stereo audio (RCA)
1 × SVGA (15-pin D-Sub)
1 × stereo audio line in, 0 dBV nominal (1/8" TRS)
Outputs 1 x composite video (RCA)
1 × stereo audio (RCA)
1 × subwoofer (RCA)
1 × headphone (1/8" TRS)
Video Formats Supported SDTV: 480i
EDTV: 480p
HDTV: 720p, 1080i
TV Tuner NTSC-M, CATV, 181 channels
TV Audio Mono, Stereo, SAP
Parental Controls V-Chip (TV PG, MPAA)
Picture-In-Picture PIP, PBP
Closed Captioning CC1–4, TEXT1–4
Speakers 2 × 10W
Plug and Play Compliance VESA DDC1, DDC2B
Power Supply 100–240VAC, 50–60Hz
Power Consumption Operation: 232W
Standby: <3W
Storage Temperature 0 to 60°C
Operating Temperature 5 to 35°C
Apr 08, 2009 | Protron PLTV-32 Television
Large Black Box Showing up in middle of screen.
Try and turn off the closed captioning. I had the same problem and it turned out that the closed captioning was on t1 instead of OFF. Hope this helps!!!!
Feb 19, 2009 | Zenith C27A24T 27" TV
Black box comes up on tv screen
The black box is a text box for closed captioning. Some stations send the signal which turns on the box while not actually broadcasting any text. Go into your setup menu and turn off closed captioning, or at least change it to a different mode. The easiest option is to restore factory presets.
Nov 28, 2008 | Polaroid FLM-3732 Television
Black rectangle in the middle of my screen
Turn off the text box function of the closed captioning.
Aug 31, 2008 | Sansui LCDWDVD320 32 in. TV/DVD Combo
A black box appears on the screen
The close caption feature most be on and you need to disable it to get rid of the black box,the close caption must be set in any mode for the box to come up,maybe text1 or text2.Go thru the menu options until you get to the CC feature,some remotes have a key to bring it up and disable it.Let us know if you need more information.
Oct 27, 2006 | Samsung TXM1967 19" TV
Protron PLTV-32 Television Logo
16 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
