Question about Ruud UBHC Air Conditioner
Door switch not allowing green light to come on indicating power
The door switch when pushed in will turn the LED green light on sometime but not all the time. Power flucuation.
  • 4,636 Answers
First check door switch to make sure it is not bad. Turn power off and straight wire switch to determine if the switch is the problem.
Let me know what you find.........Sea Breeze
http://yaunco.com/pdfs/rheem/upkb_spec.pdf
Posted on Jan 31, 2009
How do I replace bulbs on model DS5603 Mod G electric fireplace
Do you need to replace the upper or lower light bulbs?
For both, first open the door of the fireplace. For the upper light, locate the upper bulb bracket (above the door). Bend the bracket down. Unscrew the old bulb and replace it with 7 W clear chandelier or candelabra bulb with an E12 base. Bend the bracket back up to its original position. Close the door, if only the upper bulb is out.
You will need a Phillips blade screwdriver to replace lower bulbs. Open the door (if it wasn't already open). Locate the screw that holds the log set in the center of the ember bed. Remove that screw and the log set. Locate the bulbs that are behind the log set and determine if one or both bulbs need to be replaced. Unscrew the bulb(s) to be replaced. Screw in the replacement 60 W clear chandelier or candelabra bulb with the E12 base. Replace the log set and press firmly against the glass. Replace the screw that holds the log set. Close the fireplace door.
The procedure to replace the bulbs is on page 4 of the service manual. It is also on pages 10-11 of the Owner's Manual. The documentation is available from Dimplex: http://www.dimplex.com/en/customer_support/technical_and_troubleshooting . The direct link to the service manual is http://www.dimplex.com/cms/publications/7400650000R04.pdf . The Owner's manual is here: http://www.dimplex.com/cms/publications/7206570100R09.pdf .
I hope this helps.
Jan 12, 2017 | Heating & Cooling
I have a Rheem Classic Super Quiet 80 gas furnace (for heat). The fan stops when the "heat" turns on.
Any time I ever had trouble,first thing to suspect is the thermostat.
They lose contact sometimes and sometimes you tap the face and they work til next glitch.
If the thermostat has some years on it,go ahead and replace it.
Can't you just leave the heat and fan in auto? That would be best,I think. don-ohio
Jan 10, 2017 | Heating & Cooling
Where are the batteries on my thermostat
If you posted the Brand and model that would really help. Sometimes they are in the front behind a little door or more commonly you need to take the thermostat off the sub base and they are on the back of the thermostat.
Mitsubishi slit air conditioner model MSZ-GA80VA I turn on and turn off cauting out door unit fuse blown I replaced still The fuse is blow is the out door air con unit Note.unit in door stop not inpos
turn off everything electrical in house and retry with good fuse or breaker if still blows unit needs repair possible shorted capacitor? if it runs it may need to be on its own circuit dedicated to it alone
Jan 05, 2017 | Mitsubishi Heating & Cooling
My Coleman furnace 4322/729 model lights the pilot but won't cut in . What could be problem ? Cleared lines Complete
Gas valve not opening? Does it have the exhaust blower that pulls vacuum switch allowing burner to light?
(1) Thermostat not working? Has to complete the circuit in or gas valve to open.
(2)Can be a stuck or bad gas valve. Try tapping the side of the gas valve body while thermostat is calling for heat. Tapping,not pounding. Like lightly,yannow? don-ohio (:^)
Jan 03, 2017 | Coleman Heating & Cooling
Why does my ceramic heater keep turning off
Without other specifics I can only postulate that it's more than likely overheating, and perhaps it's location stifled
Dec 09, 2014 | Heating & Cooling
Electric Furnace stopped running
You have one of two problems. Either the capacitor for the motor has failed or the motor has failed. I would turn off the power to the unit and see if you can locate the capacitor and remove it. An ac supply or electrical supply house can match up the capacitor. This is relatively inexpensive. Otherwise you will need a new motor.
Nov 11, 2014 | Heating & Cooling
Conair Lysol hand held steamer
Does it tell you to add salt to the water?(I have a cheapo little steamer that requires salt to increase the conductivity of the water-it just creates steam by running AC voltage through the water in the tank)
May 25, 2013 | Heating & Cooling
I have a Kenmore dehumidifier 58053701300. It worked fine for maybe five summers, but I couldn't get it going this past June. It just would not turn on. I checked the outlets. No problem. No...
I will start to dig into this one and see what I can find as far as measurments for voltage. In the mean time, you said the bucket was ok, but did you check to see if the shut off float switch is operating and moving freely and not bound up some how. It should also have a slight clicking sound as the switch is made and unmade.
Dec 04, 2011 | Heating & Cooling
Ruud UBHC Air Conditioner Logo
59 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
