Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
I have no power to the refrigerator light or the digital controls
It is a whirlpool side by side, four years old. Refrigerator is on the right with the controls and light mounted by two screw on the left. The inside light or the digital lights indicating the frig setting are not lit up. Can I test the wiring connection without melting down some of the controls...or do I just remove and replace?
Thanks,
Tom
  • 1 more comment
  • toms_usa Feb 01, 2009
    Thanks Peyton,
    Excuse my inexperience, but the control to be replaced is the main control at the compressor and not the the small "circuit boards" of sorts at the temp control knobs inside the frig itself?
    Thanks Again,
    Tom
    Peyton,
    You are the man!...I will replace the main board.
    Thanks,
    Tom
    Peyton,
    The model # is GS5SHAXNL00...sorry for the delay.
    Tom
  • 410 Answers
Your actual problem on this is the main control in the compressor compartment. unplug your refrig then remove this control unplug all connectors and reconnect. this will probably get you working temporarily In almost every case I've seen we ended up replaing the control board. thx peyton
Posted on Jan 31, 2009
  • 1 more comment
  • peyton thompson
    peyton thompson Feb 01, 2009
    correct! think of it like this. the boards in the refrig are like your keyboard on the computer just an input device. no power nor worky.
    the board by the compressor is the motherboard or computer that sends and receives the power and info from the 2 boards inside.
  • peyton thompson
    If you will give me a model# for your fridge I'll get you a good part number. of course you may have already gotten it. I use the Sears parts system but use the part number they give me to find a better price.
  • peyton thompson
    here ya go pt#W10135090 it is about 81.00 bucks thru sears.com if you anna do a search at some of the other online parts dealers you could probably find it cheaper.  have a great weekend and thanks for using fixya. peyton
Whirlpool gold gS6SHAXMs00 fridge not cooling on right side, but cooling in freezer side. Also, digital readout is blank and it stays about 60 degrees in the refrigerator section. The light bulb in the...
You have a bad control board. The control board is not hard to replace. It is located in the bottom of the unit inside the plastic control board housing on the back of the refrigerator. Just make sure the power is disconnected and the wires are placed on the new board where they were on the old board. Here is the control board to order.
The part comes with a 365 day, any part, any reason return policy.
Regards,
Richard Roth
http://appliancecafe.com
Nov 06, 2012 | Refrigerators
I have a whirlpool side by side refrigerator model no GS5SHAXNB00 refrigerator light blew this morning i replaced the bulb no lights working on refrigerator side and temp control settings
you need to replace the main/board for sure located in the lower rear left hand wall of the unit in a plastic case, it will have 3 wire harnesses unplug the unit,undo the plastic container and unplug the the board and there will be a burned spot on the case and burned trace on the circuit board, reason being,this is very common on any of these sideXsides,if a light blows out in the refrige compartment it puts a surge on the board and burns the circuit trace open,this makes the digital temp read-out go dark and if the lamps light at all they "strobe" dimly or not at all,and you will hear a clicking of the relays in the rear area trying to latch the light bulb circuitry, but cant because the main/mother-board is defective now
Mar 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Whirlpool sise by side thats about 4-5
you need a new control panel, if your light bulbs blow out it surges the control board and ruins the control board and your symptoms of no lights and temp control points to the control board
Nov 03, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE refrigerator is the worst product I have even
Well, i have to jump right in here and agree with you. I have been working on appliances since 1971 and GE is the most frustrating, highest priced replacement parts ( for the most part ) of all brands. Of all the brands, Whirlpool and Maytag have been the longest lasting, best priced and easiest to work on. I truly feel sorry for you....really.
May 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool GD5RHAXNT00 Side By Side Refrigerator
your  problem on this is the main control in the compressor compartment. unplug your refrig then remove this control unplug all connectors and reconnect. this will probably get you working temporarily In almost every case I've seen we ended up replacing the control board. thx peyton
Feb 07, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
The light and digital controls on the refrigerator side dont work
I replaced a circuit board that is in the white box at the lower left rear of the fridge. You will need to remove the cardboard cover, then there is two screws to loosen the box. The circuit board is inside. There is a white tab that sticks up push it sideways and it will pop right out. Put the plugs in the new board and pop it back in and put everything back together. Be sure the wires are routed so they do not contact the compressor.
If you want to test it first get a voltmeter one probe to CN1, the white wire, and the other to CN2, yellow wire with red stripe, there should be 120 volts. If not, or when the door is open it drops replace the board.
I did not have a voltmeter but it seems everybody that had a problem the fridge was 4 to 5 years old. So I bit the bullet, around $90.00, and replaced it and it works!
Dec 29, 2008 | Whirlpool GD5SHAX Side by Side...
Whirlpool refridg side by side
This sounds like the compressor is bad. The clicking sound is the start relay trying to start the compressor and cannot. You stated that it was only four years old. Check the warranty for your frig. Most carry a five year warranty on the compressor.
Nov 10, 2008 | Whirlpool ED5FHEXMQ Side by Side...
Ticking noise getting louder, 30-year-old Whirlpool SbS Refrigerator
Hello strebig
Welcome
You said, you have a ticking noise in your 30 year old refrigerator?
Before we get started here.
Do you know thee efficiency difference between your fridge and any new one?
My fatherly advice is do not put another nickle in to your fridge.
You are putting good money in to bad!
Unfortunately you all ready spent the cost of a new one in the past ten years on electricity.
Today's new refrigerators will pay for them self in a few years and then be a hell of a lot less on your electric bill.
The change from a 30 year old fridge to today's models WILL show up on your electric bill!!!!!
I just read this article that you may find interesting.
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Please remember to enter a rating before you sign off!
God Bless, Thank You, HUUUM
Oct 05, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool refrigerator stop cold but frosting bad
Hello Catherine Fu,
Welcome
You said, you got this whirlpool double door refrigerator for 4 years. cost me about 1.5k. the second year, right after warranty, the main brain is down-the light panel in the refrigerator is off. whirlpool tech told me to replace it will cost me 500, so you decide not to do it. Now you have bad frosting issue for 6 month. Inside the Refrigerator, the water keep on dripping on side wall and glass drawer ceiling. In the freezer, frosting all over each drawer, and the bottom drawer has too many frosting and ice that i can hardly close the door. Last night, the refrigerator section just don't get cold anymore, it shuts up by itself.
Help!! It is an very expensive refrigerator and ONLY 4 years old .
First,I think you need to have a new tech.
It sounds like you have either an air leak allowing out side air in and this causes the icing.
Or you may need some freon (coolant gas) .
If your freon pressure is low it can ice up.
Did that tech that was there check for a freon leak and also check the pressure of the freon in the lines???
You need to call a different tech and let him see what's happening.
Some company that is reliable!
Let me know what they do for you.
God bless, Huuum
please remember to leave a rating.
Sep 28, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge/freezer not cool.
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
I believe your problem is an old thermostat or compressor !
How old is it?
My advice is do not put good money into bad!
A new fridge will pay for itself in a few years by using a lot less electricity!
Here is an interesting report I just read!
Repair or replace?
Thanks for giving me the opportunity to help!
Please remember to leave me a rating before you sign off!
Thank You, HUUUM
Sep 20, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
137 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
