Does it have relays on 1989 honda civic
On a car over 15 years old the odds are the wiper motor failed
You need wiring diagrams to work on electrical
You have to see what is in the circuit you need resolved
No one can tell you how to diagnose things,you follow a
procedure that work for you
Don't change any parts
That is not how you work on a car
Learn how things work & test to confirm failure
Your not going to have relay failures as you read about
on these sites,too much bad info talked up on here
A fuse will blow if the motor or any motor fails,so that could be
a key do not replace a fuse,go to what it controls such a the motor
& try unpluging it & use the wiring diagrams to put power to it
SOURCE: windshield wipers in front wont work but rear wipers work
Hi! U need to check the switch and the wiring circuit that controls the motor.
SOURCE: window wipers dont work i changed the wiper motor
the switch or the relay. Check if power is comming to the relay.If it is then the relay is faulty. If not then it's the switch. If the wiper's won't work at any speed it is most likely to be the relay because if it is switch then the wipers should work at some of the setting's hope this help's. Cheer's
SOURCE: I haveea 97 honda civic. My wipers won't turn off
PRISE SWITCH OUT AND CHECK FOR CROSSED WIRES IF SWITCH IS CAPUT GO TO BREAKERS YARD FOR REPLACEMENT.
SOURCE: where is the the wiper motor on a 99 honda civic
Back of engine bay and base of the windsreen you will see some plasic covers known as scuttle panels, you may have to remove the wiper arms first (10mm M6 nut under the Black circle cap on each arm)
The motor will be the size of a coke can with Silver linkage bars going to it
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-windshield-wiper-motor.html
http://schematicsdiagram.blogspot.com/2011/12/car-windshield-wiper-gets-power-for.html
http://technoanswers.blogspot.com/2011/11/how-does-cars-windshield-wiper-system.html
Did you test the new motor before you intalled it? Need the diagrams to see all the items in the control circuit. Having someone say you have relays is of no value to you. You need to see it on the prints & find in the car & test every item in that wiper circiut including wiring
