Question about Kenmore 53642 / 53644 Side by Side Refrigerator
I have a Kenmore 106-53642300 side by side, it stopped making ice so I checked the emitter codes according to what I've read they are ok blinks twice 1 sec delay (repeated) when I close the other the light stays on. So I got a new Ice maker and filter it took forever to fill up with water but it did and it never ejected the ice, so now what????????????????
Could water be frozen -try heat gun not too much heat
Posted on Jan 31, 2009
I have a Kenmore side by side refrigerator-Freezer. The ice maker stopped making ice. There is an "off-On" switch in the freezer along with a red light. The light keeps blinking. Can you give me...
Hi and welcome to FixYa, I am Kelly.
Here is a Job Aid that will help you:$FILE/4322658A.pdf
Testing the optics starts on page 25. You must follow the instructions verbatim as far as time lines or you will have to start the test over.
NOTE: There are 2 types of Optics. Pre 2002 and 2002 Optics. Make sure your performing that optic test that is a match for your unit.
Take a look at the charts on page 30. From here is appears that either the optics are blocked or
the emitter board has failed. Do the tests and follow the troubleshooting procedures to confirm this.
Thanks for choosing FixYa,
Oct 26, 2010 | Kenmore Freezers
Not making ice!
Try removing it and let the ice thaw. The mechanism for the rake to push out the ice can freeze up.
Apr 30, 2010 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Need to disassemble a Sears Kenmore 106.57372700
Sounds like the IM heater stuck on that's the only thing that would have melted liner. Check the optics open the freezer door and push the flapper on the right side back and look for a green light if it's on solid optics are ok if there is no light or flashing replace the emitter and receiver
Feb 16, 2010 | Whirlpool GS2SHAXM Side by Side...
Ice maker not making ice. red light on control panel blinking twice.
Remove the ice bucket and inspect the ice maker for an ice cube stuck in the ejector. Hit it with a little heat of a hair dryer till it gets loose and the ice maker starts rotating. Replace the ice bucket. See if it starts making ice again amigo.
Jan 31, 2009 | Kenmore 53642 / 53644 Side by Side...
The most likely cause is the water solenoid behind the fridge. Take an ohm meter and test across the two terminals and it should NOT ohm out (beep). If it does not ohm out I would replace the P.C. Board kit, emitter & receiver icemaker control.
Jan 04, 2009 | Kenmore 53642 / 53644 Side by Side...
Ksra25i kitchenaid refer ice maker
Probably the infrared emitter and receiver that are on opposite walls just inside freezer door near ice bucket.
Oct 31, 2017 | Refrigerators
Kenmore side by side refrigerator model 106.5702 will not make ice.
your ref board seems to be working fine
Did you test the water valve???
if yes and water valve works, than replace the Ice Maker
May 11, 2008 | Kenmore 53703 / 53706 Stainless Steel Side...
Ice maker won't stop making ice
souonds like that sensor has gone bad, doenst know its full and contionues to make ice. youll need to repalce the electronic board.(they come as a kit both emitter and reciever,)
Mar 08, 2008 | Kenmore 55693 Side by Side Refrigerator
Ice maker repair and still no ice
Amyc, of course you should call this cat back, but here are a few things to check. Make sure that the fill tube is not frozen over. The black tube feeding water to the IM. Next with the freezer door open your optics should flash twice with a pause repeatedly. Hold the left side emitter flap down and the light should be on steady. If this checks, the optics are good. The ice maker rakes should be at the 2:00 position when it's in it's home positon. Any other position could be a bad module. When the cat comes back to check it out, make sure he jumps the ice-maker to get the unit to fill before he back.
Mar 02, 2007 | Kenmore 53582 / 53584 Side by Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
228 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
