Question about Harman Kardon HK595 Computer Speakers
Why is my speaker screen keep saying that i have my headphones on
Are my speakers set wrong or what please help
Turn up vol on computer
Posted on Jan 31, 2009
Headphone jack not functioning properly
This is the normal way for this laptop ..leave it always with the headphones on selected in that list ..cause if the main speakers don't work well there is no point in using them ..This way you will run whatever yo will plug in ..speakers or headphones..The only setting difference in headphones and stereo out ..is that for headphones will but the speakers of the laptop when plugged in ..This way it will even help you if the speakers are making weird noises cause they are damaged ..
Dec 22, 2011 | Computers & Internet
Dear Sir, Speakers are working but headphone is not working please tell me the solution.
Well you can only play sound through one device at the same time. If you wish to change the device to play audio from, using windows 7, go to the bottem corner of your screen, to the system tray. You will there see a speaker icon, rightclick it and click sound devices. Then figure out which device your headphones are (if there's multiple speakers showing up). Click the speaker you want to use and click the set as standard button.
You may have to restart the applications currently playing sound in case they don't play sound anymore or they still play through the wrong device.
Jul 24, 2011 | Computers & Internet
Despite having disconnected all the speaker cables, protection light keeps flashing
HI...
ALL speakers need to be connected. and if this has settings for 2 sets of speakers , , use the A spkr setting and the A output connects.
If still flashing , try just headphones. If still bad, it will need service.
PLease rate my help if this helps
Sep 25, 2010 | Cambridge Audio Azur 640A Amplifier
Nano won't play music just through my headphones-
1 Please check the headphones on any other device to make sure that there is nothing wrong with them and they are functioning normally. 2 Switch on the Nano and press MENU 3 Go to settings and go to clicker. It will show 'speakers' 4 Press the center and it will change to headphones. 5 Set it there. 6 Similarly you can adjust the volume.
Jan 22, 2010 | Audio Players & Recorders
My speakers wont work suddenly unless I am using my headphones
Make sure in the volume mixer that it is using the right sound device. You most likely have it set to the wrong device output. When you plugged in the headphones in kinda automatically switches, but to use the speakers again you have to do it manually. Just hook up a cheap av receiver to your computer and use this headphone input instead. a 100$ 5.1 av receiver beats any pc speaker system.
Aug 01, 2009 | Toshiba (4CH-VOUT) Sound Card
Headphone jack on 22 inch flat panel tv
You are on the wrong website for this type of inquiry. This is a self help website for the repair and use of manufactured products made for consumer use
Jun 27, 2017 | Televison & Video
Low sound in headphone
I would say it is because the unit does not have a built in amplifier. The speakers are powered PC speakers of studio monitors I am guessing. Try plugging the headphones into the headphone jack of the speakers if they have a headphone jack or try a set of powered headphones out of the Edirol and see if it helps.
That should remedy the problem.
Dec 27, 2008 | Edirol UA-4FX External Sound System
Can the cable ends be converted to fit a DVD?
You can certainly purchase a cable or an adaptor to connect the speakers to almost anything - this however is not the issue - z5300 computer speakers have an impedance of 8 ohms, whereas most home theatre systems will be set up to use speakers with an impedance of 4 Ohms or 6 ohms or 8 ohms - using the wrong type in the wrong configuration is very likely to result in damage. Also the speakers contain their own amplifier, and are designed to accept an input that has not been amplified to speaker levels before - most tv/dvd audio output will be amplified, depending on the model, so will almost certainly destroy your speakers unless you have a low amplification output on your tv/dvd. If you post back with the make and model of your tv and dvd player, hopefully i can find the necessary info to describe how you could make the connection if it is possible. Logitech says; "Logitech speakers are powered speakers and are designed to be used with a home computer. However, it is still possible to connect your speakers to many other devices. You can connect any Logitech speaker to any device that has a pre-amp mini-headphone jack. Home amplifiers will normally contain a standard ¼" headphone jack. You'll need to purchase a ¼" to 1/8th" adapter to connect your Logitech speakers to a home amplifier. Note: Under no circumstances should you connect your Logitech speaker system to an amplified output such as the rear outputs of a home amplifier. Doing so may cause damage to your Logitech speakers as well as your home amplifier." Hope this helps - please post back with details :)
Apr 19, 2007 | Logitech Z-5300 Computer Speakers
No sound coming out of speaker, but headphone jack works!
Hi, I had the same exact problem. The speakers wouldn't work but sound came out of the headphone jack.
To fix my problem, i opened up the subwoofer unit and checked the fuse on the circuit board which seemed fine. Then i had a look at the wiring on the other side of the circuit board and noticed one of the wiring had fried leaving a gap in the connection and exposing the copper wiring. So i just soldered the two bits of wire together. Works fine now!  I just had to be careful when i finished soldering that the exposed wire wouldn't touch any of the other connections. I insulated the wires with a glue gun to keep it all in place.
hope this helps.
Jan 22, 2007 | Logitech X-530 Computer Speakers
Harman Kardon HK595 Computer Speakers Logo
55 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
