Question about Husqvarna Designer I
Service Menu For Husqvarna Designer SE
I would like to go in and adjust the thread tension of the machine but do not know how to get into the service menu.
  • wdewling Feb 01, 2009
    Ok thats great ,I got it to the part of entering a password now ,any ideas on what the password may be.Thanks SewTechWayne , heading the right way anyway .I have the entire repair manual for this machine but no password
    thanks
    Bill
Hi SewTechWayne, do you happen to have the latest pass code? 5031 is no longer working on my machine. Thanks!
Posted on Jun 10, 2010
    New Friend:
  • 186 Answers
Hold down the start button and the presser foot pivot buttons at the same time and turn on the power. The machine will make a funny noise and the test screen will come up. You then need to find the sub-menu, I think it says tensions on it but I'm not sure.
Posted on Jan 31, 2009
  • SewTechWayne
    SewTechWayne Feb 01, 2009
    I can find out tomorrow for sure, but try either 5277 or 5031. Let me know if either of these don't work.
  • ROBERT HENSHAW
    ROBERT HENSHAW Mar 02, 2018
    5277 or 5031 don't work
Husqvarna designer se / bottom tension loose
If the bobbin thread is simply laying on the surface of the fabric, you need to increase the top tension. The tension is correct when the bobbin and top threads meet in the middle of the fabric.
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Jun 16, 2017 | Husqvarna Sewing Machines
How do I turn off thread portioning on Husqvarna Ruby De Luxe. I don't want to adjust the settings but need to turn this off. Thank you
FWIW, I was unable to find any information for turning off the thread portioning function. Unfortunately, this appears to be the thread tensioning system, so disabling the thread portioning would be disabling the thread tensioning--something that is critical to sewing. It appears this model may have some issues and perhaps this one is particular to your machine. It may be best to take it for service.
Perhaps this will help:
Husqvarna Viking Designer Ruby 25 Tension Thread Portioning Deluxe Stitch...
Husqvarna Viking Designer Ruby 22 Bobbin Thread Sensor
Husqvarna Viking Designer Ruby Review Sewing Insight
Jul 01, 2016 | Husqvarna Sewing Machines
Distorted embroidery with Designer SE
have you tried changing the needle
try rethreading the machine top & bottom
also clean under needle plate area & bobbin area for loose threads & lint
Jan 27, 2012 | Husqvarna Designer I
I am having trouble with the free motion on my Viking SE. I can feel the thread sticking up on the back and the top thread keeps breaking. I have tried changing thread (four times) and changing needle...
I presume you have set the machine for free motion quilting in the Menu? There are so many things that could be causing this, and so many variables for tweaking it to optimum performance. What foot are you using? What thread? What needle? What menu setting? Have you tried loosening the top thread tension? Bobbin tension? I will keep a lookout for further posts from you with a bit more info that we can start working on. I have a Designer1, not the SE, but have used an Se so will try my best to help.
Dec 15, 2010 | Husqvarna Designer I
Can not adjust the upper thread tension tight
If you are adjusting the upper tension on your machine and yet there is no difference to the sewing, it seems to me that maybe your upper thread is not in the tension disks correctly. Re-thread taking care to make sure the threads bed down into the tension disks. I pull off about 2 foot of thread from the spool and put my right-hand finger on the thread very close to the spool (the idea is to hold it down so it doesn't move) then use my left hand to take the thread through the thread run. Once I get close to the needle, I tug the thread a little and you can hear/feel it go into the tension disk.
Sometimes it looks like the top thread is the problem, but in fact it is the bobbin which is at fault. Re-insert your bobbin again taking care to click it into its tension slot. If you are still getting bad results, try loosening off the bobbin tension. Use a tiny screwdriver to turn the tension screw (the one just on the outside of the tension slot). Turn it no more than 1/5th of a circle at a time (to the right to tighten, to the left to loosen) then put bobbin back in and test. You should not need to adjust it more than two or at most three times. If you do, something is seriously wrong with your machine's tensions and it needs to see the Sewing Machine Doctor.
May 25, 2010 | Husqvarna Designer I
Designer 1 Embroidery Bobbin problem
Designer 1 bobbin case tension adjustment:
When the bobbin runs out, sometimes it bends the bobbin case tension spring. Then tension is too light. Take the bobbin case out of the machine. Tie the loose bobbin thread to the Designer 1 needle plate. Insert the bobbin in the bobbin case. Here’s the tricky part set the bobbin case on the table as if it’s in the machine (Bobbin is visible and sitting horizontal to table top) threaded as if sewing and loose end tied to needle plate (that is removed from the machine). Lift the bobbin case off the table rotate it so that the flat side of the bobbin are vertical to the table and no longer horizontal. Have the bobbin case oriented so that the thread coming out of the bobbin case sprint (slot area where it is put for sewing) is at the top. Lift it high enough that the needle plate is lifted from the table. It should not release thread unless you shake it gently and then a very small amount of thread. The needle plate is the exact weight resistance your bobbin case should have on the thread.
Oct 28, 2008 | Husqvarna Designer I
Breaking thread
Try adjusting the tension in the "Set" menu. "Tweaking" anything else may end up costing money.
First, make sure the hook area under the bobbin case is free of debris. Try a new bobbin and a new spool of thread with a new needle, full inserted. If the needle threader isn't lining up, the needle may not be in right.
Jul 12, 2008 | Husqvarna Designer I
Satin Stitch Problems - Designer SE (similar to the Designer 1)
It sounds like to me you might have some thread stuck in the tension assembly. Possibly some thread "snubs". Also there is an internal service program on this machine that could also solve that problem. That is why you need to take it to a qualified Husqvarna service center to be fixed by a qualified technician.
Aug 09, 2007 | Husqvarna Designer I
Sewing Machines Logo
1,543 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
