Question about Compaq Presario 2580US Notebook
System is not responding win xp - Compaq Presario 2580US Notebook
Nero 6 wont load in win ME, it has done so before with no problem
Windows XP is the most compatible for all software installations , check the software version that you installing and also check that if all the files downloaded properly if you got the software from the internet. Service pack 2 is the best.
Feb 22, 2013 | Computers & Internet
I turned on the PC, was asked to choose between WIN and WIN XP. When I choose WIN XP, the message comes up that "file nvrd32.sys could not be found" and so then I had to reboot the PC, choose WIN...
need the xp disc someone or thing has deleted a system-32, made the same mistake and had to reload the OS. System 32 is a main part of Your OS with just one little whoops of deletion you render the program useless. it should save your old stuff in a win.old file which it'll explain as you redo the whole thing over again good luck hope I can help
Jan 20, 2011 | Computers & Internet
Windows stop and nothing happin
hi If able to load win XP or any operating system that mean your system is booting and is in good condition. if there is issue with load of OS in normal mode then you try using last used configuration. follow this steps
1) keep press F8 when bios screen goes off until you see win xp option
2) then choose "last used configuration".
it will try to boot the system even though the system does boot properly then repair the os by booting xp dvd or cd from cd & dvd drive.
i hope this will resolve the issue.
Jun 25, 2010 | Mercury P4VM800M7 Motherboard
Will not run xp pro i'm stuck in 2000 mode mother board is ak77 pro 133 vt8233 will not run xp pro i've been told im pretty much sol. Is this true?
If you have a valid Win XP Pro CD and want to install the operating system you'll need to format your hard disk drive. If you have allot of data on you're hard disk drive, (In Win 2000) Suggest you create a second partition within the free space of you're hdd and install windows XP Pro. Boot you're system with the XP CD. Pay close attention to the display screens. Follow the instructions for creating a second partition.
Format the new partition. (Quick). Install windows XP on the new partition. Once completed you can copy your personal data to win XP.
If you choose to keep the win 2000 partition and you do not wish to have a dual boot system than remove/delete the root files from the 2000 partition. These files; Autoexec.bat and Boot.ini. You're new XP Boot.ini should read like this;
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Once you're satisfied an no longer need win 2000 use windows diskmgmt.msc from the run command to delete the win 2000 partition.
Win 2000 uses a FAT16 where Win XP uses the FAT NTFS.
Cheers!
Mike
Jan 07, 2010 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
Five computers networked with Linksys WRT320N router. Operating systems: Win 7.0 on 3 computers (two hardwired)(one laptop - wireless), Snow Leopard 10.8 on 1 (wireless), and XP on one (wireless). Also...
Sometimes this problem occures when you install a later model wireless router.
Try installing the latest Wireless card driver on the XP computer and the LAN card drivers on the other computers except the MAC.
Dec 31, 2009 | HP LaserJet P2015n Printer
Excel stops responding during the saving process
There may be following one or more reasons:-
1. MS office 2007 is currupt
2. System has a virus
3. Windows OS is currupt. (Make sure you are running MS Windows Xp SP2)
Here is the solution:-
1. Scan system with a good legal antivirus
2. Repair OS using utilities win Doctor or from win Xp installation disk (upgrade)
3. Repair MS Office 2007 by going Office Button --> Options --> Resources --> run Microsoft Diagnostics
Zulfikar Ali
Jan 23, 2009 | Microsoft Office Professional 2007 Full...
No sound in win XP sp3
please check out in my computer systems device manager if anything in the sound section is in red or yellow remove it. unless win xp was made for your laptop the drivers are not there. you need to go to compaq web site and download your drivers.
Nov 28, 2008 | Audio Players & Recorders
Drivers
I lost my CD for my LARGAN chameleon XP digital camera. where do I get the driver for it?
May 16, 2008 | Largan Chameleon Digital Camera
Xp hangs and pc stop responding during Xp installation.
Location off viruses is on SYSTEM RECOVERY and it can't be cleaned.It's just one way:
If u can change the PIN off HDD.It can do just programmer!
So my solution is just buy new hdd
Nov 23, 2007 | Computers & Internet
Compaq Presario 2580US Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
