kawasaki 19.2V 4 Piece Cordless Tool Kit
Problem for kawasaki 19.2V 4 Piece Cordless Tool Kit
Kawasaki tool set/batteries will not
By marktreadwel on Jan 31, 2009
kawasaki tool set/batteries will not charge and the light on the charger does not come on like its not charging at all.
Clarification Request
Posted by FTjoe on Feb 01, 2009
the charger will not charge any of the batteries? if none, then i would check the fuse inside the charger. most chargers have a fuse inside.
Solution #1
posted on Feb 01, 2009
Not Rated)
muttandjeff
Rank: Wiz
Rating: 84%, 133 votes
MAKE SURE POWER ON OUTLET YOU ARE USING FOR CHARGER , CK TO SEE IF CHARGER IS FUSED , TAKE A PENCIL ERASER AND CLEAN ALL THE CONTACTS THAT MAKE CONTACT WITHE THE BATTERY IN THE CHARGER AND ON THE BATTERY ITSELF , AS SOMETIMES THEY GET CORRODED AND DO NOT MAKE PROPER CONTACT , IF NONE OF THESE WORK YOU COULD HAVE A BAD CHARGER
Was this helpful?
Yes
No
Popular Solutions for kawasaki 19.2V 4 Piece
Questions and Unsolved Problems for kawasaki 19.2V 4 Piece
Do you recommend kawasaki 19.2V 4 Piece Cordless Tool Kit?
Answer
Answer
Ryobi p111 charger -- light stays red even if battery left charging overnight.
Answer
I have a dewalt de9116 charger and when a battery is put in it flashes constantly even a new... (More)
Answer
I have had two cordless drill variable speed triggers burn up and render the tool useless (original... (More)
Answer
how do you connect the wire connections for the power switch?
Answer
screwed 75 2 1/2 inch deck screws worked great, came back the next morning and zip doesn't work.... ... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For kawasaki 19.2V 4 Piece...:
Top Drills / Driver Experts
Rank: Guru Guru
Solutions: 1212
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Drills / Driver Experts
Top Garden & Power Tool Repair
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
