Question about T-Mobile Sidekick II
T Mobile Sidekick 3 how to open it up ?
I need to get to the motherboard (mainboard) in this phone to resolder a loose power plug connection. Does anyone know exactly how to disassemble it ? I was able to take out the LCD screen, but only because I saw the two screws holding it in place. Thanks
  • Anonymous Nov 25, 2007
    how do you open sidekick 2 i already got screen off now what?
  • jillywillybe Apr 24, 2008
    I want to open the back to put in the sim card in, but don't know how to...can anyone help?
I do not no how to open it up
Posted on Dec 19, 2007
You have to flip off the side silver plastic panels. They kind of snap on and off. Probably try to get at them with the screen open. Once they are off you will see the 4 screws to get the phone open.
Posted on Aug 20, 2007
SOURCE:
The screen on my T-mobile Sidekick 3 went white.
You need to reseat the LCD cable. More than likely it has come loose in the back of the LCD
Follow the guide at the following link.
Sidekick White Screen Repair Guide
Jun 14, 2010 | T-Mobile Sidekick® 3 Cellular Phone
The screen wont come on my sidekick 3...ball still works
Yeah, more than likely the lcd cable connection is loose. That is what the white screen usually indicates.
It is fairly easy to take a apart and reseat.
Follow the guide at the link below
Fix Sidekick 3, Sidekick ID, Sidekick II White LCD Screen
Jun 19, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick III 3 LCD Backlight stopped working sometimes
yes you need to replaced the LCD to make it work again.
Jun 03, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3
Take a look at the following link:
They usually run abour 20 dollars:
Sidekick 3 trackball replacment parts
Here is a guide for replacing the trackball assembly on a sidekick 3
Hope that helps
Aug 28, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Ayy
Is the orange light coming on but you have no power? If so, then it is probably not charging. The sidekick 3 charging port is notorious for going bad. The little contacts that send power to battery come loose.
Find a friend that has a sidekick 3 or sidekick ID and try out their battery. If it powers up, it is your charging port.
The easiest thing to do is to get a charging cradle that has a spare battery charging slot. They run about 25 dollars off off ebay and allows you to charge the battery seperate from the phone. A spare battery is good too as it allows you to have one charging at all times.
http://repairmysidekick.org/SideKick-Repair-Parts/Sidekick-3-Spare-Battery-Charger
Sidekick Spare Batteries
Jun 07, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Help
If you sidekick ID screen is white, you may be able to fix it. The flex cable connection cable on the lcd screen itself can come loose. Chance are if you tighten it, the screen will work again. I have had success with sidekick II and sidekick 3 with this same problem.
The following instruction for a sidekick 3 but it is the same for a sidekick ID. Just reseat your lcd instead of installing a new one.
Sidekick 3 LCD Screen Only Replacement
Mar 27, 2008 | T-Mobile Sidekick ID Cellular Phone
Sidekick 3
if that is happenin' you need to take replace the mainboard.
Feb 12, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Busted Sidkick 3 Charger Port
Sorry to hear that. The Sidekick 3 is notorious for the charging port getting busted.
If you take it apart, you can see that it is soldered in 5 places to the motherboard. Maybe one of those solder joints came loose.
This link will show you how to take apart your sidekick.
Sidekick 3 Disassembly
Another option is to get a charging cradle that has a spare battery charging slot. They go for about 30 dollars shipped on ebay. This will allow you to charge your battery external from the phone or if you have an extra battery , have one charging at all times.
Check the followinf link to see availability.
Sidekick 3 Spare Battery Chargers
Feb 03, 2008 | T-Mobile Sidekick® 3 Cellular Phone
i have sk 3... the backlight does not work. And the keypad light works sometimes. Does the LCD light need t/be replaced?
Oct 22, 2007 | T-Mobile Sidekick® 3 Cellular Phone
SIDEKICK 3
Downloading songs(mp3) to your sidekick is very simple. Connect the phone to your PC or insert your memory card. Open My Computer, open SDCard or Removable Disk, Open My Music and simply drag and drop the music files ih that folder.
To register....
  1. Have your phone (Sidekick or otherwise) with you
  2. Visit my.t-mobile.com
  3. Click "Register for My T-Mobile"
  4. Enter your 10-digit mobile number without spaces (e.g. 5557771234) and click "Submit"
  5. Your phone will get a text message with your password. It will be something like ar1wo6 and it is CaSe sEnSiTiVe!
  6. Log in using your mobile number and temporary password
  7. Fill in the information the page asks (note: you will be asked to provide a new password, and if you are using a Sidekick, this will also change your Sidekick login password)
  8. Select your phone from the list if prompted
Aug 08, 2007 | T-Mobile Sidekick® 3 Cellular Phone
T-Mobile Sidekick II Logo
1,284 people viewed this question
Top T-Mobile Computers & Internet Experts
Ekse
Marvin
Marvin
markpain
Level 1 Expert
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
