Question about Microsoft Xbox 360 Controller
My Xbox 360 upper left controller light doesn't work
The light on my controller that shows that it's on and is the first player one isn't working. The other three work, so it must have burned out. Do I replace it, or wait for it to work again? I have a wireless one for the Xbox 360.
  • 42 Answers
The LED most likely burned out. I would just replace it if it is annoying to you.
Posted on Feb 13, 2009
"SET 1" Displayed and remote not working.
You have a Panasonic, they have a feature, in case you have two or three Panasonic units you can program the remote either be used on one, two, three. So if the display lights set one that means the remote control would control set one. There are several ways to change a setting one is in the player menu, I believe you can change the remote. Check your manual, this is not a big deal.
Oct 18, 2014 | Panasonic Televison & Video
Transcend 1TB External Drive stopped working.
Insist that Transcend replace the hard drive in accordance with the warranty.
Mar 24, 2014 | Transcend 1TB EXTERNAL HDD
Flashing start light
see this causes and fix it. God bless you
Drain Pump If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective YOU'LL need to replace it. Drain pumps are not repairable.
Heating Element If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Heating Element Assembly If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced
Touchpad If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Check Fault Codes If the display lights are flashing and there is an error code in the display window, check the Error Codes guide on our website to determine which component has failed or is failing
Oct 03, 2012 | Dishwashers
We have a whirlpool quiet partner iii. It was working fine and was opened mid cycle. Then it wouldnt drain. Then all the lights started blinking. At some point it drained the water out. We flipped the...
see this causes and fix it. God bles you
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Oct 02, 2012 | Dishwashers
Sometimes my tail lights stay on when the lights are not on and the engine is off. Sometimes one and sometimes both and it isn't the brake lights. In addition, sometimes one of signal lights will be...
Wow - electrical issues with Any motor Vehicle are frustrating. I would only suggest not one but two or three calls to dealerships that focus on your car manufacturer and after chats, select one that will trouble shoot the issue with out charge?
Jul 09, 2017 | 1999 Ford Windstar
Well, when i turn on the computer the monitor only flashes it alittle but then it like turns off, and it dosent leave the screen on?
I would first try booting from a boot disk or live cd to make sure it isn't a driver issue. If the problem persists, you may be looking at a damaged monitor. Take a flashlight, and gently hold it to the screen to see if the LCD portion is working. If the LCD is working, but the lamps are not then read on. The most common reasons for a monitor to fail like that are damaged caps, burned transformer, and/or burned bulbs. The control circuitry sends a burst of energy to the bulbs to light them, then backs off to user settings. Most monitors will sense if the bulbs didn't light, and try a couple more times before giving up. I'm in the process of working on one now that exhibits the same symptoms and after opening the thing up it needs three caps, a transformer, and a new set of bulbs. Best of luck.
Sep 18, 2011 | Hyundai ImageQuest L70S 17" LCD Monitor
I have a 1989 Honda civic just had a rebuild what i thought was a blown head gasket turned out to be holes burned into 2 valves.since the rebuild it soots up the spark plugs bad it flashes codes 1 then 10...
Code 1 Oxygen Content-
Code 10 Intake Air Temperature (IAT)
Code 14 Idle Air Control (IAC) valve
Sounds like the oxygen sensor (code 1) is recieving more fuel content (or unburned fuel) than it can measure...
The intake air temperature sensor isn't reading within range because...
The Idle air control valve (basically an electronic choke) isn't opening up to allow enough air into the engine to create a clean fuel burn, creating burned valves (probably intake valves) from unburned fuel.
Aug 30, 2011 | 1990 Honda Civic
Acer x1300 - reinstalled vista and have three yellow warnings in device manager: Coprocessor, Ethernet controller, sm bus controller? How do I fix?
Easiest way would be to use a seperate computer and download the drivers onto a usb stick and use that to install the drivers. You can't download straight to your computer since your Internet won't work (Ethernet Controller isn't installed) You can also burn a CD if a USB doesn't work.
You can get the drivers from here.
http://driverscollection.com/?H=Aspire%20X1300&By=ACER&SS=Windows%20Vista
Jun 05, 2011 | Computers & Internet
Tried three CDs, but display shows disc error
First, try a "hard" reset of the player by physically pulling the power plug from the outlet, waiting at least 30 seconds before plugging it back in.
After it comes back on, try a non-burned disc you know to be scratch free. If this disc will not work, you have a hardware malfunction. Due to the relatively low prices of consumer electronics, it probably isn't worth fixing, unless it is a high-end brand.
May 05, 2011 | Audio Players & Recorders
The screen is enlarged after watching a movie how do we fix it?
Hi melissami133
PLEASE RATE MY ANSWER IF ITS HELPFUL !
FOR XBOX:
With the new Xbox 360 interface, the how-to below is not working anymore! You can do the following to reset your console:
To reset the display settings of the Xbox 360 console to the default settings, follow these steps:
  • 1. Remove any discs from the disc tray.
  • 2. Turn the console off.
  • 3. Turn the console on.
  • Note If you are using an Xbox 360 Wireless Controller, turn the console on by using the Xbox Guide button on the controller.
    Note Make sure that you use the player 1 controller when you do this. The player 1 controller is the controller where the upper-left quadrant light is on.
  • 4. As the console starts, press and hold the Y button, and then pull the right trigger at the same time. This causes the Xbox Dashboard to reset the display settings to the default settings and then automatically restarts the console. So it's OK when the Xbox 360 console restarts.
FOR PS3 :
Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Jan 30, 2011 | Video Game Consoles & Games
Microsoft Xbox 360 Controller Logo
87 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
