Question about Fuji FinePix A500 Digital Camera
Memory Card I recently wiped all the pictures off my memory card and now when I turn the camera on it says 'card not initilised' Have looked through the set up menu and still don't no how to make it work!!!!
    Brigadier General:
  • 6,966 Answers
Hi, You can try: Remove/reinsert the memory card; Follow page 74 of the users manual (display set-up menu, < or > till format function, choose xD-Picture Card, Pressing MENU/OK initializes the xD-Picture Card or internal memory. Initializing internal memory takes about 15 seconds. A reminder, The Format function erases all the frames (files), including protected frames (files). Back up important frames (files) onto your PC or another media. Hope this works for you. Pls post again how things turn up. Good luck and kind regards.
Posted on Jul 31, 2007
  • Louie  Role
    Louie Role Jul 31, 2007
    sorry it should be page 75
    Genius:
  • 2,985 Answers
Format the card in the Camera- read your manual
Card not initialized?
The error can be caused by:
1. The xD-Picture Card or internal memory is not formatted.
2. The xD-Picture Card contact area is soiled.
3. a camera fault
for 1.:
Format the xD-Picture Card or internal memory on the camera (p.130)
To format the internal memory or xD card goto format in the setup menu and chose the correct memory.
for 2.:
Wipe the contact area on the xD-Picture Card with a soft, dry cloth. It may be necessary to format the xD-Picture Card
(p.130).
If the message still appears, replace the xD-Picture Card
for 3.: You won't like this one:
Contact your FUJIFILM dealer.
Oct 30, 2013 | Fuji FinePix S6500 Digital Camera
How do you erase all images on a Canon IXUS 1100 HS camera?
If all the pictures are on a memory card, format the memory card. If all the pictures are in the internal memory, remove the memory card (if installed) and format the internal memory.
Formatting wipes out all information from the memory card or internal memory and prepares it for further use. This is better than deleting individual pictures and will help prevent future troubles.
Nov 27, 2012 | Canon PowerShot ELPH 510 HS / IXUS 1100 HS...
I have a nikon coolpix s60 and when i go to view the pictures, the screen turns black and i cant turn the camera off unless i pull the battery
What name brand memory card do you use? I recently discovered myself that Nikon only supports SanDisk, Toshiba, Panasonic and Lexar. Try taking out the memory card and take pictures without the memory card inside the camera. If you can view the picture saved onto the camera memory then you will know that all you need is a new memory card, with one of the above mentioned name brands. Hope this helps.
Mar 01, 2011 | Nikon COOLPIX S60 Digital Camera
Picture on viewer fine..transfer to computer divided
It sounds like the file is corrupted. Try formatting the memory card in the camera. This will wipe the memory card clean and eliminate it from the being the problem. Formatting the memory is erase the memory card and you willnot be able to get the pictures off it after you format it, so make sure you down load all you the pictures you want befor formatting the card. Then occasionallly after downloading everything, format the card on a regular basis. This will help to keep the cards internal memeory from being fragmented. If formatting does not fix the problem, try another card (format it before use) if this does not fix it, take it to a local camera store and let them trouble shoot the problem or send the camera off for repair.
Nov 21, 2009 | Nikon D60 Digital Camera
How do you transfer internal memory to memory card
-Turn On camera
-Press menu button and look for setup menu
-Under setup menu Look for the word image storage then Press Ok button
-Under image storage choose Internal memory then press Ok Button
-Now if your setting is in internal Memory turn Off camera.
-Turn On camera again
-Press review Button to show pictures in Internal Memory
-Press Menu button then Choose Copy.
-Now under copy wil provide three option copy ALL/PICTURE/Exit
-If you wnat to transffer all the pictures to you memory card choose all if selected picture just choose picture.
-Now your picture in internal memory is in your memory card
_Note; You need to set your iamage storage to Auto again for you to able to access or used the Memory card
Nov 08, 2009 | Kodak EasyShare C653 Digital Camera
Polaroid Digital camera saying ''card protected'' and won't take any pictures at all.
Look on the left side of the card to see if there is a lock.
Jul 28, 2009 | Cameras
Memory card is full but there are no pictures on my camera.
Try using the "format" option in your camera's menu. That should wipe the card clean. There's probably a file or folder that the camera can't recognize as being one it created. You might also plug the card into a card reader and open it on a computer. The format option on the computer will also wipe the card clean to start fresh in the camera.
May 18, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Memory Card
have a look in the camera menu for the format or initialize card option, (sorry i cant be more specific - cant find the manual) this should initialize the card, else use a usb card reader to format the card in a card reader on your computer
May 25, 2008 | Fuji FinePix A330 Digital Camera
Using USB Plug, Transferred Photos to Computer and Deleted Them.. Says the pictures are still taking up room on memory card..
Try putting the card in the camera and in the menu, select 'FORMAT' this will totally wipe the memory card, ready for use. You will find plenty replacement cables on Ebay, for about £7.00-8.00
Nov 22, 2007 | Sony Cybershot DSC-T200 Digital Camera
Fuji FinePix A500 Digital Camera Logo
177 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
