Question about Air Tools & Compressors
My garge air compresser keeps blowing fuss
I have wire my air compresser up in my garge like the sells men told me and it run good for a will and then it will blow the fusses i've run 15 amp and tryed 20 and 25 amp .it it is a 2 **** motor . like now will it cold out it run good for about two days dut when it wormer out it seems to blow them more but i've not really been useing it ahole lot .becouse of it and i need it almost every day so could hte wire from the fuss box be to small or is it somehting else.please help if you can thanke
  • John Trevino May 11, 2010
    A two horsepower motor at 115v will draw lots more amps to start then settle at maybe 15-18 amps. Most homes are not wired properly to power this compressor. If the wire that feeds your plug has a long run from the main switch box, you will have the problem that you describe. The best option would be to rewire your compressor for 220v. At the higher voltage your compressor will most likely only draw about 8 - 12 amps and cost less to operate. If your compressor cannot be wired for 220, or 220v not available maybe your could exchange for 1 1/2 hp at 115v.
After the tank fills with air for the first time and air is left out, the commpressor pump will kick on and kick off the outlet curcuit breaker. Why would it do this?
Posted on Feb 01, 2009
Have toro 418 snow thrower prime it and starts but immediately stalls can only keep running if I keep pushing the primer button what's wrong
The fuel pickup tube in the carburetor is probably clogged. I don't know how handy you are, but you have to remove the carb, disassemble it and blow out all the orfices with compressed air and possibly run thin wires into the tubes and holes. Good Luck! the last time I had to do this was in the middle of a snowstorm!
Jan 28, 2015 | Toro Power Clear 418 ZE - Single Stage...
How do you clean the fan blades?
If it is not easily accessible, Id recommending taking it outside and blow it out with a air compresser that has a blow spout attachement on it, if that is not available, most towns have tire changing companies that sell used ties, most of these places would be willing to blow it out for you for a few dollars im sure, sometimes thinking outside the box can save you some money on the long run.
Hope this helps.
Oct 14, 2013 | Alpine Natural Air 3000 Air Purifier
Xs 250 yamaha ignition
You have possibly connected the leads to the wrong terminals
Aug 20, 2013 | Motorcycles
2000 road king efi keeps blowing neutral/oil pressure fuse
Hi Jody, you need to blow out the connectors to these switch circuits that probably got water in them with compressed air, for a free wiring diagram please visit the website below and good luck. Harley Davidson Wiring Diagrams and Schematics
Feb 07, 2013 | 2000 Harley Davidson FLHR-FLHRI Road king
My Wii system will not read any discs I try. Is there a fix for this?
Sometimes the laser inside of the Wii can get dust on it that would keep it from reading. You can try and get a canned of compressed air and blow into it or just give it a good old fashioned blow.
They also sell these laser cleaners for the Wii:
http://gamesweasel.com/blog/news/wii-lens-cleaner/
Thanks and please rate if this helps you! :)
Mar 29, 2011 | Nintendo Wii Console
What is wrong when your ignore and meter fuss keeps blowing
Not 100% on the first part of the question...but fuses blowing makes me think faulty wiring is to blame. Check for frayed or damaged wires.
Mar 14, 2011 | 1995 Geo Tracker
Air conditioning blowing fuss
Faulty clutch/coil assembly. If there was zero pressure in the system the low and high pressure sensors would not allow the clutch to engage, just to clarify.
Sep 20, 2009 | 1998 Dodge Caravan
Fresh air 2.0: Unit cycles on and off.
The problem is dust or moisture on one or more of the circuit boards, in the bottom of the unit. The problem is usually caused by resetting the cleaning reminder without actually cleaning the machine. ;-) It hasn't been difficult for me to solve so far. Remove the filter. Remove the two screws that hold on the plate where the rear switch is located. The wires are long enough that they don't need to be removed from the switch. Use a blow dryer or dry compressed air to blow off the circuit boards. ****Keep your face out of the way!!! Be sure not to get the blow dryer too close or too hot. If you have a Warm setting, use that. Good luck!
Sep 30, 2008 | Ecoquest Fresh Air Air Purifier
Air Tools & Compressors Logo
95 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
