Question about Roper RAS6233KQ Top Load Washer
Roper wash machine ras7133kq1
The wash machine is making a loud humming noise when it agitates, spins, and drains. The only time it isn't making this noise is when the machine is filling. Could it be the motor or transmission?
  • wicklertracy Feb 01, 2009
    Thank you so much! That was exactly the problem. Found a bobby pin stuck up against the impeller. Could not have fixed it without you!!
  • wicklertracy Feb 02, 2009
    you did an awsome job fixing my first problem..how about this one? Since reassembling the washer..it works great until it spins..makes a knocking sound and the clothes are still wet after spinning. Any ideas?
  • 640 Answers
No theres something in your pump,,it up against the impeller in your pump.....onthejob
Posted on Jan 31, 2009
  • onthethejob1
    onthethejob1 Feb 01, 2009
    tracy bookmark me for later..onthejob...your welcome
  • onthethejob1
    onthethejob1 Feb 02, 2009
    was this your original problem...
I have a Roper ras7133kq1, top load washer. About 3 months ago I replaced the lid switch because it wouldn't drain or spin. Now it will ONLY spin, it won't fill with water or agitate, the only way...
If it won't fill you will need to replace the "water inlet valve" on the back of the unit. The unit will only agitate if it gets the signal from the water level pressure switch.
Here is the valve to order.
Nov 22, 2012 | Washing Machines
How do I check lid switch without taking machine apart. The model is RAS7133KQ1. Will not drain or spin.
Unfortunaetely there is no good way to check that with out getting to the contacts and ohming them out to make sure that the switch is bad....most of the time though it is not hard to pop the top of the machine enough to check that...just need to find where the tabs are located and pop them with a screw driver...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 02, 2010 | Roper RAS6233KQ Top Load Washer
Washer is loud, and won't spin or agitate
check the motor bushes,and also check for bearings in drum you can check this by lifting the inner drum up and down if you feel a knocking noise then this will be the bearings have worn.
Jul 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Will fill and drain, not agitate or spin though
I am having the exact same problem with the same brand machine.  I put in a load of clothes to soak till the morning, but in the morning, the washing machine would only fill, spin, and drain.  The agitator would not wash the clothes, so they came out with the soap of course still crusted in.
Jan 22, 2009 | Roper Washing Machines
Agitator Noise of Roper RTW4305VQ
yes this noise is normal.its the dog ears ratcheting in the agitator
Jan 19, 2009 | Roper RAS8244KQ Top Load Washer
Loud grinding motor protesting humming w/no spinning or agitating
The drum/agitator bearings are bad I believe, or the gearbox has been damaged. This is an expensive repair. I would strongly consider buying a new washer. This is a great time to buy appliances since the stores are really competing, and the prices are at their lowest.
Ray
Dec 14, 2008 | Kenmore 22422 Top Load Washer
Model numer RAS6233RQ0...only get humming sound, and nothing else
yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
Jul 24, 2008 | Roper RAS6233KQ Top Load Washer
Roper(whirlpool) washer will not spin model # ras7133kq1
check the motor coupler between the motor and the transmission
Mar 17, 2008 | Roper RAS8445KQ Top Load Washer
Roper RAS6233KQ Top Load Washer Logo
230 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
