Question about Asrock 775VM800 Motherboard
Continuous beeping
Try to reinstall xop sp2 boot screen dispays ok ram ok.hd`s ok..cd`s ok....go to option screen to highlight option but no response...the goes to continuous beeping
  • Misterixas May 11, 2010
    Have you tried to set BIOS to it's defaults (clear CMOS)?
  • Thomas F. Schneider May 11, 2010
    Te us the Beep sequesnce. This is a code.
  • 558 Answers
You may have bad memory,if you have more than one stick installed try one at a time,see what difference this make
Posted on Aug 30, 2009
Installed new HD into Dell 1720 Inspiron after getting the 0146 errr code. Once I installed the HD I began the installation of Vista. It almost finished then the screen went back with the cursor...
you need to format the hdd first before you can successfully install Vista.
try booting from cd/dvd by pressing F12 on the Dell screen.
- Select optical disk drive dvd/cdrw and press Enter
- Press Any key to boot from CD or keep tapping the spacebar.
- If you see Windows Setup EMS enbaled, press Enter.
- Keep clicking next until you are asked "Where do you want to install windows?"
- Click Drive options Advance
- Click or select to highlight the partition to where you want to install Vista
- on that same windows, click "Delete" and OK
- Click "NEW" and then click "Apply"
- Click "Format" and then "OK"
- After that, you may now click "Next"
Now windows vista should be installed in your computer and on its last boot, it will ask you to create a profile (username and password).
^_^
Jun 12, 2010 | Dell Inspiron 1720 17" Widescreen...
New build pc no boot... black screen
Try to remove the battery from the MB, and next time you try to install WIN XP, when you are asked how to format your drive, chose quick NTFS formatting; disable floppy drive in BIOS, because it might try to boot from it (and I suppose you don't have one), and in boot sequence (BOOT DEVICE PRIORITY) set cd-dvd as first, and HDD as second, and turn off any other device as bootable
Nov 17, 2009 | ASUS M2N-MX Motherboard
Gigabyte GA-945P-S3 short beep codes on cold boot. Tried reseating RAM, didn't help. system runs fine after beeping stops
Using the manual for the Gigabyte GA-945P-S3 MB. Go to page 71 & you'll see bios beep codes for your board: AWARD BIOS Beep Codes 1 short: System boots successfully 2 short: CMOS setting error 1 long 1 short: DRAM or M/B error 1 long 2 short: Monitor or display card error 1 long 3 short: Keyboard error 1 long 9 short: BIOS ROM error Continuous long beeps: DRAM error Continuous short beeps: Power error As you can see there isn't a code for three short beeps. When you boot your system try to pause your boot up screen. See if the bios is reporting the correct total of memory in your system. Bios codes from the link below. http://www.computerhope.com/beep.htm#05 3 beeps for the AMI bios code reports Base 64K RAM failure. You can test your memory. Go to memtest.org Scroll down the site to just under the three screen shots. Download Memtest86+ V2.11 You have a choice in making a bootable floppy disk or a bootable CD-ROM disk. Once completed you boot your system to the testing program. Memtest will check your system memory. This should help. Thanks for using FixYa! Mike
Jun 04, 2009 | Gigabyte GA-945P-S3 Motherboard
Tecra M2 doesn't boot is it a processor problem?
given the symptoms, it points to motherboard.. if it was processor, video or ram. it wouldnt boot at all and you'd just get error beeps from your laptop. i'd first try resetting the bios, by removing the bios battery for 30 min, then putting it back in. if that doesnt work try changing it out, usually costs under 8 bucks. if that doesnt work then I would change out the motherboard, if its cost effective.
Mar 03, 2009 | Toshiba Tecra M2-S730 Notebook
Blue screen problem
If you have the operating system CD then boot from that and if it is a Windows retail cd then you will have several options. If it is a recovery cd then the only option might require a complete format and reinstall. Pressing F12 will give you a one time list of boot options. Some machines like Compaq use F10 for recovery. Look for the boot options on the lower part of the screen at boot. If only a blue screen appears initially then try pressing F2, F1 or Delete right after the first beep. If there is no beep then make sure all drives are empty, all peripherals disconnected. Blue screen means that you have a display. Beep codes are listed in the manual or on the BIOS manufacture's website. Faulty RAM can cause this problem as well. Try reseating the RAM. More details will get you more help if these tips do not resolve the issue. Best wishes to you.
Aug 26, 2008 | Acer Aspire 5500 5570-2609 Laptop
Blue screen error
It is best to repair the existing installation of the operating system.
Thanks
Aug 06, 2008 | Microsoft Windows Server Standard 2003 for...
HD crashed, no boot from CD/floppy possible, blue screen
the problem is that windows 2000 doesn't recognize , or recognize but show wrong size for large hard disks. The size limit for windows 2000 is 120 GB. Hope that it helps.
Jul 28, 2008 | Acer Aspire 1705SMi Notebook
PC won't boot
It can be either the RAM or the Video card. If you have put a new Video card then check with the old one.
Replace RAM and check. Best of kuck
Jun 13, 2008 | Intel Motherboard
Trying to do a repair installation
OK, that screen is the bios for the laptop. Don't do anything in there. (except check under boot and make sure the boot order is cd then hard drive) Once the boot order is correct, just boot from the cd rom, and to do a repair, just keep continuing past where you are asked to enter F-8, the next screen will offer a repair for the windows installation- press R. That keeps your files and programs, but reinstalls windows. Good luck
Aug 11, 2007 | Acer Aspire 3680 Laptop
Asrock 775VM800 Motherboard Logo
199 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
