Question about Toshiba Satellite A85-S107 Notebook
Problems with my Toshiba Laptop.. A85-S107
A few days ago I tried to turn on my laptop but got a blank screen with a blue box in the center telling me to enter a password. I have tried every password that has ever been on this computer and have no idea how to fix it. Need help!!
    Problem Solver:
  • 15 Answers
Hey as jimmie is saying the password is in the bios so if you are able to open your laptop and locate a jumper called CMOS remove for like 30seconds that will clear your bios then return it and you will be able to bott without any problems
Posted on Jul 31, 2007
    Problem Solver:
  • 15 Answers
I think it is not a problem. You can find a battery inside of the laptop. Get it out and make it converted in the battery slot to clean the COMS. Then your laptop will be fine.
SOURCE:
How do I change a keyboard on a satellite A85-S107 laptop?
1. Take out the battery and AC adapter, unplugged from the wall, enusre the laptop is fully powered off.
2. Remove those screws with a T-8 or Phillips screwdriver.
3. Turn the laptop back over and open it up. Check and see if the Toshiba Satellite A85-S107 keyboard is tucked under any plastic pieces. If so, find them if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
4. Remove the plastic pieces carefully.
5. Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You'll notice that the keyboard is connected with a thin, but wide, data cable to the system board at the bottom.
6. Disconnect the data cable attachment of the keyboard which will sever all the remaining attachments of the laptop keyboard with the laptop computer motherboard. To remove this cable, you have to just carefully pull it out from the socket to which it is attached. Then you can lift out the entire keyboard out of the laptop.
7. Take the new Toshiba Satellite A85-S107 keyboard out of the plastic and place it inside with the right orientation, attach the data cable.
8. Refasten the keyboard in place at the top.
9. If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
10. Turn the laptop over and replace all of the keyboard screws.
11. Put the laptop battery back in place and switch it on to check Toshiba Satellite A85-S107 keyboard functionality. If everything has gone according to plan, you should be ready to type away!
Mar 12, 2012 | Toshiba Satellite A85-S107 Notebook
I have a toshiba satellite a85-s107.....got blue screen of death
when ya boot it up...press F8 a bunch of times and try to go to safe mode and try to copy all your files to a hard drive and then put the disk that came with your computer in, and reinstall your operating system and that usually works for me
Dec 27, 2009 | Toshiba Satellite A85-S107 Notebook
Toshiba Satellite a85-S107 the volume control wheel on the computer does not turn the volume all the way down. I can still control it through windows. Help!
maybe your driver is not working well http://www.rudytarigan.com/laptop/toshiba-satellite-l310-drivers.htm go to this site you can find drivers of toshiba there. reinstall some of your not compatible drivers.
Aug 06, 2009 | Toshiba Satellite A85-S107 Notebook
No video stream
driver problem so try to install it from their site
Jun 21, 2009 | Toshiba Satellite A85-S107 Notebook
Toshiba a85-s107 satellite laptop - does not power on
Remove the battery and reinstall the battery. It should reboot
Apr 09, 2009 | Toshiba Satellite A85-S107 Notebook
Spill on laptop..how do I clean
ok -
First:
Disassembly guides with pictures:
How to remove keyboard.
http://irisvista.com/tech/laptops/ToshibaA55/SatelliteA55_remove_keyboard.htm
Remove laptop LCD screen. http://tech.irisvista.com/laptops/ToshibaA3/remove_laptop_LCD_screen.htm
Second:
ONLY clean with 95% - 99% rubbing alcohol, then wait till COMPLETLY dry before re-assembling.
Hope this helps.
Jul 03, 2008 | Computers & Internet
Toshiba Satellite A85-S107 laptop touch pad L-R key not working
try using the fn and f9 to enable or disable the touchpad.
Jun 27, 2008 | Toshiba Satellite A85-S107 Notebook
Problem running the restore disk for Toshiba A85-S107
I have the same model and i just reformatted the hard drive with the original restore disk and it does loop around several times. That is the way it is suppose to do on this particular restore disk. So don't be afraid if it goes around several times because it is doing different tasks each time it loops.
Nov 19, 2007 | Toshiba Satellite A85-S107 Notebook
Toshiba Laptop Keyboard Malfunction
If you boot a XP cd and select repair will it let you type?
Sep 21, 2007 | Toshiba Satellite A85-S107 Notebook
Toshiba Satellite A85-S107 Notebook Logo
209 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
