Question about Hotpoint Ultima WF860 Front Load Washer
  • Hotpoint Master
  • 3,463 Answers
You will probably need to clean the pump filter.
To access the pump filter,remove the lower plastic panel at front of washer, there you will see the filter, unscrew the cover anti-clockwise, remove filter and clean.
This should clear the fault.
If it does not , let me know, and i can can tell you other things to look for.
Please rate my fixya solution.
Posted on Jan 31, 2009
  • coisti Feb 13, 2011
    this was very helpful thank you washing machine up and running many thanks
  • henrylucyeve Apr 27, 2011
    Followed your advice it worked many thanks. Was thinking I was in for a big bill
    New Friend:
Hoover washing machines saying E03 can any one tell me want it means thanks
Posted on Apr 26, 2013
I turn the the filter anti clock wise but it wont come out
Posted on Nov 27, 2011
Machine flashing f 05 taken back cover off and cleaned hose,still not emptying of water, shall we give up or try something else? hotpoint ultima wf 860
make sure you have checked the pump itself, possibly a hairgrip/nail etc. jamming it. also make sure nothing blocking the actual waste hose itself.
Jun 19, 2011 | Hotpoint Ultima WF860 Front Load Washer
It keeps flashing F-05
I guessed that both postings were for the same problem especially when I saw where from ;-0) so please see your other posting.
John C
Apr 10, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hi my hotpoint ultima wf860 keeps filling and wont drain disply panal says f-05 can you help please?
Sounds like your water pressure switch is faulty. You can replace this easily by removing the top panel, the part is round and about 2-3 inches diameter, it has a thin pipe connected to it that goes to the tub and 2 or 3 wires plugged onto it. F5 means pressure switch jammed on full. Hope this helps
Mar 02, 2011 | Hotpoint Washing Machines
I have a hotpoint ultima washing machine wt965 and the display is flashing f-05
F05 - Pressure switch jammed on full - Check pump for blackages. Also resetting the machine sometimes solves the problem switch off at plug for 5 mins then switch back on and try again. hop this helped
Sep 26, 2010 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
My hotpont tumbledryer keeps flashing up f11 its a hotpoint ultima ctd85 pls help
Fault code F11 means that the pump is not working,check the pump connections and the pump itself.
Please leave feedback.
Nov 12, 2009 | Hotpoint Dryers
Cycle ctopped and is flashing f 05
F05 means pressure jammed on full.
Check pump for blockage, or filter if waher has one.
Please rate my solution.
Jun 21, 2009 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint aquarius wma58 1400. Full of washinh. Full of water.
pull your washer out. put near door if poss then put the waste pipe down to floor level to empty the water. if there is to much water in the drum it will not spin try your pump
Jun 21, 2009 | Washing Machines
Hotpoint ultima wt741
f11 keeps flashing door won't open
Sep 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
777 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
