Question about Freezers
My hotpoint ff187e fridge/freezer keeps bleeping and flashing how can i fix this? it is only 18 months old.
Turn the second knob at the top to off (freezer knob) turn the fridge freezer off. Then turn it back on. That may sort it. Or you may need to totally defrost the machine as there could be some ice blocking some vents. May need to remove the back panel of the freezer for this (inside).
Posted on May 09, 2009
  • 750 Answers
Hello
Welcome to Fixya
My name is Huum,
You said, my Hotpoint ff187e fridge/freezer keeps bleeping and flashing how can i fix this? it is only 18 months old.
The beeping and flashing are alerts to tell you the temperature is not up to safe levels.
It is an alarm to warn you.
Your fridge is close enough to the warranty period that they should still service it. If you call Ge Hotpoint and ask for a supervisor.Other wise you need service to come out and repair it before your fridge goes out!
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Posted on Feb 03, 2009
Hello,I defrosted my electrolux chest freezer and now problem is power is on but not freezing,alarm light keeps coming and keeps bleeping every 2 minutes and goes off and on
Is the compressor running? if it is running, but there is no cooling, it is time to buy a new freezer.
If the compressor is NOT running, I would suspect the compressor start relay.
How did you defrost it?
Jun 09, 2016 | Electrolux Frigidaire 14.8 cu. ft. Chest...
Hotpoint fridge freezer ff200 tx displays error code A1?
These tempratures are pretty cold should be around 0 deg. but it sounds like you might have a bad defrost timer or defrost thermostat the frost should not come back if defrost system is working
Jul 26, 2014 | Hotpoint Freezers
Hello, my hotpoint FF187E fridge freezer keeps tripping my electric off, sometimes it will stay on for a couple of days other times it does this straight away, any idears would be appreciated, thanks...
you may have a burned wiring which when wet trips off you electricity. the location may be in front of your unit between the doors if you have a two door fridge. if you have a singole door unit it may be located on lower area of the fridge body which where the water flow down when you have excess water dripping infront of your fridge. those two location are most likely because the wiring installations from thermostat, heater, and ligth are there. ofcourse you have to check first the compressor and it's auxillaries
Jan 13, 2010 | Freezers
Hotpoint FFA97 freezer works but fridge does not
It seems to me that there is a leak of gas from your unit.This is if you have 1 compressor/motor)If there is two compressors on unit then it can be thermostat for fridge.Anyhow check if motor is running all the time and is wery hot, if it is there is to little gas in system .This should be covered by guarantee.Jan
Feb 13, 2009 | Freezers
Freezer freezes and then thaws
check wiring into outlet and at breaker that feeds outlet. you may be losing high volts at or to the switch. if possible check power into the stat when the condition occurs. this will telll you if stat is bad or power into it aka the outlet is bad. you may be jiggling wires in the outlet enough to fix short term each time you replug to outlet or get a good heavy extension cord and plug in else where to seee if problem goes away.Good luck
Dec 06, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Freezers Logo
1,045 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
