Question about Creda W100FW Front Load Washer
Blocked outlet washed some rather fluffy things in the machine and darn thing has got blocked, have opened door, removed laundry items and scooped water out, what do i need to do next (step-by-step instructions would be very handy)
    President:
  • 1,294 Answers
Power off the wall. Get user's manual, look for blocked filter. Open up the filter, usually front bottom right side, clean, refit. Be prepared for much water to come out. The filter requires periodic cleaning according to usage.
Posted on Dec 22, 2007
How do unlock the washing machine IQ300
Do not open the washer door by force while it is operating (high-temperature washing, drying, or spinning). Within 5 minutes as you start a wash, it is possible to add/remove laundry items. Simply do the following: Step 1: Press the Start/Pause button to unlock the door
Mar 25, 2016 | Washing Machines
Sludge on clothes after washing
Try washing the machine without clothes , on hot wash warm rinse. Pending on how much laundry you do - is how often you should run a ghost load/cleaning cycle.
Aug 09, 2013 | Fisher and Paykel Washing Machines
Magkakatuluyan ba kami ni shelumiel
Instructions
things you'll need:
* Laundry detergent
* Clean cloths
* Measuring tape
* Plywood (if necessary)
* Wrench (if necessary)
1.Verify that the Kenmore top-loading washing machine is completely plugged into a grounded, three-prong power outlet. Reset the fuse or circuit breaker, if necessary; do not plug the washing machine into an extension cord.
2.Make adjustments to the feet on the washing machine if it is shaking or vibrating. The front and rear feet must all be touching the floor evenly. If the floor under the machine is flimsy and cannot adequately support the washer, set a 3/4-inch piece of plywood under the machine for better stability. Load the tub evenly when placing items inside the washing machine and do not overload the tub.
3.Examine the washing machine drum, including between the inner and outer basket, if the machine is clicking or rattling during use. Remove loose objects from inside the drum. If objects are caught between the drums, unplug the washing machine and pull the items out with a pair of pliers, if possible.]
4.the fill hoses behind the washing machine if there are water leaks and ensure the drain hose is connected to a laundry tub or drainpipe. Look at the plumbing throughout the home for drainage problems and correct as necessary.
5.Turn on the water valves behind the washing machine and clean the water inlet hose screens if the water is not running or filling. Do not overload the tub, and use only high-efficiency (marked HE) laundry detergent in high-efficiency Kenmore washers. Note that energy-efficient washing machines often use less water than other machines; this is normal.
6.Choose a wash cycle with a higher spin speed if the water is not draining as expected or items are extremely wet when washing is complete. Reduce overall load size and select a new drain/spin cycle to remove the extra water from the washer. Ensure the drain hose is properly installed on a drainpipe or tub and is not set more than 96 inches above the floor.
7.Reduce the number or volume of items inside the washer tub if the clothes are not rinsed when the cycle is complete. Verify that the water valves are turned on and the correct type and amount of laundry detergent is used.
Mar 12, 2011 | Kenmore 22422 Top Load Washer
Beko wm5120...no power even with new fuse
Instructions
  1. Close the lid or door. Washing machines automatically stop when the lid or door is open. Lift the clothing and move it slightly. If the washing machine is overloaded with towels or heavy garments, it might become unbalanced. The washer won't run until the items are adjusted.
  2. High-efficiency machines might stop running when regular detergent is used or too much high-efficiency laundry soap is poured in. If you suspect that the laundry soap is the problem, cancel the cycle and press the "Spin" or "Drain" cycles. Restart the cycle, but do not add more detergent.
  3. Inspect the water outlets. Turn faucets to the left to ensure that both the hot and cold water hoses are open. Tug on the hoses to make sure they are attached and inspect the hoses for thin spots that might be causing leaks. Make sure the hoses aren't kinked. Detach the hoses and run clean water through them to remove clogs.
  4. Is the washer's cord plugged into a grounded outlet? Never use extension cords to power washing machines. Check the circuit box for blown fuses.
Feb 02, 2011 | Washing Machines
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Error code E20 electrolux washing machine EW1280F
• E10 = there is no water filling • E20 = the water is not drained • E40 = door open
Download Manual - http://laundry.manualsonline.com/manuals/mfg/electrolux/ew_1280f.html
Feb 04, 2010 | Electrolux Washing Machines
Door wont open laundry stuck in there now since Friday night...This product S-----!! NOT TO MENTION ALL THE MOLD ISSUES ALREADY...
you can use a wet dry shop vac and attach it to the end of the drain hose to remove the water.
if the water comes out fairly rapidly you may need to replace the drain pump.
once the water has been removed you can open the door and remove the clothes.after everything is removed you need to remove both the hoses from the drain pump and look in it for any thing that will stop it from turning and or blocking the drain pump.
Jan 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washing Machine Door won't open
I had the same problem. I went through all the steps on this thread to no avail. Finaly I just pryed the thing open - with no damage, thank goodness.
Once open I saw that the latch in the door didn't move when I pulled the handle. The problem it seems was in the latch on the door itself. If you end up this problem and want to get wet clothes out, just stick a flat-head screwdriver, behind the door latch into the horseshoe-shaped metal bit and lever it open - no prying necessary.
Not sure how I'm going to fix this permantely but at least I got my wet clothes out and can do laundry as long as I keep the screwdriver near by.
To fix - I'll either need to figure out how to disassemble the door and replace the latch mechanism, or just buy a whole new door.
Oct 27, 2006 | Whirlpool LHW0050PQ Front Load Washer
Creda W100FW Front Load Washer Logo
114 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
matt
matt
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
