Question about Poulan Pro Chain Saw 46cc 20"
I have a p3416 poulan chainsaw it cuts off while using like you cut the switch off and is hard to start. is it normal to have air bubbles in the gas lines for the primier bulb when priming? david
I have a Poulan PRO PP4620AVX can not get it started. I have replaced the spark plug and it pulls hard.
Posted on Oct 12, 2009
  • 47 Answers
Some bubble is normal but inspect your fuel line for cracks sounds like your sucking air hope this helps
Posted on Feb 08, 2009
Can I run an 18in bar on a 16in chain saw
you should be able to without issue.
The Stalling issue started after lengthening the bar/chain?
Dec 23, 2014 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Will not stay running
Clean carburetor-verify fuel line blockage-clean filters-make sure your gas/oil mix is correct-use fresh gas. They shut down frequently when setting them down-Increase RPM at Idle.
Jul 27, 2014 | Poulan P3416 16Inch 34cc 2Cycle Gas...
I have a POULAN PRO 3516AVX chainsaw that I have to tighten the chain after every cut . What gives?
If the chain is stretching then it is either poor quaility chain, or there is not enough oil getting to the chain, it is impotant to use a non fling chain oil so as to lubricate the bottom of the bar where most cutting is done. hold the tip of the bar close to a clean peice of card board, rev the saw, there should be a good line of oil showing on the card board.
Sep 15, 2011 | Poulan P3416 16Inch 34cc 2Cycle Gas...
I just bought a new Poulan Model P3416 chaisaw (34cc) and I have followed the starting instructions and have not been able to start the saw. I have even varied the instructions but no luck. Any thoughts...
see if your switch is in run position and then pull your spark plug out see if it is wet, then see if it is sparking when you ground it and pull cord to roll over, if all is good hold throttle wide open and crank over without choke on, probably flooded, good luck
Aug 19, 2011 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Engine starts, runs, chain goes around, but cuts very weak, leaving black marks on the wood from rubbing but not cutting
You have a dull chain. Check out the video below to learn how to hand sharpen the chain:
Thanks for choosing FixYa,
Kelly
Jul 14, 2011 | Poulan P3416 16Inch 34cc 2Cycle Gas...
The saw is a poulan 3416 ,2 yr old, purchased new. the problem is starts ok 6 primer pushes idles ok then will either die after first cut or as soon as you pull trigger
Run too lean, this is fuel starvation, remove the fuel line from the tank and replace the filter on the end, check the fuel hose from the tank up to the carb for leaking or cracking.
May 14, 2011 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Starts fine but just as I start to cut the wood it bogs downs and sounds like it is flooding out. I can back it off, rev it up and the same thing all over again.
It is unusual for a machine to richen up when it starts cutting, chainsaws normally run a little rich free running, when they start cutting they need the extra fuel to keep it going under load, it is much more likly it is running too lean, start by cleaning the air filter, if there is a spark arrestor in the muffler take it out and clean it ( a gauze in the exhaust outlet ) pull the fuel filter out of the tank and replace the filter on the end, failing this it may well be a carb adjustment required, there is a special tool required to adjust many of these carbs ( the screws are splined ) this will require a workshop adjustment, or making a tool to fit over the screws so as to turn them, try using a short peice of tube that fits tight over the screw, push a suitable screw driver in the end od the tube to allow you to turn the screw, turn the H and the L screw out 1/2 turn on each , has this improved the running, if so it is running lean.
Feb 07, 2011 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Poulan p3416 .3 1/2 years old . gas cap has become really tight,from the first turn
Poulan.com
http://www.ordertree.com/modelinfo/PWE/P3416-Gas-Saw-Type-2/75.P3416-Gas-Saw-Type-2.1.59.1.html
Handle, Chassis, & Bar Assembly
Item 15, $3.09
Maybe a little cross threaded or swolen from contact with fuel.
Please verify this is your fuel cap. HTH
Lou
Oct 29, 2009 | Poulan Pro Chain Saw 46cc 20"
34 cc Poulan,dies out when tipping it to side to cut tree.
I would check the fuel line for a pinhole or crack.It may need replaced.
Mar 14, 2009 | Poulan Pro Chain Saw 46cc 20"
My Poulan 3500 chain saw will not start
My guess is that one of your fuel lines has a crack or small hole in it. Inspect these and replace if needed. let me know how it goes.
Feb 17, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro Chain Saw 46cc 20" Logo
323 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
