Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
My garage door opener willnot work inside trailblazer .
My remote for garage door has new batteries but will not work inside my vehicle my husband took his out his truck it worked, outside it worked inside my trailblazer it would not work as well. My remote for lock/unlock is now working close beside door as well
  • marty metzger May 11, 2010
    Hitwizard. She says it works outside truck, so code is ok.
  • Bo Trevathan
    Bo Trevathan May 11, 2010
    Depending on the type of remote and garage door you have, you have one of two options. If it is a Coee Learning Garage Door Opener, all you need to do is find a button on the back that says Remote or Rem. or something like that. WIth most of these you just press it and it will flash, and then you press the garage door opener remote to be programmed. The garage should then learn the code for this remote. If this is not the set-up of the garage door opener, you should open the battery case and look for a series of switches. Compare these switches to your husband's and match them. It should wotk if you do this.
  • 30 Answers
Do you have a antenna build into the windshield of your car? If so thats your problem and there not much you can do about it other then stick your hand out the window when you pull up, and point the wire coming from your opener toward the door itself. Do not cut or add to that wire.
Posted on Feb 10, 2009
My Craftsman remote won't close my garage door
If the remote opens and closes while inside the garage but not outside , there are a few things it could be. Assuming it was working fine before..
1. weak battery in remote.
2. remote itself could be bad. (unless you have more than 1 remote acting the same)
3. Logic board in opener is going bad causing limited range.Is the wire that hangs down from the opener straightened out? That is your remote antenna.Some people have coiled or even cut it off..reducing range.
4. Less likely but this can happen- interference from another electronic device, wireless routers, cell phone, new appliances etc.. can reduce remote range. Any new electronics recently purchased?
Jan 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Unable to open the garage door with the remotes. I closed the door from inside unit and came out. but later on when i tried opening it from the remote there is nothing happening. Please please help me. My...
It sounds like your remote may have deaad battery OR got de-programmed. I hope you have another door into the garage. You NEVER should rely on a radio remote as the ONLY access to the garage! Many failures can happen to prevent the remote from working.
IF you can kill the power to the opener in the garage, do that for a couple minutes then repower and try again...
And for goodness sakes cut in a new door as EVEN in a condition where the power fails in a disaster you want to have access to your vehicle... this is a "wake up call" for you! There is also a keyed lock that can give you access to the manual trip cord to allow manual opening of the door.
Jan 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
HomeLink works in vehicle... unable to program hand held or remot
When did your remote and keypad quit working? Was it when you programmed the Homelink? It sure sounds like you have a bad logic board.
Jul 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote wont work more than 5 feet from the opener.
The battery inside of the remote needs to be replaced. Take the remote to any radio shack store and they will sell you the new battery and even install it for you.
May 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Setting garage door opener
Most openers are programmed the same. You normally program the house garage opener to accept the new remote. Your garage opener will have a button to press to add in a new remote. Normally you press this and then press the remote in the car and hold until your lights on your opener flash or the garage door closes. (check your manual on your garage door opener)
Mar 27, 2009 | 2005 Chevrolet TrailBlazer
Having trouble setting garage door opener to my 2004 trailblazer
1. Position vehicle within 10 feet of garage door- engine off and battery on.
2. Press/hold 2 outside buttons of Homelink transceiver until red indicator starts flashing rapidly, then release button. This should take about 20 seconds. This erases any previously learned codes.
3. Press/hold remote control and press/hold button of Homelink transceiver simultaneously. Slowly move remote control from 5" away to 1" away from Homelink transceiver. Release both buttons after red indicator starts blinking rapidly. This should take about 5 seconds. I discovered that the Homelink in my TL is a bit faulty because it took much longer to accomplish this than when programming the Homelink in my MDX. My TL's Homelink may "unlearn" it's code in the future and the needed proximity of the TL to the garage door may be much closer than desired until I get the Homelink fixed.
4. Press training button on garage door opener unit until the indicator lights illuminates- this should be immediate.
5. Within 30 seconds press/hold the Homelink button for 2-3 seconds until the red indicator starts flashing rapidly. Repeat a second time. It should now be programmed. Check it by pressing the programmed button on the Homelink receiver.
6. When programming more than 1 garage door opener unit, disconnect power from unit before programming more units. By not doing this the programmed unit could conflict with the unprogrammed units commands.
Problems:
1. The Battery in the garage door remote may be too weak to program Homelink. However, the battery may be strong enough to operate the garage door. One of my remote controls had a weak battery- my system was installed today, fresh out of the box. I had to use the second remote control for the programming of Homelink on my 2 vehicles.
2. Antenna on the garage door opener unit must be hanging down, fully extended.
source:chalkstar100 (fixya mate)
Thanks for using Fixya
Have a nice day!
Mar 07, 2009 | 2004 Chevrolet TrailBlazer
Remote opener
Have you tried to re-learn the remote? The instructions should be inside the opener cover.
Nov 02, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
159 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Vince Heuser
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
