Question about SanDisk Sansa Clip MP3 Player
USB wont download and wont charge
Well, i got a SANSA 2GB MP3 today and i was so happy!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! But when i got home i then plugged my MP3 in using the USB and it was fine but it then started making this really really annoying noise every like 10 seconds AND what the manual said to do just DIDNT wrk and im REALLY REALLY REALLY REALLY REALLLY ANNOYED.
  • Anonymous Feb 02, 2009
    My computer won't load the Sansa's uploading screen so I'm stuck with the songs i've got on it atm
  • 22 Answers
For some devices you will have to load the device drivers first then connect the device by usb.  The device should have come with an installation cd.
Posted on Jan 31, 2009
My mp3 player wont charge but will turn on when pouted in
connect the Sansa (via the player's USB cord) to different USB ports on the computer until the Sansa starts to charge. A weak or non-working USB port won't charge the Sansa.
  • Reset the Sansa MP3 player. Slide the player's "Power" switch all the way up to the "On" position. Hold the switch in that position for 20 seconds. The Sansa resets. Try to charge the player.
  • Install the latest firmware onto the Sansa MP3 player. Download the Sansa Firmware Updated (link in References), and then click the link in Resources for the specific model of Sansa you own to learn how to update the player's firmware.
  • May 01, 2012 | Kitchen Appliances - Others
    Can i play SanDisk Sansa Fuze 2GB MP3 Player while charging
    It depends. What's charging it?
    If it's connected to a computer's USB port, then no, you can't listen to it.
    If it's connected to a USB charger, such as you might find for cell phones, then yes, you can listen to it.
    May 14, 2010 | SanDisk Sansa Fuze MP3 Player
    Sansa sandisk mp3 2gb, wont charge
    Sansa San disk 250 2GB doesn't charge via computer but change the AAA battery in the back.
    Sep 26, 2009 | SanDisk Sansa m250 MP3 Player
    My sansa 2gb went dead now it wont charge @ all
    It's either problem with the player or the charger if you usually charge it when you connect to the computer then it's more likely to be a problem on the player itself and it will have to be replaced ,if it has warranty then return it.
    You can also try a different USB cable or USB port.
    Sep 23, 2009 | SanDisk Sansa e250 MP3 Player
    Mp3 2gb sansa veiw wont turn on... but charge screen will show up
    it seems that your player are corrupted.
    it means some of your file are infected with virus and corrupted.
    if you can try to reformat your player i suggest you to do it.
    be aware that if you will going to reformat all files saved are possible to be deleted.
    thanks,
    Jun 01, 2009 | SanDisk Sansa Fuze MP3 Player
    My pc wont let me install new sandisk 2gb mp3 player
    On your sansa, go to "Settings" then System Settings" then "USB Mode," then change it to MSC, if that does not work, try the other modes, just in case.
    Hope this helps!
    Apr 02, 2009 | SanDisk Sansa Clip MP3 Player
    When i connect my sansa clip 2gb it will not charge. it say connected and then goes off. I thought it was charging but when i checked it the battery had died what do you suggest i do to get it working...
    Check for the following:
    USB Cable
    Make sure that the USB cable is properly plugged in and use the original cable.
    Computer in Hibernation mode
    Make sure the computer isn’t entering hibernate or sleep mode while the device is connected.  The computer must be on in order to charge your player.
    USB Port 2.0
    Make sure the player is connected USB 2.0 port (1.1 occasionally causes charging problems).
    USB Port location
    Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
    Battery
    Make sure the battery is fully charged.  It takes approximately 3 hours to fully charge the battery.
    Latest firmware
    Make sure to update firmware by downloading and installing the Sansa Firmware Updater
    Jan 23, 2009 | SanDisk Sansa e250 MP3 Player
    MicroSD wont work in MP3 player
    mp3 player wont recognize videos....jus mp4 will do it if the video is in mp4 format
    Aug 22, 2008 | SanDisk 2GB microSD Memory Card
    SanDisk Sansa Clip MP3 Player Logo
    Top SanDisk Audio Players & Recorders Experts
    Gyula Lacz
    Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
