Question about Garland H283 Gas Kitchen Range
Change thermocouple Garland range
How do you get at the thermocouple on the left side oven ( convection oven ) on this garland range 283 RC ? The oven floor does not appear to lift off. there is very little clearance underneath.
  • 3 Answers
I know the question is a little older, but maybe it helps someone else... I just did the job and it turned out to be much easier than I thought it would be. The whole burner assembly slides out, so you don't have to work in that small space!
Simply turn off the gas, disconnect the two pipes that go from the oven to the valve (gas and thermostat), disconnect the two door springs from the burner unit, remove the screw that holds the valve, remove the two screws that hold the burner in place and simply slide the thing out. You may have to loosen the right half of the heat protector plate to get it out. That's it.
Posted on Nov 12, 2009
  • innkeeper64 Nov 14, 2009
    By the way - don't forget to secure the oven door somehow! Once the springs are removed, the door WILL open as soon as you are working down there. And that door is heavy enough to knock you out!
    Novelist:
  • 125 Answers
Hello. Heh, well, somehow you WILL have to work in that little space, I know it wasn't what you wanted to hear, however...
The easiest way to do this, is to shut off the gas, remove as many items in front of the plate the thermocouple, pilot line,and burner orifice go through. Most of it should come off with wrench's and screwdrivers, then you can take off the plates covering the burner area, once these are off, you have approx. 3 to 4 in. to work in to remove the pilot/burner. Leave the door springs alone, they can stay, its just one of those pain in the **** things, and is the only way.
Hope that helps, and thank you.
Posted on Feb 22, 2009
  • Jim Feb 22, 2009
    ps: take a picture of it if you can, before you take it apart, then you have something to check when re-assembling.
  • Garland Master
  • 4,654 Answers
Here is a link to PDF of your oven. Also phone numbers to ask Garland their answers...........SEA BREEZE
http://www.hendrixequip.com/PDF/X085_H283.pdf
Posted on Jan 31, 2009
What can go wrong with a garland thermocouple?
Make sure the thermocouple is screwed securely into the safety valve... it is a -tiny- voltage and a small loss can drop the pilot. Also make sure the pilot flame covers the last 1/3 of the thermocouple element, you don't wan to cover the whole thing. Check for errant air currents that might be blowing the pilot out.
Jul 19, 2014 | Garland H286 Gas Kitchen Range
I have a gas garland convection oven 10-15 years old. I see the red button to relight the pilot light but I can't find the pilot light itself. Can you tell me where I should be looking?
On the main bake burner is going to be a small pilot burner,got to lift off the oven floor to get to it. It is going to look something like this picture and is attached usually to the side of the main burner.To light the pilot,push that red button light the small pilot burner..hold in the red button for about 20 seconds..release the red button..pilot should be on..if goes off the thermocoupler is going to be in need of replacement
Aug 26, 2011 | Ovens
I just installed a new thermocouple from garland in my range but the oven still shuts off. I don't know why.
I have a Garland range 4-burner and it is 24 inches wide.I don't have the model number;and I want to buy a thermocouple. I need a part number it.
Nov 25, 2010 | Garland H283 Gas Kitchen Range
Where can i get parts for a garland starfire gas oven
Our oven pilot light will not stay on - we have to relight all the time. We have had the thermocouples replaced already and it is only two years old. The seller will no longer work on it for us. Says it is our fault in that we MUST be doing something wrong.
May 13, 2010 | Garland H286 Gas Kitchen Range
Need part # for oven thermocouple on garland h283
Here is what I think you are looking for:
18 inch thermocoupler: G1019418
here is a good website
http://www.whaleyfoodservice.com/garland-parts.asp
Good Luck!
Feb 25, 2009 | Garland H283 Gas Kitchen Range
Garland gas oven pilot light won't stay lit. We have cleaned it and depressed red button for varying times up to 10 minutes. Adjusted flam
The ovens are protected by a thermocouple. It's the steel rod that the pilot flame heats up. The idea is simple- if the thermocouple doesn't sense heat from a pilot flame, it won't allow the gas regulator to send gas to the oven burner bar; it won't even allow the pilot to stay lit. Easy to replace. My Garland oven uses a 24" thermocouple. Any good hardware store has them for around $10. Just take off the skirt that covers the over-ride buttons on the regulator. You'll see the other end of the thermocouple there. I recommend taking the old one with you so you know which length to get. When you install the new one, just curl any excess in a nice big loop & tuck it out of the way.
Feb 15, 2009 | Garland Kitchen Ranges
Garland stove oven pilot light does not stay lit
If there is any adjustment, it would be a small screw on the oven control accessible with the oven control knob removed. This adjustment affects the size of the top burner pilots, but I'm not sure about the oven. The oven pilot orifice may have an obstruction, or if the flame is actually normal size where it covers the thermocouple when it burns, you may have a thermocouple problem.
Dec 22, 2008 | Garland H283 Gas Kitchen Range
How do I remove the oven door on a Garland Range
Hi, is this unit a convection unit? usually you don't need to remove the door to replace the thermocouple, if it is convection unit, you will need to shut the gas off, remove the safety, and there are two metal plates covering the burner area, take those out, the next thing is to remove is the burner, it is usually just fitted in the back, once this is out, as the pilot is attached to it, you can replace the t'couple now, assemble reverse.
If you really need to remove the door, and you are really lucky, remember to undo the spring hooks holding the door so it does not snap the door closed during disassembly, usually you can just pry up on the triangle near the hook, releasing tension to unhook the door hooks, leaving the springs attached. You can just take the screws out that hold the top of the door, the bottom of the door, and I think the handle, then the door skins split, and on each side at the hinge, there is a set of bolts holding the hinge in place, remove these, and you should be able to remove the door, otherwise you need to take the bottom kick plate off, along each edge inside the door frame, are screws holding the outer channels in place, remove these, and down along the inside of the kick plate edge too. Easily pry these away from the oven body, older units had a solid piece from front to back, and you had to remove the entire side panels, or were spot welded altogether, all you can do then is pry them back best as possible, and hopefully they won't crease. Inside these channels are the hinge plates that the hinge goes into, unbolt them, slide the door out, and there you have a door in you hand. Garland has a kit to replace all of these parts as you go, if they are badly worn. I know, allot for a thermocouple. Hope that helps, and thank you.
Dec 21, 2008 | Garland H283 Gas Kitchen Range
Griddle top for older Garland 283 gas range
Hi, it may not, depending on the age difference of the units, the grease catch, etc.. contact Garland at www.garland-group.com , or call 1800 424 2411, the parts department should be able to tell you at least. Hope that helps, and thank you.
Mar 10, 2008 | Garland H283 Gas Kitchen Range
Oven pilot light won't light
It is usually a bad thermocouple. Mine had only had a weak pilot flame and the problem turned out to be a corroded and leaking pilot gas line. It was leaking whee it enters at the bottom of the oven chamber.
Mar 05, 2007 | Garland H286 Gas Kitchen Range
Garland H283 Gas Kitchen Range Logo
1,265 people viewed this question
Top Garland Kitchen Ranges Experts
John Tripp
John Tripp
Dennis Boxerman
Are you a Garland Kitchen Range Expert? Answer questions, earn points and help others
