Question about Sony KV-36FS100 36" TV
Dopped tv, worked fine, now not picture but has sound
I was moving and dropped my kv-36fs10, which is only about 215 pounds! the plastic on corner broke but i put it back together and the t.v. worked fine at my house, and hour or two later when i get to my new house the t.v. dosent work, i hit the power button, it clicks makes sound but no picture, the standby light is blinking though any suggestions?
  • daaa Jan 18, 2008
    not droped but same problem
    Genius:
  • 1,694 Answers
Most drop damage is in/around the area of the flyback xformer.My Motto==PVAT! With magnifier examine PCB for crack(s).May still be fixable.
Posted on Oct 05, 2007
SOURCE:
Sony trinitron KV-27V20 stopped working
Power supply regulator section should be checked in detail. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Some times, the ads attached with each posts might help you to find the availability of spare parts. There are more than 640 posts to different brand TVs.
Aug 19, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Screen looks like a picture negative, PIP works fine, sound fine
Sony's have dual tuning systems to allow for the separate PIP channel. The common problem on the Sony's is the circuit board and tuning module connections go bad. It is likely that the connections on the board or module were already in the decayed process and moving it just accelerated the issues that were inevitable.
The quick fix is to swap the PIP over to the main picture or to bus the antennae signal to the antennae B terminal thus bypassing the bad tuner module.
The recommended fix action is to have someone with soldering skills to remove the chassis, and locate all the cold and cracked solder joints, especially near the tuning modules. If this does not take care of the problem, the tuning modules will need to be removed for re-soldering on the actual tuner modules.
If none of the above works, then you can always use the audio/video outputs of a cable box or vcr to the a/v jacks of the tv, thus bypassing both tuners in the tv.
Apr 28, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Picture vertical output has reduced
TV has no cathode 200 volts supply.
If you have experience of CRT TV repair then let me know to guide you further or get help of near by TV tech person.
Nov 30, 2008 | Sony FD Trinitron WEGA KV-24FV300 24" TV
Moved tv from 1 location to another
hi there, it may need some fine tune for the sony kv-27fs12 to be connected directly to cable jack wall. do some test. ty
Jan 10, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
No picture on tv but have sound
how many times it flashes?? if its more than 6 times you have a problem. just lick the red wire that goes to the picture tube.if it does not kill you, you are lucky
Jan 07, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture, but has great sound
Older television have components that are designed to last for about 10 years. slight movements can cause failures in old Capacitors and loosen connections.
Might sound weird but seriously give the thing a good slap on the side after it has warmed up. if there is any effect AT ALL. take it to a repair man. if not your set may have simply bit the dust and now requires more servicing costs then a new set.
Nov 07, 2007 | Sony KV-36FS100 36" TV
Sony KV-32FV15 TY
I have had my Sony KV-32FV15 for about 2 years now and nothing has ever gone wrong(even going through several moves.) I recently moved again and when I plugged in the TV, you can hear the sound perfectly but the screen just stays black. You can not even hear the squeal that the TV makes when comming on. Is there anything that I should initially look at to troubleshoot. I cannot afford at this time the $250 fee to repair my TV. I look forward to your input and hopefully I can get this TV working again.
Oct 24, 2007 | Sony KV-32FV15 32" TV
No picture but sound works.....
  • adjust brightness setting when playing tv.
  • adjust screen control located on flyback transformer.
  • hope this will help.
Oct 23, 2007 | Sony KV-36FS16 36" TV
Sony WEGA KV-36HS500
you may have cracked the circuit board when moving , sounds like a bad vertical circuit. look for bad connections around vertical ic or flyback transformer
Aug 19, 2007 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony tv picture keeps flashing
You likely have bad solder connections around the tuner area. This model has a history of problems in that area or the tuner itself.
Aug 29, 2006 | Sony KV-32S35 32" TV
Sony KV-36FS100 36" TV Logo
91 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
