Question about HTC Touch P3450 Smartphone
HTC Touch Screen malfunction
Hi, i've had my HTC Touch for almost a year now and up till now it has been working fine, but recently my touch seemed to be locking up. The screen would apparently be black as if the phone was off and the power button on top would not turn the screen back on. The phone is however still on due to flashing blue and green lights up top. On further inspection it seem that in a VERY dark room i was able to slightly make out that my screen was still working it was just too dark to be visbible. This problem went away on it's own after a little while, but it has happened more and more frequently since then and now it seems permanent. Also earlier today I realized that if i pressed down on the bottom right hand corner of the screen and pushed the power button at the same time, my screen would spring back to life like normal, but as soon as i remove the pressure on the bottom right hand of the screen, the screen goes back to it's apparent "dead-like" characteristics.
Any help would be much appreciated.
  • Amanda420 Feb 10, 2009
    hey i have the same problem. Ive had mine just under a year as well. And up until now the only way i could get he screen to come back is just keep turning it off and on by removing the battery and putting it back in. I tried ur screen solution and it works for me also but does not turn back off after removing pressure. it stays normal up until i charging or after a call but not after every call just every so often but always during charging. You should have 1 year warranty from the day of purchase if u do go get ur new one right away. I have the warrenty and lucky for me i also purchased an extra 3 years..and is expecting my new one with in a couple of days. I was going to try a hard reset to see if it would do ne difference but i have not tired it. If u dont have warrenty this might be something to considure doing. but b4 u do make sure u save ur contacts and ne other documents that u might have on it. Or else it will all be erased. good luck..right on here an update of ur phone>
  • Anonymous Feb 12, 2009
    I have had my Touch just over a year and I have this problem.
    The screen goes black like on auto-off - but pressing the button on top doesn't do anything.
    A soft re-boot sorts it but after an hour or two it goes back to the problem.
    I haven't tried your remedy yet.
    I will get rid of it and buy something else - certainly not an HTC product.
Hi, i want to formate my htc touch phone.... i dnt want a number formate.... i want a clear full formate
Posted on Feb 02, 2009
How to unfreeze the touch screen on a htc inspire
try taking the battery out for a short time,then refitting it.turn on phone
Jul 25, 2014 | HTC Cell Phones
HTC my touch 4g frozen
my touch phone screen freeze.what is the cause?
Dec 31, 2012 | HTC Cell Phones
My htc tytn II screen suddenly became unresponsive to the stylus or even my finger. I can only open my screen lock through the keyboard which worked but takes longer time to use. many commands can only...
Hi. You need to replace the digitizer. This happens to many touch screen phones from all brands.
you can purchase from:
After purchasing you can have it replaced in a cell repair shop or similar shop. Or you can chose to replace it yourself.
Thank you for using fixya.
May 24, 2011 | HTC TyTN II Smartphone
Hi, im using my htc touch bviva from past a year i dint had any problem till date but from past 2 days my touchflo stopped working my cell phona is working fine only problem with the user...
Turn of your phone and remove the battery for 10 minutes. The reinsert the battery and deploy the HARD RESET ( Check HTC Viva Manual how to do hard reset). Also you may try to clear storage in the settings. BY doing this your device will reset to orginal factory settings.... BE SURE TO BACK UP YOUR DEVICE before starting this... you can use SPRITE BACK UP also available on the HTC website.. download both device and PC software ... take back on PC for easy restore.
Good Luck..
Aug 22, 2010 | HTC Touch Viva Cell Phone
Screen was not aligned
I too own a HTC 3g and also had similar problem , if suppose i touch 2 number 1 comes, then later I removed all my 3rd party softwares and did a clean hard reset now i don't any problem. It works fine.
hope it would be fine for you,
R K Soni.
Mar 04, 2010 | HTC Touchâ„¢ 3G Cell Phone
The touch pad of HTC Touch responds intermittently.
hi, its a error in the phone, I had this happen to mine. You will most likely have to sent it away for repair. Just reflash the stock ROM and make sure that you have reflashed the stock SPL if you where using hard SPL and you will be ok this site will help you flash: thank you
(vote for me)
Sep 23, 2009 | HTC Touch P3450 Smartphone
Htc touch screen not working.
Hi, I had the same problem. Whenever, I touched my screen the wrong things would respond, then finally one day my phone locked & when I tried to unlock it the screen wouldn't respond at all.Took my phone to 3 sprint stores and all the techs couldn't help. One even accused water damage or overheating because they saw spots under my screen. But I never wet my phone so I thought it might be overheating since I do live in a warm climate. They all tried to get me to buy a new phone, which seemed like a scam. I didn't want to hard reset & lose all my data so I looked closer at the screen & noticed the spots didn't look like water spots & peeled the screen back. I noticed that the glue from around the screen actually leaked onto the screen, so I dampened one end of a q-tip & wiped the glue off the dryed it with the other end. I turn the phone back on and the screen worked fine. Try cleaning thr screen before doing a hard reset or paying for a replacement phone. It'll save you time & headache.
Hope this helps =)
Jan 09, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
HTC Touch P3450 - Bluetooth issue
Set your car stereo to play input from bluetooth, which is make and model of your stereo?
Apr 18, 2008 | HTC Touch P3450 Smartphone
Touch screen not working
the only solution i have found...replace the phone
Feb 20, 2008 | HTC Touch P3450 Smartphone
my car kit is not even picked up by the htc yet my p910 was working fine. Microsoft does it again - sell you something that they know does not work, yet instead of putting an advisory out they waste my time my petrol going back and forth from supplier to supplier. This is the problem with all the American companies , honesty and integrity is only for the others.
Sorry I am a bit frustrated that I will get a fine which will make my phone even more costly
Dec 19, 2007 | HTC Touch P3450 Smartphone
HTC Touch P3450 Smartphone Logo
303 people viewed this question
Top HTC Computers & Internet Experts
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
