Question about Garden
Cub Cadet LT1042
Thanks for help on spring. Now I have this problem: How (where) to reinstall the belt keeper rod for the engine pulley?
  • jharri4 Feb 01, 2009
    Thanks, I figured out where it goes. For some reason I cannot see the picture you posted on the site.
  • 323 Answers
SOURCE: install belt on cub cadet mower
First, make sure you have the model number and serial number (located under the seat) and then go to www.cubcadet.com to get a belt diagram so you know which way the belt snakes through the pulleys.
You will have to remove the two pulley covers on either side of the deck.
Fit the belt around the right side of the deck pulleys when you are on the left. There is an arm attached to the springed pulley on the left side. It will have a hole the size of a 3/8" driver/ratchet. Set the ratchet on unscrew (to the left) and push the arm in toward the center of the mower. You will see the pulley moving too, creating enough slack to slip the belt over the edge of the rim of the pulley with a little elbow grease. If it is too tight, get someone to push in with the ratchet while you slip it on. Once again, you are the grass cutter king!
Posted on Jul 25, 2009
bbreton
  • 437 Answers
SOURCE: I have a Cub Cadet 1250. The PTO suddenly stopped
Look at www.cubcadet.com. There under parts you should find an IPL for your mower. You will need the model and serial number from under the seat to get the information. Look under the electrical for PTO.
HTH
Good Day.
Posted on Oct 29, 2009
SOURCE: Huskee supreme 46 " drive belt keeps comeing off..
mine is to tight..cant adjust the snowblower belt with PTO off it still turns what can i do Huskee tractor...email me at guitarblues60@yahoo.com
Posted on Dec 02, 2009
SOURCE: my cub cadet mower LT1042 will not start. It acts
Just had the same problem with our LT1042 and it was the fuel shut off soloniod. Could not buy just that piece so we took it off and cut off the piece that went up on the carborator and put it back on. Started right up. Now it back-fires when we shut it off but it runs.
Posted on Apr 30, 2010
Fix4You
  • 32 Answers
SOURCE: how to replace the drive belt on a 2006 cub cadet
Use the link below to download the manual for free.
http://www.cubcadet.info/Manuels/2005/Tracteurs/LT1042-LT1045-LT1046-LT1050-Owner.pdf
Posted on Nov 14, 2010
Why does the deck drive belt on a cub cadet 2042 keep coming off and or breaking every time you try mowing the yard ?
My first guess is the belt is not properly routed through all the pulleys and past the belt keepers. Please check everything twice against the belt diagram in your operator's manual.
Mar 02, 2017 | Cub Cadet Garden
How to replace belt model 2155 cub cadet engine pulley to deck?
Download the owners manual from Cub Cadet using model number 13A-244G100.
Customer Service Cub Cadet
Sep 16, 2014 | Cub Cadet Garden
Cub cadet ltx 1050 extension spring where does it go
In case anyone has a 2014 Cub Cadet LTX 1050 KW and needs to know where the damned spring goes when it falls off when removing the belt keeper, here's a photo.
Jul 15, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
My belt came off and I need to know how to put it back on?
There should be 4 pulleys.2on the deck that are above the blades,put the belt on those first.
There should be a tension pulley,with the engine OFF,look on top of the deck and engage the blades.Note the direction the tension pulley moves,the belt must pass inside that pulley.Now disengage the blades and put the belt on the engine pulley.
May 11, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
Belt keep coming off cub cadet 1042, all parts on deck have been replaced with new parts & still the belt comes off every time
my cub cadet used to throw the cutter belt too....till i took the drastic step of adding a bit more tension to the belt. this was achieved by drilling another hole on either side of the chassis about 1 3/4 inches to the rearward of the machine and moving the lift arms to the new holes. Viola, more belt tension, and furthermore there is now no interference between the tensioner and the rearmost run of the belt.
Oct 22, 2009 | Garden
Garden Logo
321 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
