Wireless Internet connection
My BT internet connection has stopped working.The network support centre on my computer tells me to switch on by using a switch or key combination on the computer. How do I do this? I have an Advent 9517.
  • 258 Answers
Look for a button with waves or curves on it, something like this
http://netsysblog.unet.brandeis.edu/blog/wp-content/uploads/2008/07/wireless-icon.gif
or
http://www.psln.com/img/logo_wireless_icon.jpg
if may either be on the keyboard or a switch elsewhere on the computer
If it's a function button hold down the Fn key as you would the shift key and tap the key with the icon on it to turn the wireless off or on, look at your screen when you do this and it should show whether it's turning on or off
Posted on Feb 01, 2009
I have had my fujitsu siemens for nearly 4 years. When I first go it I had huge problems connecting wirelessly. BT did however seem to sort the problem. It was fine for 2 years, but again I'm having to use...
Yes if it's just Bluetooth you're trying to get to work by a new BT dongle. If wireless and BT are on the same card buy a new BT/wireless card This one Desktop 802 11ac Wifi Bluetooth 4 0 Dual band 1300M Wireless AC PCI... Works great. Try to stay away from Intel I had to replace two of them in the last six months. The link above uses Broadcom and works fantastic.
Jun 28, 2017 | Fujitsu Siemens Computers & Internet
I usually connect to my neighbor's wireless internet. We have had no problems until this morning when the connection to the internet just dropped and stopped working. I have the Linksys WUSB54GSC and it...
Usually such problems occur when the administrator to the internet service decides to block a particular user from accessing the internet or sets a password for users on the internet. The best bet is to contact your neighbour as he will be the best person to tell you what happened.
Hope this solution has been helpful?
Sep 23, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
Internet connection won't register on compaq laptop
You must go into "Internet Connections" and enable your ethernet/ LAN connection. It is advised to disable the wireless connection in the interim. Thank you, Dana
Feb 15, 2010 | Computers & Internet
Hi could you tell me please how i set up a wireless connection on my bt home hub thanks
First you will need a wireless router.Once you have this you will need to take a conection from the existing hub to use as a source for the internet.Configure the router as per instruction.
Good Luck
Oct 17, 2009 | Computers & Internet
Comp will not connect to internet and tells us there is a cable not connected. It is wireless and the modem is working with all other comps in house. I have checked the modem, switched it off and...
have you installewd the drivers for the modem ? if you have go to desktop and click settings got to network settings open this up it should show any connected networks if not click new connection then go throught the proceedure you can try the first internet connection if not try the advanced option for the wireless.. make sure you installed the wireless drivers as well a it wont work without these.. Good Luck A
Jun 30, 2009 | Advent Netbook
I can't access my wireless internet, asking for a pass phrase
the D Link router is what is causing the issue - Cut your losses and get a linksys ( netgears are ok so maybe one of those ) but avoid D Link and Belkin equipment as far as wireless or networking goes.
An apple airport extreme ( although a bit more expensive ) are very good.
Jun 28, 2009 | D-Link DI 514 Wireless Router (DI-514)
Internet !
hello there!! thanks for using Fixya.com!
You know what, I had the same problem couple of months ago. But I suggest that you should enter manually the network settings for the WLAN internet connection.
You have a pretty common configuration and there's good and bad news. The good news is that yes, you can definitely get your Sony PSP onto the Internet with the setup you have. The bad news is that I'm not exactly right when I say "with the setup you have" because you're going to need to buy what's called a wireless router to connect.
Basically, the setup you have works like this:
highspeed Internet connection from service provider (BT in your case) connects to highspeed modem connects via Ethernet cable to your computer.
While you can configure the wireless network with a password, since the Sony PSP claims to support the various secure wireless protocols, my experience is that it never connects properly. Instead, I suggest you leave it password-free, though it's not particularly secure. If you have good neighbors, you're probably safe...
Or you may just simply:
Wireless network connection Step1Turn on the “WLAN” switch on your PSP when you are in range of a wireless access point. Step2Select the “Network” option on the “Home” menu. Step3Select the “Internet Browser” option and then press “X.” Step4Use the Up and Down direction buttons to select the address bar. Step5Press the Circle button to display the onscreen keyboard. Step6Use the onscreen keyboard to enter a Web address. Step7Select the “Enter” key and then press button “X.” Step8Select a connection and then press “X” to display the Web page. jQuery('.Article .Steps .Image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); good luck!
Feb 12, 2009 | Computers & Internet
Xbox 360 connect to xbox live with out wirelless adaptor
wel your o2 router is basically ur internet so if that does not work i reccomend you switch to broadband and buy the wireless adaptor for the xbox 360 and use that if you dont no how to set that up send me an e-mail to reece16cc@hotmail.co.uk and i will walk you through it step by step till ur up and running AND PLZ RATE THIS FOR I WILL NEED YOUR VOTE TO CONTINUE HELPING OTHERS WIT THE SAME PROBLEM YOU ARE HAVING TANKS.
Nov 26, 2008 | Microsoft Wireless Network Adapter Xbox...
Belkin F5D8630 wont take my new log in details
check to see if all of the ssid's are all the same or if there is another wireless system interfering.
Sep 11, 2007 | Belkin (A3L85014BLS24)
Computers & Internet Logo
478 people viewed this question
David Payne
David Payne
