Question about Admiral AW22 Top Load Washer
Admiral is not spinninng
Everything is working except the spin cycle. water is drain but clothes are too wet still.
  • sawidick Feb 28, 2009
    My Admiral stops in the spin cycle, too. If I apply downward pressure onto the knob, it will start again. But this happens every single spin cycle, gentle or normal wash.
    Genius:
  • 1,075 Answers
I would say the simple soulation to this is get the main belt tightened.sounds loose???.hope this helps.adrian
Posted on Feb 25, 2009
MY WASHER SPINS AND DRAINS THE WATER BUT MY CLOTHES ARE STILL WET
are you sure that its spinning as this is a common problem with wet clothes. When the cycle is complete the clothes should be wrapped around the bottom of tub not just lying there,
Sep 26, 2011 | Admiral AW22 Top Load Washer
Washer won't do spin mode
Repair Clinic solved the problem for free and I'll be buying the part from them. Thank you!!
Dec 30, 2009 | Washing Machines
Does washer drain before the spin cycle starts?
Normally yes. There are around 12 to 20 gallons of water in the tub after the wash cycle, which will be anywhere from 63 to 110 pounds of weight in addition to the weight of the clothes. For the machine to start the spin cycle to remove this water would place a heavy load on the motor, gearcase, pullys, belts, gears, ect. With the water drained, the load is lighter, and much easier to start spinning the excess water out of the clothes. The normal cycles are: Fill, Agitate, Drain, Spin, Rinse Fill, Agitate for rinse, Drain, Spin Cycle and off. Imagine trying to spin a 5 gallon bucket of water over your head, full of water, and then empty. Which one do you think would be easier to do? And safer for you.
Sep 26, 2009 | Admiral AW22 Top Load Washer
Slow spinning wet clothes
The reason to this problem is your worn belt.It might have
gone bad.You may need to replace it.
Sep 02, 2009 | Admiral AW22 Top Load Washer
Washer does not work well on spin cycle admiral aav7000aww
No you need to check ur clutch, u can check it by running the spin cycle for a few minutes then shut it off and turn machine up so u can look under it. get a spray bottle with cold water and alil soap detergent, then spray the clutch with it, if it shows or steams up or sizzles then the clutch is slipping and bad. the cluth is in the center near the tranny, should look like a round siver pc of metal about 5 inches in diameter
Jul 18, 2009 | Admiral AW22 Top Load Washer
Clothes are wet at end of spin cycle
Dear Customer
Please perform the following
Clothes are too wet after spin cycle:
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Please rate this,Thank u
Dec 17, 2008 | Maytag Washing Machines
Admiral AAV8000AWW washer - clothes are wet after spin cycle...
may be a loose belt or a partial blockage somwhere.
Nov 09, 2007 | Admiral AAV7000A
Admiral AW22 Top Load Washer Logo
96 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
