Question about Samsung DLP HL-P5663W 56" TV
Loud buzzing sound/ no picture samsung HLR4667WX/XAA
Replaced lamp. no problem. then picture went green then out with a loud buzzing sound. will not turn off. had to unplug. plug it up after days go by and still have no picture just buzzing. still can not turn off.have read posts about color wheels and fans. any ideas. if i open the set how do i tell what is bad?
  • 1 more comment
  • homan Mar 24, 2009
    I have the same problem as John1327 on the exact same TV. Only difference is that my picture flickered and then went out. Buzzing sound and all symptoms started happening
  • Anonymous Apr 06, 2009
    I have had same problem w/ my TV. When the problem started, the picutre just went out but sound continued. Then an irratic buzzing noise occured. The LAMP light started flashing by the start button. I replaced the lamp ($167!) and still no picture and the irratic buzzing continues and stops afte about 5 minutes. The LAMP light indicator near the start button stays lit. TV will not shut off unless I unplug it.
  • jessgarr Apr 14, 2009
    I have the same problem with our Samsung. We replaced the bulb about a month ago and now the picture is gone and I only have sound. As well as a loud awful buzzing noise. Mine's vibrating the back of the tv. It won't shut off and when it does it turns itself back on. The lamp light is also now flashing again.
3 Suggested Answers
SOURCE: Samsung HL-R6167W DLP color problem/buzzing noise
My 3 yr old Samsung DLP has the same buzzing noise, had a tech out today and he said "color wheel". Thank goodness I purchased that expensive warranty, This is my 4th repair in 3 years.
Posted on Sep 26, 2008
dmon_67
  • 9 Answers
SOURCE: My Samsung model HLR4667WX/XXA is
It is easy; just look for a video on you tube and with a screwdriver and some care you can fix replace the color wheel yourself.
I replaced mine in fifteen minutes. Note, I had to replace my ballast prior to this so I had a little experience.
Good luck.
Posted on Feb 25, 2011
Samsung hlr4667wx/xaa
can be this one Samsung BP47-00027A
or this one Samsung BP47-00021A Lamp Ballast would say it is this one 00021A as its on its listings. http://www.ebay.com/itm/Samsung-BP47-00021A-Lamp-Ballast-/331036842455?pt=US_TV_Boards_Parts_Components&hash=item4d135559d7 54.11 USD.
Mar 28, 2014 | Office Equipment & Supplies
My Samsung DLP tv Model HLP6163w/xaa shuts down , the two green and timer red ligts fliker
l need some information here:
Does it work at all or fail upon trying to turn it on?
When was Lamp replaced last and have you inspected the lamp?
Have you or do you hear any high pitched whine or grinding sound or even a loud fan like sound?
Dec 06, 2012 | Samsung Televison & Video
Model code HLR4667WX/XAA won't turn on just clicks
Sounds like you have defective capacitors in the power supply board, cheap and easy fix for those with electronics repair skills
Jul 23, 2012 | Samsung LN-S4041D 40 in. LCD HDTV
Samsung model hlr4667wx/xaa. Will not turn on. I can hear it try. It makes the loading up sound, lamp turns on, but screen is still black. At first everthing would power up ok including picture, but a few...
Have you had a issue where you heard a high pitched whine or fan like sound?
Examine the color wheel- can be done with lamp removed--look in the opening the lamp faces---is wheel intact or missing any pieces?
The set will turn lamp on for a instant and then off if it detects wheel not moving at full speed or not at all.
Mar 27, 2012 | Samsung Televison & Video
Samsung HLR4667WAX/XAA made a loud popping sound, picture went out and then the sound
Your lamp is burnt definitely (lamp makes that sound ,take lamp out and You will see inside lamp) no sound ,because unit goes to protect mode and shouts down power
Aug 08, 2011 | Samsung - Lamp for Samsung HLR4667WAX/XAA...
I have a samsung model hlr4667wx/xaa picture freezes
analog board can cause that symptom especially if the pic is freezing .
Jun 26, 2010 | Televison & Video
Loud rumbling/buzzing for 10-15 seconds and then power goes off
Your Color Wheel needs to be replaced!
Call Mats Electronics for Parts and supplies
1-800-628-1118
Mar 17, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
I have a samsung HL-S4266wx/xaa and about a month ago the screen changed colors to a negative like a photo. so i turned it off and then back on and five minutes later there was a buzzing sound then the...
This is something that cannot be easily guessed at. There may be a failure in part of the power supply, and on one of the processor boards.
You will have to have the Samsung service rep do the necessary repairs on your set.
Jerry G.
Apr 28, 2008 | Televison & Video
Samsung HLR4667WX/XAA television keeps turning off
if it's making a loud vibrating sound it's due to the color wheel shattering. easy to replace sits on top of light engine.
Dec 11, 2007 | Televison & Video
Samsung DLP HL-P5663W 56" TV Logo
1,440 people viewed this question
Henry  Thomas
Henry Thomas
