press the helpful button and follow me on Fixya for more helpful tips
The current models of automatic standby generators will have LED indicator lights on the side compartment of the generator. A green LED light will indicate that the unit is in AUTO mode and is ready to run, or is running properly during a utility outage. The yellow LED light will indicate that maintenance is needed. The red LED will indicate either that the unit is switched to OFF or that there is an alarm detected. If a yellow or red LED are present, you will need to check the generator's control panel, as it will describe the type of maintenance needed or the alarm present. This information can be found in the owner's manual as well. You can find a copy of the owner's manual online by searching the model or serial number of the unit here
http://www.generac.com/service-support/product-support-lookup
