Question about Dell Latitude D630 Notebook
My Gateway laptop screen is dark and I believe I have to replace the bulb but how do I know which one to order? I have pulled apart the monitor but where to go from here? Thanks Dee
    Problem Solver:
  • 17 Answers
Just Search up the Make & Model Backlight Bulb of the LCD Screen. Example: (LiteOn LTR6543 Backlight Bulb). Don't forget about the Inverter, Most of the time it's Mounted below the LCD Display. That's what Powers the Backlight. Hope This Helps!...
Posted on Feb 12, 2009
My laptop screen went very dark, I can barely make out whats on the screen but I know its working. What can I do to fix this situation on my gateway p-6860fx pc notebook?
Hi josue fernan...
You need to see if your laptop lcd screen is faulty and/or the lcd inverer is faulty.
1....Test the lcd screen:
Hook your laptop to an outside monitor and then start your laptop normally...if the picture on the external monitor is good, then your lcd screen is bad.
2....Backlight Faulty: If the monitor is still as dark like your lcd screen on the laptop then it could be the backlight that is faulty.
Please take time to rate me thumbs up
LCD Backlight and Screen Replacements:
http://www.laptopsman.info/0-Gateway-lcd-1.html
LCD Screen replacement:
http://www.screentekinc.com/Gateway_P-6860FX--17-inch--1440x900-wxgaplus-laptop-lcd-screen.shtml
Sep 11, 2011 | Gateway P-6860FX Notebook
Dark Screen
there is a weird possibility that somehow your PC is configured to save power.. that is something you can do on a laptop to save battery..
you can check in the control panel what is the status of your energy options and see whats going up there..
there is also another possibility that it might be the monitor to be malfunctioning... but if after the screen being dark and you enter the options on the monitor and they are bright i doubt its a malfunctioning monitor..
so try to reinstall the monitor drivers and possibly the drivers of your video card if you have one.. but my biggest bet would be the option energy in the control panel
Dec 22, 2007 | Gateway FPD-1930 19" Flat Panel LCD...
Gateway FPD1960 monitor
support.gateway.com/s/Manuals/Monitors/8511446.pdf OK manuals above and below. support.gateway.com/support/manlib/.../Monitor.shtml Below is how to repair your monitor step by step, hope this helps. http://www.ccl-la.com/LCDrepair10.htm
I looked for a service manual, but could find none :(
Jun 06, 2010 | Gateway FPD1975W 19" LCD Monitor
MONITOR VERY DARK
Try using the FN key and the up arrow at the same time while tapping the up arrow, also make sure that if you have vista, you are not in "power saver mode". if there is no light at all coming from your screen, you may have a bad display bulb, this could also be a faulty invertor, but you would have noticed a constant flicker.
Sep 07, 2009 | Gateway Computers & Internet
Light bulb bad?????
You may have a faulty inverter or a faulty CCFL lamp.
A defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 06, 2009 | Gateway HD2200 LCD Monitor
Lcd of my gateway laptop lost ligth inside so is to dark but i can see the destop icons but is to dark
Your Backlight bulb has burned out, or the Inverter for it.
1.General information on replacing a Backlight lamp,
(Bulb)
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
2.General information on replacing an Inverter,
http://www.laptoprepair101.com/laptop/category/replacing-screen-inverter/
May 28, 2009 | Computers & Internet
My computer monitor will not display properly
this is the first way. use external monitor. if you get clear view then you have a problem with LCD INVERTOR (you say bulb).
i hope it works.
May 27, 2009 | Gateway M-6307 Notebook PC
Screen went black
I don't know. I've never actually replaced parts in a monitor. If the bulb is expensive, it might be best to buy a new monitor. They're cheap nowadays. Or you can check if there's warranty on the monitor and it can probably be fixed for free.
Apr 20, 2009 | Acer X221WSD Monitor
Monitor too dark....
inverter board bad. this runs your lcd lamp(s) but is not in the screen.
Oct 02, 2008 | ViewSonic VA702b 17" LCD Monitor
Laptop screen very dark
the screen is not a sealed unit... and the backlight and the lcd bulb can both be changed out...
I do it on a daily basis....
It is way cheaper to change out the lcd bulb than it is to replace the lcd display panel... Way CHEAPER
the results are the same
Jul 30, 2008 | Gateway 450ROG Notebook
Dell Latitude D630 Notebook Logo
69 people viewed this question
Alun Cox
