Question about Viking DFSB483 Side by Side Refrigerator
Water dispenser freezing on viking refrig
All of a sudden the water dispenser if freezing up on my viking refrig. It's a bottom freezer model with french doors. water dispenser stopped working but ice maker still functions. can anybody help me with this?
  • 59 Answers
One thing that can cause this s the removal of the styrofoam block that surrounds the water reservoir. A lot of people think this is just for shipping but it is necessary to prevent the water freezing.
If it is missing it ill need to be replaced.
Posted on Mar 04, 2009
  • Shaye Oct 15, 2011
    i have same exact problem!
    but the styrofoam is still in place...
    perhaps my fridge is set too cold? I keep it at 35 degrees f.
Water freezing in bottom freezer
The drain line is clogged, unplug. Remove the back panel being very careful not to cut yourself or damage the evaporator. Remove the ice not sharp or pointed objects for this, just hot water. Lay towels down and start pouring hot water until you hear it go down the drain.
Mar 14, 2015 | Samsung Refrigerators
FGHB2844LF water dispenser not working
Turn the temp down on the refrigerator side but not below freezing. Some frigs have a "trap" set up for the water dispenser. its located behind a panel in the frig and it is there to help chill the water before it dispenses. if the frig setting is too cold then it can freeze the water .
Dec 08, 2013 | Frigidaire FGHB2844LF Gallery 27.8 Cu. Ft....
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
How do you adjust the door swing angle on the Viking VCFF036 bottom freeze French door model? What are the angles?
Check with your Viking rep. I had a problem that the door swings too wide. They said they are coming u with a kit to replace the door stop. I was told there will be a 100 degree doorstop kit for my problem The door when swung open gets a ding from an adjacent Viking electric oven with the professional door.
Jan 01, 2010 | Viking VCFF036 Bottom Freezer French Door...
GE refrig/freezer dispenser makes ice, but no dispensing of water
The dispensor water line , is probably trying to freeze , inside the door . raise the freezer control slightly warmer , to keep this from happening . May take 2 or 3 raisings to find the proper temp . Also , you can order a dispensor heat kit , pt # WR49X10173 , which comes with installation instructions .
Oct 05, 2009 | GE Refrigerators
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Water dispenser in my Maytag french door refer has suddenly stopped working. We use it every day and the filter seems to be fine. It almost sounds like it is frozen. Please Help!!!
We have a hd2560 (bot 10/04), french door with inside water dispenser and it had stopped working a year ago, but started working a few months later. I couldn't figure out what happened, but suspected the water line was frozen. I later found out that the water reservoir is located behind the fruit and vegetable bins, so look there to see if the water is frozen.
Two weeks ago, our frig/compressor stopped cooling after making humming/clicking sounds for weeks. Fortunately, Maytag has a 5 yr parts & labor warranty on the compressor, so we were covered. Evidently, there are quite a few faulty compressors out there.
I believe that the compressor had been over-cooling in the past and caused the water lines/tank to freeze. This would also cause frozen produce/fruit. I would immediately contact Maytag/Whirlpool if you suspect a faulty compressor as well.
Oct 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
Maytag mfd2561 water dispencer and ice maker issues
ther first refrig id have to see for better idea of problem but hte second with the flaps open and closing is going to need a high voltage board part num(12920710)---thats the part number i get wehn i look it up with the model MFI2568AEW. dont know where you got 12002608(that to is a h.v. board. which ever itssan easy enough repair to do yourself, its mounted on the rear of refrig and comes with programming instructions in the box
Mar 12, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Mar 06, 2007 | Amana AFD2535DES French Door Refrigerator
Viking DFSB483 Side by Side Refrigerator Logo
774 people viewed this question
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
